Question about Little Giant 360 Pony Pump Series Non-Submersible Self-Priming Transfer Pumps
Makes a buzzing noise but pumps no water
My pony pump has suddenly stopped pumping, should I open it up and see? what am I looking for? Full rain barrels and no pump :-( Thanks! SJ
  • Brad Brown Jul 18, 2013
    The screws on the front of the unit where the hoses attach are what you remove. Then the front plate comes off and you can see the parts that move. The repair parts are here but you should see if the turn by hand first. The unit is only designed to work 15 minutes an hour.http://www.little-giantpump.com/555103_p...
  • Sraj Jul 19, 2013
    Thank you sooo much, yes the part inside was broken. I can turn the shaft by hand. So if I get the replacement part and replace it hoopefully it should work. Fingers crossed. Thanks again Brad
  • Little Giant Master
  • 15,645 Answers
You need to take it out and see if the impellor is stuck or if the motor is stalled.
Posted on Jul 18, 2013
  • Sraj Jul 18, 2013
    Silly I know... but I have no idea how to open it. It looks like one sealed unit. I have taken a couple of screws out but the body of the pump looks sealed.
I have an old solid fuel fire with a back boiler behind it...the pump is making a buzzing noise....some radiators hot some not...please help
Tell us more: What is the Solid Fuel?-- Coal?-- Wood? Is this a Steam boiler?- or a Hot water boiler?-- It sounds like Hot water, for you mention a pump-- Perhaps it is a Hot Water Circulation pump?
Does the Boiler have a sight glass?-- What is the water level?
Tell us more, so we can help you figure things out.
Mack B.
Oct 13, 2013 | Bosch & Power Vent Water Heater
Tank full of hot water,faucets deliver only cold,water trickels into tank with rapid intermittend pump action
1) Copy following link:
http://waterheatertimer.org/Crossover.html
2) Add comment with clear description of water heater, fuel type, and pump?
Is this a pump problem or water heater problem?
Is this a water well pump?
Are you getting good stream of cold water at tap?
Which water heater do you have?
Is the heater new?
Or older heater that stopped working.
Dec 27, 2012 | Atwood 10 Gallon Gas/Electric Water Heater...
Laing model 330 Pump not working-delay in hot water delivery.In the past,a vibration occurred when cold water running above the pump.Can this be repaired.Power operating to pump. Thanks, mel ross
Question not 100% clear.
1) The pump is not working? Does the pump make a noise? if pump is not working full-time, it can cause delay in arrival.
If pump motor is suspect, and outlet has power, then check override switch located on timer. Set override to Timer, move some of the trippers outward, then manually rotate timer dial until pump turns ON.
http://waterheatertimer.org/images/IMG_9325-grundfos-timer-800.jpg
If no noise is detected, or noise stops and starts, or seems strained, or if pump is hot, then pump motor may have burned out.
2) If pump is working, and makes noise like a humming sound, and pump motor is not hot, but hot water is not circulating, then unplug pump so it will not overheat and burn up.
Disassemble the pump and cross-over piece. Clean piping with white vinegar or CLR. Do not soak in CLR or it will damage seals. Rinse parts thoroughly. Reassemble and see if problem is resolved.
If pump is vibrating, then suspects include sediment and/or air inside line, and this can be resolved by cleaning as described. Also install air vent to increase life of pump.
3) Other causes for hot water delay at faucet are crossover.
Crossover can be caused by bad single-handled faucet cartridge, and/or by clogged-or-failed check valve on cross-over piece on grundfos.
This type of problem lets cold water enter hot line, and causes delay in arrival of hot water. Clean-or-replace the grundfos cross-over piece, and replace bad faucet cartridge.
Open following link for testing instructions:
Resources:
http://waterheatertimer.org/Water-heater-recirculation-system.html
http://waterheatertimer.org/pdf/Troubleshoot-recirculation.pdf
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 17, 2011 | Laing Thermotech Autocirc Undersink...
Resources:
The pressure tank psi may be too high. To set it you get the system to pressure up and stop then check that water pressure. Whatever that is, is what the tank should be set at. Too much air pressure and the water pressure will suddenly drop before the pump kicks in.
To set the tank properly turn off the pump, drain all water pressure, then set the air pressure in the tank to the same as the water pressure was. Turn it back on and check again.
Apr 14, 2017 | Water Heaters
Code LC, I cleaned the filter, won't stop beeping
you need to flush out the rinnai. to do this you will need 4 gallons of white viniger & a circulating pump. #1 disconnect the power. #2 close both incoming & outgoing water valves under the unit. #3 conect a drain hose to the out going flush valve ( flush valves are under the unit & have brass caps) #4 connect pump outlet hose to ingoing flush valve. #5 put pump incoming hose & drain hose from outgoing flush valve in a 5 gallon bucket. #6 pour 4 gallons of vinager into the bucket. #7 open both flush valves. #8 turn on the circulating pump & let viniger pump in the incoming flush valve through the rinnai & out the outgoing flush valve back into the bucket for 45 min. #9 disconct pump from incoming side & close incoming flush valve.( don,t close outgoing vaves at this time) #10 put out going hose in empty bucket. #11 open incoming water to flush viniger out of unit. # 12 disconct outgoing hose , close outgoing flush valve & open outgoing water valve. #13 clean filter & turn on power.
Jul 08, 2009 | Rinnai Water Heaters
Takagi TK-JR vibrating noise
Remove your hydronic pump and replace the flexible impeller coupling that couples the impeller blades to the pump motor. make sure you don't do this on a sat or, sunday (i hate house calls then) and, be sure you have a new pump housing gasket before you start the job. Also check the unit for loose pipe brackets
May 20, 2009 | RTO Takagi Jr. TK-JR-N Tankless Water...
Amtrol Boilermate makes whining noise
I had also this problem before, same with buzzing sounds on my Amtrol Boilermate and all I had to do was to call the local dealer and they have got it fixed.
May 05, 2009 | Emerson Part UWL Chrome Ultrasystem water...
Humming noise with my beckett burner
the beat i can do on this is an educated guess , it would be the pump or the pump motor bearings , but having said that i have also seen these make noise for years and not go out ,I have worked on oil burner about 35 years experience has taught me not to guess parts , so the advise i would give is to find the part and model numbers for the motor on the pump assembly and the pump try to find availability in your area , heating and cooling, hardware store ECT. and wait to see if becomes more defined or fails so you don't spend a fortune on parts you don't need ,**** make sure there are no oil ports on the pump motor bearings 9LITTLE OIL CAPS ECT OR PLASTIC PLUGS YOU CAN REMOVE TO OIL ) IF THERE IS PUT A COUPLE DROPS OF 3 IN 1 OIL AND SEE IF IT HELPS .
Feb 01, 2009 | Water Heaters
Little Giant 360 Pony Pump Series Non-Submersible Self-Priming Transfer Pumps Logo
87 people viewed this question
Top Little Giant Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Little Giant Water Heater Expert? Answer questions, earn points and help others
