E01 my midea air conditioning gives a E01 malfunction how can I repair it
H2 error on ODU display
https://www.carrierair.com.au/installer-and-technical-support/fault-codes/
Check the links to talk to a technician or service. I find no easy access to matching a sheet of error codes with your carrier VRF on the web. I encounter codes but the sheets fail to identify the models! Those codes refer to a decrease malfunction which defies interpretation by any but an air conditioning technician. So, the most direct route to your query answer is at the above link.
Jun 16, 2017 | Carrier Heating & Cooling
My midea aircon is showing F3 code?
Display = E2
Malfunction or Protection = Communication error between indoor units and outdoor unit.
This is the meaning of the error code. If you need any more AC Cleaning & Repair help contact the professionals.
Apr 07, 2015 | Midea Heating & Cooling
E1 Error for Midea AC
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Jul 25, 2011 | Refrigerators
Our dryer reads E01. I can't locate our manual so what does that mean? Thanks
E01 - lint filter dirty, exhaust air duct is blocked or too long, fault in program sequence or malfunction, the room/cabient is not adequately ventilated.
Feb 13, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
No air blowing from the aircon. though the aircon can be switched on and off.
something is wrong with the fan, it may be jammed with a foriegn object or have a malfunction. kids may have stuck things in it.
Jan 05, 2010 | Midea WP10000 Air Conditioner
How to make a makeshift Midea portable AC vent kit
Yes a dryer hose will work, you can also buy insulated pipe from an Air conditioning supply house or possibly LOWES.
Aug 26, 2009 | Danby DPAC8020 Air Conditioner
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
