Question about Life Fitness 9100 Next Generation Remanufactured Treadmill
The screen is on and asking to press statr to begin but the keys wont work
    Top Expert:
  • Life Fitness Master
  • 12,223 Answers
Adjust the REED switch, see the diagram, clean it, test for open or faulty, and tight the connector very well.
However you must RUN the software calibration for easy diagnostic, and fix it. the screen is on and asking to press statr to begi - 6c4c6e08-8307-45a9-a0ef-8476bc51f1ff.gif
God bless you
Posted on Jul 10, 2013
F2,f8,f10,f12 don't work to get bios menu . how can i change my bios setting during set windows up by usb.
if you are trying to get into your BIOS you have to press which ever key when you are booting the system you can't be in windows because it wont get the proper key stroke to enter the BIOS.
Mar 19, 2015 | Computers & Internet
IGNITION KEY TURNS ON BUT NOTHING WORKS
sounds like a bad battery or bad cables go to battery(corrosion or just loose]
Mar 26, 2013 | Cars & Trucks
Im having problem with my laptop it wont work properly when i brought it to a technician he said it needs to be reformat my friend said i can do reformating my self but i dont know how can u help me. tnx.
You can do it yourself. First backup all your data on a USB dribve or somewhere else.
Now Simply insert the CD/DVD of the OS which you want to install. (WIndows XP/Windows 7).
Make sure it should be bootable. Restart your machien and Let the Installation begin.. It will ask for you to press any key to Setup Continue.. Press any key. Now just follow the Steps as provided in the screen in third screen where get the option to choose C:\ or D:\ here you can choose C and use format option.
With regards
FIXYA team.
**Please post your feedback and Vote if the problem resolved as per your satisfaction**
Oct 11, 2010 | Acer Aspire One PC Notebook
The numbers 1-3 on the keypad wont work
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the beginning of the post and skip to the last part For Repairs )
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the diagnostic tests.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Release the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterward you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a high pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
You can also try this site. They do repairs on most models, except the newer ones.
Jun 03, 2010 | HP 48gx Calculator
I got eee pc 900a but wireless not working i try
  1. Turn off your computer
  2. Turn it on and immediately begin rapidly pressing F2 by itself
  3. Go to the Advanced tab by pressing the right arrow key once
  4. Go to onboard devices configuration by pressing the down arrow key once, then pressing Enter
  5. Go all the way down to Onboard WLAN by holding down the down arrow key until it is selected
  6. Press the minus key (-)
  7. Press F10
  8. Press Enter when it asks you to save configuration changes
If that still doesn't work, make sure you have the drivers you need from here:
http://support.asus.com/download/Download.aspx?SLanguage=en-us
Mar 22, 2010 | ASUS Eee PC 900 Notebook
My neice has an acer aspire 5517. Turned it on and the screen is blank, no start menu or icons. How can I fix this?
Hi there, please restart your laptop when its booting press F8 key . You will find few option asking for selection. Select that by using up/down arrow key. Select " Last know good configuration" & press Enter. Next page asking for selecting operating system, for example: windows vista or Windows XP etc. Just select the operating system & press Enter again. ( Hope your laptop showing only one operating system ). Your laptop will start normally. After the if you seen the screen dark then press FN+Right arrow in key board(>). When you press FN + ( < ) or ( >) key that's time its working for brightness controlling for screen. Now if all well then fine other wise please let me know .
Another suggestion is run your Acer driver DVD for installing Display drivers. When finish restart your laptop and watch whats going. If no success then format the Operating system & reinstall again.
Thanks & waiting for your feedback
Feb 10, 2010 | Acer Aspire 5500 5570-2609 Laptop
Last windows update now I can't boot it up. Window screen comes up and then shuts the computer down and statr all over again
Ensure NO media is plugged in first ie CD / mem stick.
May not be the Windows update. try booting into safe mode using F8 key, if you can access windows that way then problem is a program thats trying to load. To stop programs from loading go to safe mode
If windows wont load in safe mode then registry is corrupted.
Jan 26, 2010 | Toshiba Satellite A85-S107 Notebook
My palm treo is stuck on spanish and I have no idea how to change it back to english.
The only way to reset this to english is by performing a Hard Reset. It will remove all information on the phone BUT after it reformats it gives you the option to select English or Spanish.
The hard reset is performed by following the instructions below:
Press and hold down the red phone key on the right side of the Treo 650 keyboard until the Palm screen appears. This will begin the hard reset.
Let go of the red phone button when you see the Palm screen.
Read the screen prompt carefully. It will ask you to press the up arrow key to proceed with the hard reset or the down arrow key to abort. Press the up arrow to continue with the hard reset.
Wait for the phone to reboot. When it comes back on, it will ask you to select a language and walk you through the same introductory screens you saw when you first got the phone.
That should solve your problem! Hope this helps!
Dec 24, 2009 | Palm Treo 650 Handheld
Compac dv 2000 laptop
first you have to know what is goin on with your laptop, is it starting up to the bios? or continously restarting, or rebooting or totally not statring at all. please specify what exactly happened to your pc to be able to know what if your board is not working at all
have a nice day
ally
Jun 12, 2008 | Computers & Internet
LANIER LX231 WITH LANIER VTI LX547
We use this equipment in remote locations and have found that the type of phone needs to be a centrex line, such as is used on a fax machine. Note: in the past, we used to have to use an "analog" phone line, which is just a normal phone line.
You probably have two different phone lines involved here.
Jun 12, 2008 | Lanier Audio Players & Recorders
Life Fitness 9100 Next Generation Remanufactured Treadmill Logo
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
