Question about American Standard Heating & Cooling
Standard reset I have an American standard heritage 15. The fan comes on, but still not getting cold air in the house.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
You are out of freon or the thermostat is broken sounds like
Posted on Mar 30, 2014
  • 13 Answers
SOURCE: No cold air coming from the registers.
If your compressor is running outside (low hum noise) then your probably need freon .If the compressor is not running could be a bad cap or bad compressor
Posted on May 22, 2009
  • 4 Answers
SOURCE: Looking for reset button on compressor
Sorry no easy answer if any of the safety switches tripped you have major problems. If your fan is coming on when switched to fan on then your problem migth be outside in the condenser. Check your power and breakers going to the condenser.
Posted on Jun 20, 2009
SOURCE: Air Conditioner isn't making the house cold at all
My AC works great, cold air coming out of the vent (about 63*) intake working well also. (about 76* in the middle of the day)
Think it could be the insulation?
Posted on Jun 22, 2009
daddyo742001
  • 70 Answers
SOURCE: American Standard blower will not run
Sounds like motor has failed. If the red light is blinking it may be telling you what is wrong by the number of blinks. It maybe locked out for some reason or loose wire. Try turning off breakers to inside unit for 5 mins and try again, this may reset unit. But it sounds like a bad motor or circut board. Try running with stat in on position instead of auto in cooling mode.
Posted on Jun 28, 2009
garing
  • 998 Answers
SOURCE: air conditioner blows air but dosen't cool house
clean outside fins and check freon level
Posted on Aug 17, 2009
I have American standard heritage 11 heat pump with the coils inside btw it's a double wide I was wondering where the fuse might be located
There will be a box that the unit gets power from, either up on the roof or on the side of the home, the fuse or circuit breaker will be in there.
Jul 18, 2016 | American Standard Heating & Cooling
I have and american standard ac and it is blowing air inside the house but the compressor is not coming on
I just fixed my own AC that was doing the same thing, by replacing the start capacitor. It cost less than $13 and I was able to change it myself in less than 10 minutes (I am a 56 year old woman)! I searched You Tube videos and watched a number of them to give me the confidence to do it and it worked.
Sep 02, 2014 | Heating & Cooling
American standard heritage 12
Do you have 3 or 4 wires coming from the Motor?
Dec 12, 2012 | American Standard Heating & Cooling
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
My heritage 14 unit has stopped running.we had the thermostat set at 69 and came home to find that it had stopped running.
Is the indoor fan running? check the breakers and reset as needed. also check the tstat . you should find a disconnect next to the outdoor unit some have fuses and some just are a copper bar device . If it has fuses check them .. if not you may have fried the transformer or the capisitor has failed. You will need equipment to check it let me know if this helps Jon
Aug 07, 2011 | American Standard WCZ036F Air Conditioner
Where is the reset button
If you turn the power off and wait a few minutes some
units will reset on their own. If not turn your fan from auto to on if the blower comes on that is good news.
The only reset on the ac side of is the compressor overload and the high pressure cutout which you need to be able to get to the compressor find the
refrigerant lines and push it in.
Jun 30, 2010 | American Standard WCZ036F Air Conditioner
NOT a problem--preventive maintenance is my goal. I kept my Payne heat pump (installed in 1985) humming nicely until this January. I only replaced it because of cost/efficiency issues ($$$) every summer....
By code, whoeve installed this brand new unit should
have left the manual with it. Check the electrical
control box or the fan compartment to see if a manual
is not in there
Feb 13, 2010 | American Standard WCZ036F Air Conditioner
American standard thru-wall heater air conditioner (PTEC1501GAA) will not heat. When wall mounted thermostat is turned up for heat, the fan turns on but no heat comes out. I opened it up and checked the...
sounds as if the heater coil itself is burnt out. These coils may be repaired if you can get an universial coil repair kit and rewire the heater coil yourself. Since the age of the unit is in question I don't know if it is possible to get a kit for repairs but you never know. I would check an a/c supply house for this kit. Good Luck on your repairs
Dave
Nov 03, 2009 | Carrier 52PQ307 Wall/Window Air...
Heating & Cooling Logo
210 people viewed this question
Top American Standard Heating & Cooling Experts
Craig Butler
Craig Butler
Tim Whalen
Mack Baxter
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
