Model no. BAR338PA
Changed batteries an can't get the unit to reset and give a display
    Top Expert:
  • Audio Player... Master
  • 34,725 Answers
The replacement batteries may be no good or installed incorrectly
Posted on Jul 10, 2013
Froze on garmin screen won't give directions
Could be a battery problem not having enough charge to get past the Garmin screen you might need to replace the battery or it might need to be reset.
Not knowing which model of Garmin it is makes it hard to provide a correct solution. ?
If your Garmin Nuvi 1300 is freezing up or not working correctly, a soft reset can be performed. A soft reset unfreezes the unit and brings you back to the main menu. If a soft reset does not solve the problem, or if you are selling your unit and wish to erase all of your saved information, a hard reset can be done. A hard reset restores the original factory settings to the unit. Once the information is deleted, it can not be restored. Turn on the Garmin Nuvi 1300. Press and hold down the "Power" button. Release the button when the main menu is displayed. The unit is now ready to be used. b> Hard Reset b> Turn the Garmin Nuvi 1300 off. Press your finger against the bottom-right corner of the Garmin display screen. Leave your finger in place as you power the unit on. Release your finger when the display screen asks, "Do you want to erase all user data?" Use your finger to tap "Yes." The unit will begin to reboot. Do not use the unit until the main menu is displayed. The reset process should take about 45 seconds. Hope this helps.
http://www.youtube.com/watch?v=xjUSGY7KVAk How to Replace Your Garmin Nuvi 255 Battery
Jan 04, 2013 | GPS
Changed the batteries on a White-Rodgers 1F86-444 and the battery display does not go off. Is there a reset button?
Thank you for yourinterest with Emerson White- Rodger's. My name is Joselito Laxamana from technical department. After changing the battery reset the unit by pressing , UP and DOWN move the SYSTEM switch from
OFF to HEAT at the same time. If you have difficulty doing this you can contact us directly at 18002842925.
Jul 25, 2012 | Home Security
I have an old Casio watch 863 SDB-500W, I have just change the battery . Light is working but nothing is display. How to reset it ?
To reset the watch, you need to 'short' the reset point with the battery. To do this, with the watch face down and the back removed the 'Reset' point is in the bottom right hand corner (a gold-coloured contact point). Use a pair of metal tweezers or an unbent paper-clip (anything as long as it's metal and will touch the reset point and the back of the battery at the same time). Maintain contact for about 5 seconds and you should get the display back.
I've just changed the battery in my SDB 500W and the above method worked. I did lose the audible 'beep' though and I'm currently on the net trying to find how to get it back. That's how I found your question... :)
Jul 24, 2011 | Bulova Watch
Model RAR188A Tried to change battery on remote sensor. Still doesn't work. I think I have to reset it but can't remember how.
Both the remote and base units have a very small hole near the battery spot, less than 1/8" in diameter. Push something smaller than the hole into it, like the end of an unbent paper clip. The base unit, at least, will give a tiny beep and it will have reset. The remote may not beep, but also will be reset.
Jun 16, 2011 | Oregon Scientific Wireless IndoorOutdoor...
My panasonic dvd/vcr combo displays the message DV D 2 in the display. Cnnot play DVD
Sounds like your remote code is different to what's in the unit's display (DVD 2). You can try to 'reset' the remote, by pressing (and holding) 2 and ENTER/OK buttons together for 5 - 10 seconds, then release. This should restore your remote function back to your unit. If it does not, replace the batteries with new ones, and try again.
The remote may require a 'reset' of its command mode (to match the unit) whenever the batteries are replaced.
I assume you can play DVD by pressing the PLAY button on the main unit.
Apr 28, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
When I changed the batteries, I am no longer able to get the display in English--it comes up in Spanish. There is no obvious button to change it. Thanks for your help.
The problem is not from the battery you changed. It should be from the sim card you changed. The phone's language is set to automatic, therefore it reads sim card languages automatically. To rectify this, since you do not understand spanish:
Option 1
-Put back the english sim then go to settings, and set your default language to English only
Option 2
-Send me your phone name and model so I can give you a reset code
THANKS. HOPE THIS HELPED.
Apr 23, 2011 | Cell Phones
My indoor outdoor thermometer is only displaying the inside temperature and I lost the manual and can't remember how to reset it?
often removing the batteries in both units will reset. replace batteries in indoor unit firs, let it settle down then insert batteries into outdoor unit. There may be a button on outdoor unit to initialise the connection.
Alternatively you might find the manual here or get the instructions from their support.
http://www.orbyxelectronics.com/manuals.asp?choice1=3&choice2=14&hidPickIndex=2
Nov 04, 2009 | NexxTech (NOMR)
Changing the time
you can go to http://www2.oregonscientific.com/assets/manuals2/bar338pa.pdf to see or print the user's manual.
If you don't want to get the manual, here's what you do to fix it. . . . .
*note: you need to do this anytime you change the batteries.
1) open the battery cover
2) on the left side you'll see 3 little buttons labeled a)zone, b)C/F c)reset
3) push the reset
4)push the zone button until your time zone is highlighted on the front display
5) look at the front display & if you see a blinking "radio signal" icon at upper left of time numerals
don't do anything else. The time, date, etc. will automatically synchronize your clock with the US Atomic Clock. This could take up to 10 minutes. As long as the "radio signal" icon is blinking, it's working on it. When the icon doesnt' blink, it's set. Cool, huh?
6) if the area you live in can't receive the signal from the Atomic Clock, instead of a blinking "radio signal", you'll see just a bare antennae. Since you probably set your clock manually, that's what it shows now before you do anything.
7) after you push reset & set the time zone do NOT touch any other buttons to set anything!!! (I know it's difficult to leave things alone, but just sit on your hands). Pushing the "clock" button or the up & down arrows will stop the radio signal & change to manual functions. Look at the signal icon mentioned in 5) and 6) above. If you only have the bare antennae icon. . . . . go ahead & set the time/date yourself. You have no signal.
Enjoy your clock!
debkresh
Jan 25, 2009 | Oregon Scientific FM Weather Projection...
Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in.  Unfortunately this also messed up the clock's time and date.  This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
Dec 30, 2008 | Oregon Scientific Lwb0997110113004...
26 people viewed this question
 Grubhead
Grubhead
