Whirlpool duet ghw9400plo
Water left in washer after cycle
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet Washer fills with water when not being used
Water accumulating in the tub is usually caused by two things:
Leak by - which is caused by a water inlet valve malfunction. The valve has an electronically controlled diaphragm that closes to shut the water off when not in use. Over time the valve can accumulate sediment and debris causing the valve not to seat all the way. This is especially true if you live in an area that has hard water, or if you use well water. This will cause water to leak by when the valve is not in use and accumulate over time in the wash tub. You can attempt to clean the valve with distilled vinegar to remove any sediments and flush it with clean water. You will need to remove the valve in order to do this. Sometimes a good cleaning is all it takes to correct the problem. If not, I would recommend replacing it.
Siphoning - siphoning occurs when the drain line is installed incorrectly. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although the problem usually describes a condition where a washer constantly fills and drains, or cannot maintain the proper water level, it can also cause back flow from the drain. Double check your drain line installation to ensure there is a proper air gap to allow for proper draining. If not, a vacuum is created and drain water can back flow into the washer.
A simple test would be to shut the water supply off when not in use. If the washer STILL accumulates water, you know you have a drain problem. If it does NOT, then you know you have an inlet valve issue.
If you need to replace the water inlet valve, replacements can be ordered on line at searspartsdirect.com. Just type in your model number and look under the "Dispenser Parts" heading for item number 1 (part #8181694).
It is a very simple process to replace. Just follow these steps:
1. Shut off water supply and unplug washer.
2. Disconnect fill hoses from the back of the washer.
3. Remove washer top panel by removing the three screws that hold it in place in the rear. With the screws removed, the panel slides back, then off.
4. The water inlet valve is located in the left rear of the washer (as viewed from the front with panel removed).
5. Disconnect the dispenser hose from the valve and the mounting screw(s) and the valve is removed.
6. Install new valve using the steps above in reverse order.
It really is a very simple repair. I hope you find this information helpful. Let me know if you still require assistance.
Posted on Nov 18, 2008
jsrock516
  • 5911 Answers
SOURCE: GHW9400PLO
The "Fdl" code is a Door Latch Lock error. Inspect the door latch for obstructions that may be preventing it from locking and doublecheck the wire harness to ensure all the connectors are intact. If the latch is defective, use the following link for advice on how to replace it:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Another method of replacing the latch is to remove the top panel and work form the top down behind the front panel. Due to limited space, this may not be desireable to some.
Replacement latches can be purchased on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. Use your model number for your search criteria. These sites have great service and offer competitive pricing. Check out all three for the best savings.
I hope this information helps you. Let me know if you need further assistance.
Posted on Jan 06, 2009
  • 99 Answers
SOURCE: Grinding duet ghw9150pw4 front load washer
This is joyce
I just had to have my barrons replaced in my washer on the spin cycle it sounded like plane taking off. I dont know about yours but mine was loud, you probl. have the same problem. get a technician to come and check it out, all these machine's are hard to work on so let professional take care of it. if you need me to find someone in your area please just let me know.
thanks,
joyce
Posted on Feb 07, 2009
  • 212 Answers
SOURCE: whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Posted on Jun 22, 2009
localwonder
  • 6784 Answers
SOURCE: Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Posted on Oct 16, 2009
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Check the power input from the plug with a device which looks like a plug-in with six lights which can be purchased from a bigbox store and sells for less than 20 dollars, it tells you exactly what is wrong and if there is something wrong with the plug, I would suggest checking ALL of the plugs in the house and mapping out the electrical on the panel
Graham
Aug 15, 2014 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool steam duet washer won't pour water in the wash cycle
There is no output from the control panel to switch on the inlet valve, so check the inlet valve at this time of the cycle. Also check the water level pressure sensor switch.
Choose another program to confirm if not the controller seems to be suspect.
Jan 24, 2013 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
During wash cycle the washer stops at 11 or 12 minutes left and screen reads F . i have a frontload whirlpool duet HT
Just F on its own?
Try to clear it doing the following:
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Hope this helps comment back if you need further help,
Jul 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Any significant issues with 2004 Whirlpool Duet washer/dryer?
No more than ordinary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F11 and P14 Error on GHW9400PLO
f11 is a serial communication error between Central control and the Motor control. door lock is likely acting based on water level in machine at time of error. tech sheet says ck for powered rotations and connections at motor control. ccu may not be your problem but based on whirlpool history is still likely. You can check resistence across motor windings and also at tachometer (115ohms for later, part of motor)
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GHW9400PLO
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door Lock does not lock
1 o 2 issues either a bad door lock, or the machine control board located under the main top is malfunctioning.
Feb 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
