Question about Car Audio & Video
Power outlet fuse on 09 Honda accord ,the one under the arm rest !!!!where is the fuse
    New Friend:
  • 20 Answers
I have a pilot and the power inverter is located under the passenger seat, I believe, the fuse should be there.
Posted on Jul 23, 2013
I installed a new tv radio on my 09 honda accord lxp. Now the parking lights and the ac climate control lights are not working. Can somebody please help me.
Check your fuses and double check your wiring. You've likely mis-wired something to the radio that also supplies power for the lights in the dash. So if you find a blown fuse, you might blow it again if it's a wiring issue. Of course, you may have bumped a wire to ground during the install which blew the fuse, so replacing it may be all that's needed.
I had an issue where a "small light fuse" in my 97 accord blew and my parking lights and dash lights didn't work. Small fuse under the hood was all that needed to be replaced.
Nov 23, 2014 | 2009 Honda Accord
2010 honda accord lx-p power port fuse
Diagram at the link shows fuse 12 under the dash powering the console port.
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=170157
See next to last page.
Oct 02, 2017 | Honda Cars & Trucks
My 2006 honda accord has a cigarette lighter in the arm rest that doesnt work but i dont know what fuse to change for it. do you know?? It doesnt say in my owner's manuel or the fuse cover.
hi there is a two fuse box one under the bonnet and one beside the drivers right leg thats for australia maybe different to your country check the one beside the driver leg it should be 15 amp put when reading the cover put back of the cover against fuses thats how you readit good luck
Mar 23, 2011 | 2006 Honda Accord
I have a honda 2006 accord and the power outlet doesnt work
List of items to check: B+ to outlet( wires from fuse box may have an open) , outlet itself may be corroded ,fuse may be blown.Double check the items you've been using in the outlet. They may be defective or not appropriate for that outlet.
Jul 22, 2010 | 2006 Honda Accord
2009 Honda Accord Coupe power outlet problem
yeah you can check your fuses on the driver side under the dash board, you will find one of them blowed.
Jan 25, 2010 | 2009 Honda Accord
Power Outlet in 2003 Honda Accord not working
plug somthing in the outlet andstart pulling fuse.You can also use a test light.
Jul 26, 2009 | 2002 Honda Accord
Power outlet of Honda accord 2002 EX V6 doesn't work (the fuse is OK because it uses the same fuse as radio system). Please guide me to show the problem. Thanks
could be the plug conecting on the back of the outlet under neath the front center console. i have seen them get truned so many times and just un plug from twisting...
May 03, 2009 | 2002 Honda Accord
1998 Honda Accord power outlet bad, can't figure out which fuse
try the fuse on the passenger side marked radio. mine went out awhile back and the power outlet is on the same fuse as the radio. If that dosn't fix it then get a multi-meter and start checking to see where you are getting power and where you aren't. it may be nothing more than a burnt wire under the center console. in that case you have to take out most of the console to get to the underside of the outlet cause there isn't any other way to get it out
Apr 02, 2009 | 1998 Honda Accord
Car Audio & Video Logo
67 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
