Question about Home Security
Genie powermax 1500 model 4062 - Home Security
How to program a remote for a genie garage opener model 209
When programming a genie remote press the learn button
Then you will have to press the genie remote at least three times before it stores the code older genie models 5 times genie i
Apr 05, 2015 | Building Materials
Can I use tje existing screw/rail of the 1/2HP Genie CM86001C and replace the old head with the new PowerMax 1500 head or does the new PowerMax 1500 require a new screw/rail?
No rail wont fit quite right. I would consider a liftmaster/craftsman/chaimberlain with yellow antenna wire. The liftmaster models are 8355 or 8550. Not sure how those model #'s translate to the craftsmans and chaimberlains. These units use 3 frequencies which are chosen automatically by opener radio. This gives you the best option to avoid interference. Genie typalically uses 2, but their fixed, so its a crapshoot to avoid interference. Do not confuse these frequencies with the rolling code feature which is a static frequency with only the "channels" changing.
Mar 28, 2015 | Genie Garage Door. PowerMax 1500 1 HPc DC...
Genie 1024 remote programming
On model 1024 genie garage door the carriage trolley jumping out of the chain what should i do to fix it or replace parts...
Feb 19, 2014 | Genie Company Genie Intellicode GITR-3...
Need to know horsepower on a Genie model 404 garage door opener
I believe it used 1/2 H.P motor that ran at 1500 RPM, 120 volts at 4.3 amps.
Nov 03, 2013 | Building Materials
Genie Powermax 1200 installed but only move approx 6 inches at a time.
You need to program the unit for up and down stops you can download the instructions from the link below
http://www.geniecompany.com/data/products/genie_programming-excerpt_eng.pdf
Jan 02, 2013 | Home Security
Received hoover powermax fusion vac today and the handle will not go down as indicated in diagram.
What is your model number? A Savvy and Powermax are differntent models. The Savvy the handle slides on and there are 4 screws to hold it in place. The Powermax has 2 screws to hold it in place. have you removed them before trying to put the handle on. If you have, you just have to work so it will slide down then put in the screws to secure it.
Apr 22, 2008 | Vacuums
Home Security Logo
77 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
