Question about Coffee Makers & Espresso Machines
Delonghi magnifica bottom tray won't go in
The bottom tray won't slide into my d?longhi magnifica. I feel like the little black box that says "push" is too low. But, that won't budge either. Idk, you tell me what's wrong.
  • 1,214 Answers
Hi there, I have the same type of coffee maker. I have had problems with " the black thing push". Back to the tray. Take the tray out and hoover the bottom and as far in as you can and under the " push". I need to hoover mine I can see now. delonghi magnifica bottom tray won't go in - 8_27_2013_9_23_31_pm.png
Posted on Aug 27, 2013
  • 3 Answers
SOURCE: water container full but low indication on
I think the water level is read by a magnetic pick up driven by a black floater located 3/4 way towards the back of the water tank.
Make sure this floater can move up and down in its pocket: you can see it through the walls so just shake the tank to see it move, and check that it floats up when you fill water
Posted on Apr 18, 2009
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Posted on Jul 08, 2010
  • 102366 Answers
SOURCE: I have lost my manual for the DeLonghi Magnifica
You can download the manual from the manufacturer's web site at
http://www.delonghiusa.com/downloadpdf.php?nid=20
Posted on May 04, 2011
mc1bean
  • 3053 Answers
SOURCE: my de'longhi magnifica coffee maker trips the
Yes it is possible, but here is what you have to do first, try a different outlet, that is not on same circuit , another part of house, even garage. If it still trips breaker, then more than likely it's a machine problem that is causing this. If it doesn't trip, then you can put it back where it was, but then have to maybe move other items on that circuit else where if your fond on that spot for the machine. Espresso machine have a huge surge electric demand when on heat mode. Like all kitchens they have several out let's on same circuit , if you still want it in same area, then have to move other stuff to other outlets that don't share circuit. And no you don't want to up circuit breaker to larger breaker as wires might not be rated to handle larger breaker. Let me know if my idea works, thanks mike from fixya
Posted on Jun 09, 2011
mc1bean
  • 3053 Answers
SOURCE: Every time I turn on my de'longhi magnifica coffee
Have to up the breaker at panel that controls that line of outlet circuits, but sometimes can not do this as wires in walls that control those outlets are on same circuit and rated at a curtain size breaker. Best and safest way to solve this is plug machine on different circuit that maybe not so many other items are sharing, like if your fridge or microwave is on that same circuit (breaker) it most likely will always trip. Let me know results if this solved problem, thanks Mr Bean Man
Internal water pipes leaking on my Delonghi magnifica. Where can I buy the pipes? Will I be able to replace the pipes myself?
DeLonghi Magnifica water leak problem - YouTube
? 2:37
https://www.youtube.com/watch?v=_mNGPs79ajY
Feb 5, 2011 - Uploaded by shellway2005
My DeLonghi Magnifica ESAM3300 is not making shots. Wateris instead coming out of the front bottom via a ...Missing: pipes
DeLonghi Magnifica leaking water pipe Questions ... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > DeLonghi
DeLonghi Magnifica coffee makers & espresso machines leaking water pipe related questions and answers. ... Delonghi Magnifica My steam arm drips when I make coffee. ... Not sure if water is leaking from water tank or internal water line.
DeLonghi Magnifica leaking water Questions & Answers ...
Order DeLonghi Parts‎
www.ereplacementparts.com/DeLonghiadvertiser rating
Buy DeLonghi Parts.
Fastest Shipping - Low Prices.
Jan 07, 2016 | DeLonghi Coffee Makers & Espresso Machines
De longhi magnifica ESAM4200
Unplug it and try the following. See if there s a tab or lever than has dropped down in the track where the filter goes. This should push up thus allowing you to put the filter back in. Don't force it though. There is something physical in the way of this . Once you get it back in, the plug it back in. You will learn after you fix this what to do next time.
Feb 02, 2013 | DeLonghi Coffee Makers & Espresso Machines
De Longhi CT021.A x 2 slice toaser - Won't stay down
Is it plugged in. You may have to do a little handy work, unplug the unit and look to see where it catches when the handle is in down position, you may have to open the bottom door. There is a little catch when the handle is down it may need to be bent a little not much.
Oct 15, 2012 | DeLonghi RT200 Retro 2-Slice Toaster
I initially replaced the o-rings in the pipe/valve assembly. It didn't work for long (not correct size o-rings probably). I then bought a new pipe-valve unit. To replace you need to pry off the stream handle (chromed plastic). It only fits one way on the axle (so take notice when replacing!). Then remove back and side covers (6 screws all at the back). Then remove top (2 screws each side at the front and a couple at the back). Then the front panel should be lose. (Instructions based on a slightly different model)
Mine made better coffee after I fixed the leak! A large portion (perhaps 25%) of the water intended for the coffee went via the steam wand straight into the drip tray, which is not good.
Oct 15, 2012 | DeLonghi Magnifica 3300 Espresso Machine
Delonghi magnifica door won't stay shut
I had this problem. The door didn't snap when I shut it and it would pop open and stop the brewing. It was an easy 5 minute fix.
I removed the drip tray and the black plastic bin where the spent coffee grounds are expelled. With a flashlight I could clearly see 1/4" to 1/2" caked coffee grinds lining the back of the cabinet at its base. This residue kept the bin from seating correctly. Because the bin wasn't all the way back into the cabinet it put pressure on the door and kept it from latching. I cleaned out the buildup with a small spatula and a brush and the door latched perfectly again.
Apr 01, 2012 | DeLonghi Magnifica 3300 Espresso Machine
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
I have a Magnifica. The descale red flashing light won't reset after going through the descaling procceedure.
I have the same problem with my Delonghi Magnifica, so maybe there is a glitch in the machine..
Aug 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Jun 08, 2011 | DeLonghi Magnifica 3300 Espresso Machine
My Delonghi Magnifica (manual not digital) won't start the grinder, could this be the circuit board?
Delonghi Magnifica comes up with waste tray full light when there is nothing in the tray. It doesn't make coffee, the grinder is rotating and appears to be clear. Could there be a blockage below the grinder, if so how do I access it.
Aug 21, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
161 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
