Question about Vtech DS6101 19 GHz Cordless Phone
How to remove Silent Mode - Vtech DS6101 19 GHz Cordless Phone
How do I get out of silent mode on uniden dect 6.0
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1760om.pdf
1. With the phone in standby, press and hold # on any handset. The phone prompts you to select the number of hours (1 - 9 or Always On) that you want it to stay in silent mode.
2. To confirm, press # or just wait about 5 seconds. The phone turns on the answering system and displays Silent Mode On on each handset.
3. After the selected number of hours, the phone automatically exits silent mode. To exit silent mode manually, press and hold # again.
Feb 18, 2015 | Uniden Cordless Phone
How to remove silent mode
Select the model of your Uniden cordless phone from the list beginning at http://www.uniden.com/owners-manuals/cordless-phones/scat/cordlessphones_mnl to download a copy of the manual.
Apr 14, 2014 | Uniden Lands Phones
Hi. i have a problem.I bought a new alarm beret 2 way 5000m and setup on my motorcycle. Alarm is working. Then i did switch to silent mode and now back to normal mode does not. Alarm always work silent...
If the Remote is now working now, the problems in the future will continue and get worse. I would recommend removing it and returning it for a Higher Quality Alarm System
Mar 03, 2014 | Motorcycles
Remove silent mode
Press and hold the # key for sometime(5 Seconds like that). Silent mode has been removed.
Jul 25, 2012 | Uniden DECT 6.0 Cordless Telephone...
How do i take my d1660 phone off silent mode
With the phone in Standby hold the # for about 5 seconds on any handset it should then Display 'Silent Mode off'
Hope that Helps
Jaysan
Jun 16, 2012 | Uniden D1660 Cordless Phone
Can't remove silent mode
Since you declined to specify the model of your Uniden DECT 6.0 phone, I can only direct you to select it from the list beginning here to download a copy of the manual.
Jan 21, 2012 | Uniden DECT 6.0 Cordless Phone
How to take your phone off silent
Hi traceylachla ,
Depends on the phone you are using , however generally there is way to remove your phone from silent mode as well as activate silent mode , please follow the below steps :-
  1. When in idle mode, keep the # key pressed till the time it tells you general profile has been activated or normal profile has been activated.
  2. If you press the # key again for a bit long time like 2 to 5 secs it will again go to silent mode.
Hope this trick helps you...:)
May 11, 2011 | Office Equipment & Supplies
My son put my Samsung phone on silent mode and I can't figure out how to get it off silent mode.... Help? Please?
Depends upon you model number but most of the samsung phone tunn on/off to silent mode by pressing and holding # button lower right corner of the key pad. if it do not work then go the settings then sound setting then incoming call then alert type it would be settled at vibration or silent by moving navigational keys remove it and sett it and melody.
Jan 12, 2011 | Cell Phones
Phone is on silent mode,how do i removed ?
Press and hold the # button and the phone should show exiting silent mode, press and hold # again to enter silent mode
Jun 11, 2009 | Samsung SCH-a870 Cellular Phone
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
Jun 08, 2009 | Samsung SCH-U470 Juke Cellular Phone
Vtech DS6101 19 GHz Cordless Phone Logo
18 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
