Question about Oregon Scientific WMS801 WeatherNow with MSN Direct Service
Will not receive a signal
I have spent days trying to get a signal I have tried all 4 sides of condo I have hit reset it keeps scanning for signal then tells me to press In /Reg then scanners some more. Help
    Top Expert:
  • Oregon Scien... Master
  • 38,077 Answers
Review the setup instructions. Batteries have to be installed in a certain way and there has to be a waiting period to allow the two units to "talk" to each other
Posted on Jul 10, 2013
Waveceptor reset
I have a number of these Casio and Citizen watches. This watch does not use GPS for the time keeping. It uses a land based broadcast time signal. There is public information about where the signals come from for your area. The technical breakdown of the time code signal is public access information.
The instruction manual of the watch has the information about when your watch should automatically receive the time signal, and how to set up the watch. Many of the manuals also included a map showing the time signal coverage, and includes the time of day information to show when the signal is strongest.
Make sure the watch settings are for your time zone. This is important. If the main time zone is not for your area it will be trying to receive the signal at the wrong frequency at the wrong time of day. There are areas where the signal may not be able to be received. You can get the mapping for this from the service that the watch has been set to use.
In North America the auto time receive is supposed to take place between midnight 00:00 to 04:00. In the eastern part of North America the reception is poor compared to central and western part of North America. Check the instruction manual for your watch for details.
Below is the spec listing of your watch.
  • Atomic Timekeeping
    Receives time calibration radio signals which keep the displayed time accurate
    Auto receive function (3 times per day)
    Manual receive function
    Signal: WWVB, UK MSF Frequency: 60kHz
  • 50M Water Resistant
  • EL Backlight with Afterglow
  • World Time
    29 times zones (30 cities), city code display, daylight saving auto/on/off
  • Date Alert
    Display flashes when set date is reached
  • 4 Daily Alarms and 1 Snooze Alarm
  • 1/100 second digital stopwatch
    Measuring capacity: 99:59'59.99"
    Measuring modes: Elapsed time, lap time, split time, 1st-2nd place times
  • Hourly Time Signal
  • Auto Calendar (pre-programmed until the year 2039)
  • 12/24 Hour Formats
  • Accuracy: +/-20 seconds per month (with no signal calibration)
  • Battery CR1620
  • Approx. battery life: 2 years
  • Module 2556
Size of case / total weight
WV57 47.0 x 39.0 x 12.5mm / 44g
WV57HD 47.0 x 39.0 x 12.5mm / 89g
Apr 29, 2014 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Cannot get audio on one channel
Which make/model TV do you have? Are you watching an OTA signal or cable signal?
On my Viewsonic N1930W, I had a period where certain OTA VHF channels had no audio. The UHF channels were fine. The steps I used to reset the TV: unplug for a while. After reconnecting the power, go to the Tools (Options) menu and then reset the TV to the defaults. Then I did a new channel scan for OTA channels. On my TV, the menu is called Options but the icon is a wrench and a hammer in an X. Thus I call it Tools. The Restore Default option is at the bottom of the list in that menu. The reset command triggers several "Are you sure prompts?" Pressing the Enter key on the remote after highlighting Yes is required. After the reset, I can go to the Channel menu and select Auto Scan after making sure that it is set for Air as the source.
If you post a comment with the details of your TV, I may be able to give the steps to reset your TV.
I hope this helps.
(I spent several days trying different solutions and did e-mail Viewsonic support on the problem.)
Jan 05, 2013 | Televison & Video
My Hp compaq 6515b is not recognising my power password any suggestion.
1st method identfy bios when start up " AWARD BIOS, AMI BIOS,etc etc below some backdoor passwords try these first
Award BIOS' :
AWARD_SW, j262, HLT ,SER,SKY_FOX,BIOSTAR,ALFAROME,Lkwpeter,j256,
AWARD?SW,LKWPETER,syxz,ALLy,589589,589721,awkward,CONCAT,d8on,CONDO,j64,
szyx.
For AMI BIOS' try these backdoor passwords:
AMI,BIOS,PASSWORD,HEWITT RAND,AMI?SW,AMI_SW,LKWPETER,A.M.I.,CONDO.
For PHOENIX BIOS' try this backdoor password:
phoenix
2nd method: remove the laptop battery, and in back of your laptop 3 to 4 screws showing small keybord pictured or keyboard mark, remove those screw's, turn front and 3 little hidden clips upside of keyboard, slide down those clips, carefully remove the keyboard, in motherborad near touchpad, locate the small silver color coin battery, remove that battery for 1 minite or 2. and put it back. your password will reset. and also bios resets to factory setting.( before resetting just write down the setting on paper) best of luck keep smiling. aaarwind
Jan 15, 2011 | HP Compaq 6515b Notebook
My DCT6200 cable box keeps shutting itself off and then turning back on. I have already tried resetting it by unplugging, but that has done nothing. Even after I have turned off the power and left it...
1) have you tried changing that box in that room to another and the box from the other to this room. That may give you an idea of either power or signal strength issue.
2) after it resets does a "dl" show up on the box front. if so it is trying to download a firmware/software update and everythime you power cycle it starts over.
3) turn the box off then hit select and go to option 8. there should be 4 modules enabled.
4) you may need a new box
Aug 02, 2010 | Arris DCT6200 DTV Receiver
Within the last two days I have lost the signal for ITV1 4 & 5 tried retuning but no signal received, my Postcode is BD20 9AL
Have you tried a complete reset of the TV, since the switchover date in some areas, transmiters have changed too. ry this ad let me know.
Good Luck
Stuart
Jan 12, 2010 | Samsung LN32A330 32 in. LCD TV
RUUD AIR CONDITIONING SYSTEM: HEATER DOESN'T WORK
there is no reset . some part somewhere has gone bad it had nothing to do with the bad filter ........ troubleshooting a hvac unit is tricky thing to do and if you want someone here to talk you through it , thats just a bad idea . i have spent years learning how to troubleshoot and spent lotts of money on the tools of the trade . i think you should call in a hvac repair person to check out your heater and find out the problem , its money well spent .......if this answer helped please rate this 3 or 4 stars . the high rateing will keep me in the paid answer department thank you
Apr 04, 2009 | Ruud UBHC Air Conditioner
DTV H20-600
You could check the voltages yourself to see if they are low. The horizontal polarity needs about 19 volts and the vertical polarity about 14 volts to work properly. If those voltages are lower by 25%, the receiver might failed to scan and that is when it locks up because is trying to find signal. The other issue could be a defective power supply if the receiver does not work after that 4 hours. There could be some capacitors that lost their dielectric strength causing the drop in voltage.
Let me know if you need further assistance.
Nov 01, 2008 | Philips DIRECTV H20 DTV Receiver
Can't receive atomic signal
You can get it serviced at www.casiosalesandservice.com or call them toll free 877.659.0761
Jun 03, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Ip address on my computer?
Try this :
Go to Start -> Run -> Type 'cmd' (without the quotes)
In the command prompt window - type - ipconfig
If you do not see any ip address like "169.254....."
Type ipconfig /release (hit enter)
Type ipconfig /renew (hit enter)
Type ping 64.233.169.103
See what response do you get. If this says Sent = 4 ; Received = 4,
Go to IE and try opening a webpage.
If this says, Sent = 4 ; Received = 0
Tell me what ISP do you have?
How are you connected?
Have you ever been able to connect to this network before?
Do let me know what happens...
Thanks & Good Luck
Aditi
Dec 21, 2007 | Televison & Video
Oregon Scientific WMS801 WeatherNow with MSN Direct Service Logo
123 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Lawrence Oravetz
Timllfixit
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
