Question about Garden
Why my walker mower smoke to much - Garden
Walker mower pulls to the right
If this is a self propelling mower, check the inner wheel gear patterns for wear. Remove each wheel, only the ones that are self propelling. On the inside of each you will see the jagged pattern that rides on the mowers propelling gear, the plastic eventually wears out causing one to catch better than the other hence you will get pulling on either side.
Nov 20, 2015 | Garden
Walker mower pulls to right
After running my Walker mower for about an hour,the beeper goes on & the clock reads ''lube''
Grab your grease gun and start looking for zerk fittings you may have missed when you greased your machine last. You will probably find a few you didn't know about. GOOD LUCK FRIEND.
Apr 25, 2010 | Blade WALKER LAWN MOWER DECK HUB BLADE...
I have a 26 hp efi walker mower and the problem I am experencing is that the mower engine shuts down when forward movement is activated, mower stays on in reverse, I have 712 engine hrs and have just...
Sorry about this problem but i would suggest that you flush oil and get new oil into it. Please do this and your problem would be solved.
Regards
Sep 12, 2009 | Mtd Garden
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
