Question about Acer ASPIRE 5720-4649 Notebook
Formatting step by step how to reformatmy computer
  • 369 Answers
You can restore it to factory settings:
Restart your computer, hold down ALT key and start hitting F10 key up and down at the computer startup.
Posted on Jul 10, 2013
How can u reformat the acer netbook by copying to other computer
Step 1:
I'm not sure end result you're looking for but I can give you the process on how you can format or reformat your hard drive by. Keep in mind that formatting a drive will erase everything on it so back up everything before starting the process. I believe it will only allow you format or reformat a secondary drive.
Step 2:
Right click on my computer on xp or right click computer in the start button on vista and beyond then select manage
Step 3:
Go to disk management (it is under storage) and right click on the hard drive you want to format and select format
Step 4:
Follow the prompt and the drive will format or reformat. Most likely it will change to NTFS.
Feb 15, 2013 | Acer Aspire One PC Notebook
How to format memory stick Sandisk
Attach scansick memory stick to your computer
Double click on my computer
find your memory stick drive.
right click on the Memory Stick (MS) icon
choose format
click on quick format
click on start
click ok on warning appear
Aug 10, 2011 | Computers & Internet
Memory card formatting
Hi
how to want to format you Memory card through Mobile and through computer. the both way i describe you let chose which one you look easy.
Through Mobile.
Switch off the mobile and Insert your memory card in mobile.
Step 1.
Press the white menu button.
Step 2.
Select "Applications".
Step 3.
Select "File mgr.".
Step 4.
Double-click on "E: Memory Card".
Step 5.
Select "Options".
Step 6.
Select "Memory Card Options" and then "Format".
Through -PC
Formatting your memory card, flash drive or device:
1. Double-click My Computer, or Computer (for Vista)
2. Right-click the drive letter associated with your memory card, flash drive or device, then select Format
(in the sample image below, we right-clicked on H:)
WARNING: Make sure you select the correct drive letter.
3. Select a File system type.
NOTE: Select FAT32 for 4GB or higher capacities. FAT for 2GB or lower capacities
4. Click Start.
Memory card info and old cameras
Many previous old cameras and portable devices do not work if the card is formatted as FAT32 or NTFS file system. One of the following errors may occur if your device does not support FAT32 or NTFS:
- Error message asking to re-format the flash card.
- Error message that the flash card is not formatted.
- Error message indicating that the card is anomalous.
To resolve the above error, backup your data and reformat your memory card in FAT file system.
If the error persists, re-format the memory card using your camera or portable device.
Aug 02, 2011 | SanDisk 1GB microSD Memory Card
How to format a new seagate external hard drive
Hi josernld
Formatting your drive for Windows Vista
STEP 1: Open Computer Management like this:
  1. Right-click on the Computer icon.
  2. Click Manage.
If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
STEP 2: In the pane on the left, under Storage, click Disk Management.
STEP 3: Right-click the drive that you want to format-be sure it's the correct drive-then click Format
STEP 4: To format with the default settings, in the Format dialog box, click OK, and then click OK again.
Formatting your drive for Windows XP STEP 1: Open Disk Management like this:
  1. Right-click on the My Computer icon.
  2. Click Manage.
  3. In the pane on the left, under Storage, click Disk Management.
STEP 2: Right-click on the drive you want to format. Be sure it's the correct drive.
STEP 3: If you want, you can type a name for the drive in the Volume Label box. This is an optional step.
STEP 4: Click the file system that you want to use in the File System box. You can also change the disk allocation unit size, specify whether you want to perform a quick format, or enable file and folder compression on NTFS volumes.
Note: Before changing the default allocation unit size please refer to Microsoft Knowledge Base Article 314878.
STEP 5: Click OK. When you're prompted to format the drive, click OK again.
Formatting your drive for a Mac STEP 1: Open Disk Utility like this:
  1. Click Finder.
  2. Click Applications.
  3. Click Utilities.
  4. Click Disk Utility.
STEP 2: Select the drive you want to format. Be sure it's the correct drive.
STEP 3: Go to the Partition tab.
STEP 4: Click on the Current Volume Scheme drop-down menu and select One (1) partition.
STEP 5: Click Options. From the Partition Schemes provided:
  • Click on the GUID Partition Table radio button.
    --OR--
  • Click on the Apple Partition Map radio button.
STEP 6: Click OK. Select other options as desired (e.g., Volume Name, Format, etc).
STEP 7: Click Apply. The Partition Disk screen opens.
STEP 8: Click Partition. At this point, the volume dismounts from the desktop and the drive is partitioned and formatted.
Note: When Volumes are created, Time Machine may open, asking if you would like to use the volume for backups. Click Cancel to proceed.
STEP 9: When finished, select the Disk Utility from the Apple Menu and choose Quit Disk Utility.
