Van overheated now cant get it to turn over
If you have had the vehicle hot then I would suspect that you will have a breached head gasket at the very least depending on how hot it was and for how long. You may have damaged other component of the engine as well. Remove the spark plugs and inspect for water on top of the pistons or rotate the engine with the spark plugs removed and watch for water purging from the cylinders. If there is water present then you need to have the head gaskets replaced and the cylinder heads checked by a reputable machine shop for cracks. Other components of the engine should also be checked for damage such as the piston rings.
