Only happens when putting extra weight on it to get steted/speed up
presume it's a gear or chain problem but don't know how to fix it
It sounds like your chain is either stretched or worn out. Worse case scenario is a broken tooth on the front or rear gears or worn teeth. Unless you have a chain break it is easier to take the bike in and get them to replace the chain. They will also check the rear cog and the crank at the same time.
