Question about Frigidaire FPHD2491KF Dishwasher
Washpump Ran thru the cycle. Water enter machine and drains, heating element also works. Appears that the washpump is not working
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon bbriones113 - From what you are stating, there is water entering and leaving the unit and the heating element is working. However, what exactly is the issue the unit is experiencing? From my understanding the unit is completing the cycle, but what do you mean by the washpump is not working? Could you please be a little more specific and with this information I can better address the issue. Thank you and I look forward to your response.
Posted on Jul 10, 2013
4 Suggested Answers
  • 120 Answers
SOURCE: Heating element appears to not be working. Water
check under the dishwasher, but first switch off your main breaker.
Check to see if connections are secure, and not corroded. After that, replace the heater coil if all else fails.
Posted on Oct 02, 2009
  • 24 Answers
SOURCE: I have frigidaire dishwasher,starts cycle,can hear
Depending on your dishwasher, it fills either by a timer or by a water probe or float. I will assume its a timer as a probe or float wouldnt exhibit this behaviour. I would say you have a restriction in your water supply line. Check your valves, any screen filter in the water line for sand/scale/silicate/etc, pressure regulator if applicable. Another posibility is a poor magnet in your fill valve.
Posted on Dec 19, 2009
techbuster
  • 5081 Answers
SOURCE: Glasses have a film after washing complete. No
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
A helpful rating and a testimonial would be greatly appreciated if you are satisfied with my solution..
Posted on Oct 22, 2010
My chef classic dishwasher is not completely cleaning the dishes. There is no obstruction to the tablet/powder door opening, although there is a small amount of powder left at the end of the cycle. Both...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Check your heating element.. </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">A bad heating element causes many problems in dishwashers&hellip;<br /><br />Dishwasher Problems The Heating Element not Working<br /><a href="http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not" target="_blank">http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not</a><br /><br />Dishwasher Maintenance<br /><a href="http://www.fixya.com/support/r4319937-dishwasher_maintenance" target="_blank">http://www.fixya.com/support/r4319937-dishwasher_maintenance</a><br /><br />heatman101 <br /><br />Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes <br /><br style="mso-special-character: line-break" clear="all" /></span><br />
Aug 26, 2010 | Magic Chef CDB6100 Built-in Dishwasher
Problem with Hotpoint WD64 Washer Dryer
this possibly a bad contact on the panel board, thats why the system malfunction by itself. better to check on the every switch contact and clean for any moisture on the board.
Oct 31, 2008 | Hotpoint Aquarius WD640 Front Load...
KitchenAid KUDP01DLBS2 dishwasher. Runs for a very long time on any cycle; time does not seem to advance. (takes 2.5 hours or more for normal cycle. "sensing soak", "water heating" lights on for a long...
Sounds like the heater inside the dishwasher is not working. The machine is trying to get the water up to a preset temperature, probably in the neighborhood of 140 degrees. That is one of the things that it is sensing.
After the machine fills, open it up and take a water temperature reading. After it runs for 10 minutes or so with the water heating light on, but before it drains, open it up again and take another temp reading. If the second temperature is at or below the first temp, the heater is not working. Could be a burned out element, faulty wiring, or bad controller.
Check inside the machine (remove the panel below the door) for a wiring diagram. If there is one there it will give the resistance value for the heater element as well as the wire colors, the circuit diagram, and the cycle times.
Jan 05, 2010 | Dishwashers
Problem with KitchenAid KUIA18PNLS0 Under-Counter 18-inch Ice Mak
There is no solution. I have three kitchenaid ice makers and they do not work. The 18inch was under warranty. I had it serviced every friday until warranty ran out. I put an inline filter on the machine and it ran like a charm for three months, which is a first. It's out again! The two 15 inch same thing... inline filter and it worked for a month. Yes I have cleaned the machine over and over with appropriate products. It will turn on water fills but it appears as though the pump is not moving the water. Either way the machine worked correctly for two years only for the 15 inch and for the 18 inch one year.
Jul 15, 2009 | Kitchen Appliances - Others
Water level below heating element and element does not appear to heat
Make sure the drain hose high loop is installed properly, normally you have this in the sink cabinet high up. Otherwise the water inside the machine may drain "by itself", leaking through the inactive drain pump during the wash cycle and cause this and other troubles.
May 24, 2009 | Kenmore Dishwashers
F-05
F05 machine means "Pressure switch jammed"
Try first cutting power to the machine for two minutes, if that reset the code, then the problem was temporary.
If not :
Check if the machine drained, or if water is not being drained.
If drain system works .take off the the lid , locate the switch, it must have a small hose attached.
Remove the rubber hose attached to it, and unlock it by blowing into the hose.
If the water does not drain, this will also cause the pressure switch error.
In this case check the drain hose , and the drain pump.
Finally, ta faulty timer control board can cause the error, you test the control PCB if lid switch and drain system are OK.
Apr 01, 2009 | Washing Machines
Gevalia CM-500 12 cup problem.
Underneath the hot pad that the carafe sits on, there are two thermal fuses that are inside tubes that are clamped to the heating element with spring clamps.
Remove the bottom of the unit (5 screws), unclamp the thermal fuse tubes, slide the tubes to one side and check the each fuse with an ohmmeter. If one of them is open, that's your problem.
Aug 30, 2008 | Gevalia CM-500 12 Cup Coffee Maker
WG1130D
if not heating, will stick in cycle.
remove connections from element and check for continuity with a multimeter
Jul 11, 2008 | Indesit W 123 Front Load Washer
Bosch 24 in SHU66C05UC/14
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Jul 08, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Help anyone. Machine will only start for the first minute
F/05 Water Temperature Sensor Error If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed. Check the Water Temperature Sensor, Heating Element and Element Relay Check connections to the Sensor, Heating Element and Relay Hope this is helpful.
Sep 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire FPHD2491KF Dishwasher Logo
106 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
