Question about Locks & Locksmithing
How to reset the combination on a Mosler Vault door Model # sd-4078-5L
I have access to a Mosler Vault door Model # SD-4078-5L, but no one knows the combination. I can do it myself, If I could find the instructions on How To Reset The Combination, but they are no where to be found. I have the Access Panel Key and the Change Key.
SOURCE: brinks fire resistant safe model 5059 instruction manual
To bad you dismantled. Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Posted on Sep 16, 2008
SOURCE: Need to reset time and name info on display for DKT301C-SD
To change time:
Press Intercom
press #
dial 652
enter 6 digit time in 24 hour format HHMMSS
press# press spkr
not sure how to fix name
Posted on Jan 13, 2009
emissionwiz
  • 76691 Answers
SOURCE: Forgot keypad combination
In order to change the keypad number code u have to have the original code Numbers, this is printed on a tag on the key-less entry module mounted under the rear glass package tray, on a shelf inside the trunk
Posted on Apr 08, 2009
  • 54 Answers
SOURCE: change my printer network access password
For an HP Officejet printer:
You can reset the printer definitions taking off the power cord and holding # + 6 buttons (semicomplete reset) or # + 9 (full reset) while connecting power cord again.
For an HP Laserjet printer:
Try logging in with admin as username and leave the password blank.
If not, preform a "cold reset" on the printer which resets parameters back to factory defaults. You want to print off a configuration page first. From the service manual :-
Cold Reset
A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM initialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
NOTE A cold reset also resets all the HP Jetdirect settings as well as the printer settings.
Use the following procedure to perform a cold reset.
1. Turn off the printer.
2. Press and hold the Go button.
3. Turn the printer on, and continue to hold the Go button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED turns on.
4. Release the Go button.
NOTE If both the Attention and the Ready LEDs turn on before you release the Go button, you must start the procedure again with step 1.
The printer's LEDs begin cycling. The cold-reset process runs until completion, and the printer returns to the ready state.
Posted on Apr 09, 2009
SOURCE: Reset the electronic combination for Doskosport Gun Guard Dlx Dbl
412231 is the combination I used.
Posted on Aug 07, 2009
I have bumil sd 103 safe and I have a key but I forgat combination codes...please if anyone know the solution.....
Unfortunately, according to this expert, you will need both the key and combination. You'll have to have proof of ownership and contact certain people to try to get the combination.
(It's a Bumil sd 102, but they should be the same)
http://en.allexperts.com/q/Locksmithing-3110/2015/2/t-bumil-sd-102.htm
Sep 08, 2016 | Home Security
How do i fix lost combination?
sorry but you need to contact the mfg of it to get combination . we do not have them here
Jun 23, 2015 | Home Security
How do I change the combination on a door key safe
Once it is already OPEN there is probably something side the safe and on the back side of lock access that will allow you to change the combination. I do not know the model number but this is standard practice so that one must know the current combination to reset it to a new one. Specifically how would be in your manual. The key would allow the over ride to access this recombination. I have a digital door lock that works similarly and you can either enter the numbers or use a key to unlock it unlike a analog safe it has both a master code (which allow the ability to create new codes or delete old codes) and an access code.
Feb 01, 2015 | Home Security
How to reset combination
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
the door and conceal your combination
7. Close the shutter door
Sep 03, 2014 | Master Lock 5400d: Portable Select Access...
Not able to access play store, sd card and, some settings on kyocera rise after factory reset
you must do a system update to latest software version in order to access play store
Nov 20, 2013 | Cell Phones
I locked the toy vault and then i forgot the combination
If it's a toy, try taking off the hinges, you can always glue it back on later.
Apr 08, 2009 | Toys
SD card can not be accessed on Sanyo NVM-4370
Did you hear a beep when SD card is inserted? Did you also try to hard reset the unit using the On/Off switch located at the bottom of the unit? Try with another SD card and see if the SD option is selectabe. If all have tried I suggest you to exchange for another unit. HTH.
Mar 02, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Locks & Locksmithing Logo
140 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