Feb 17, 2011 | Seagate Computers & Internet
I have kingston 32gb pen drive this working only 1gb remaning 31gb not woked
Try out to format your PD. if format doesn't work try following steps.
steps to format:
  1. right click on my computer.
  2. select manage.
  3. select disk management.
  4. on right side select your drive.
    (tips. your pendrive is in removable media. so see in this group)
  5. right on drive,you want to format.
  6. then select format.
if it doesn't works on your computer. then use updated antivirus or else format it on others computer.
if it helps, pls rate it... ; ) thank you.
Oct 12, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a iprodrive external hard drive and my laptop does not reconize it any more. the last time i used it i did not disconnect properly. is there a way to reset it
Here a step by step guide i found as i surf the net last week. Read along.
  1. Step 1 Log in to your computer as the administrator.
  2. Step 2 Install the external drive software from the CD that comes with your external hard drive.
  3. Step 3 Use the USB cable that came with your external hard drive and plug one end of the cable into your hard drive and the other into the USB port in your computer.
  4. Step 4 Give Windows a moment to recognize the external drive and to assign it a drive letter.
  5. Step 5 Go to the "My Computer" icon and double-click on it.
  6. Step 6 Choose the newly created external drive letter in the right-hand explorer window.
  7. Step 7 Right-click on the external drive letter and choose "format" from the drop-down box.
  8. Step 8 Choose "quick format" from the format options section from the next pop-up box.
  9. Step 9 Click the "Start" button.
  10. Step 10 Click the "OK" button in the Format warning box.
  11. Step 11 Click the "OK" button in the "format complete box" to finish the process.
Should you have any questions regarding this post feel free to post it here.
  • Step 2 Install the external drive software from the CD that comes with your external hard drive.
  • Step 3 Use the USB cable that came with your external hard drive and plug one end of the cable into your hard drive and the other into the USB port in your computer.
  • Step 4 Give Windows a moment to recognize the external drive and to assign it a drive letter.
  • Step 5 Go to the "My Computer" icon and double-click on it.
  • Step 6 Choose the newly created external drive letter in the right-hand explorer window.
  • Step 7 Right-click on the external drive letter and choose "format" from the drop-down box.
  • Step 8 Choose "quick format" from the format options section from the next pop-up box.
  • Step 9 Click the "Start" button.
  • Step 10 Click the "OK" button in the Format warning box.
  • Step 11 Click the "OK" button in the "format complete box" to finish the process.
  • Read more: How to Reset an External Hard Drive | eHow.com http://www.ehow.com/how_4840145_reset-external-hard-drive.html#ixzz0YYmAf0Ra
    Jul 24, 2010 | Computers & Internet
    How can i format my hp notebook computer
    for to format it whole ...you have to do it during the installation of the operation system ...or ...if you even want to get rid of the recovery partition you do not use..get the hard disk out and insert it in another computer and format it ..for this you need a laptop with dual hdd or a rack for hdd on 2.5 to connect it via usb..
    But the simplest way is during the installation ...when yoi get to the previous installation just choose to format or delete and rebuild the partition and this is all...after finishing the installation the C partition will be reformatted ..for all other taht do not contain windows...you only have to right click on the partition and choiose format from the list and do it ...
    Jun 03, 2010 | HP Compaq nc6000 Notebook
    How do i format a Cd on windows xp
    1 Open your disk drive2_bing.gif. Ensure that your disk drive is empty before proceeding, some CDs, especially CD-RWs, will be erased if you skip this step.
  • Step 2 Place CD-RW into CR-R drive. The disk drive may automatically detect this is an empty or "clean" disk. If so, skip to step 4.
  • Step 3 Find the disk. Click on "Start," then "My Computer," then on "Devices with Removable Storage," and then right-click on the CD-RW icon.
  • Step 4 Format the disk. Select "Format Disk" from either the drop down menu on Step 3 or from the Dialog Box in Step 2. This process should take only a few minutes to complete. If your CD-RW has information on it already, you may select "Erase CD-RW" instead of "Format Disk."
  • Mar 16, 2010 | Microsoft Windows XP Home Edition
    Step by step tell me how i can format my windows vista lapy
    Are you sure you want to format and install clean, or do you want to reset to factory defaults,the way it was when the computer was new? If you want to restore, it depends on make and model.
    To format:
    Boot from your Vista DVD
    Follow prompt up until it asks where to instal
    Highlight your current Vista installation
    Select Advance
    Select Format
    Step by Step screen shots of install process:
    http://vistahomepremium.windowsreinstall.com/installnewhdd/installnewhdd.htm
    Feb 09, 2009 | Microsoft Windows XP Home Edition
    How do i format my sandisk cruzer mini 4gb
    To format this device better if you connect it to your computers USB port and let first the computer to recognize it, then when its already recognize by the computer double click Mycomputer icon and you should see there sandisk , just right click on it then click on format.....
    Oct 27, 2008 | Computers & Internet
    Acer ASPIRE 5720-4649 Notebook Logo
    21 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
