Flying insect
This fying insect has 6 legs , a body about 1" in length,2 transparent wings . antennae and a tail about 2 and 1/2 " long . It was found on a window of a building near the water . The body is black with some yellow . It flew very fast when released
    Champion:
  • 247 Answers
Its called a dragon fly
Posted on Jul 11, 2013
When we replaced our shingles we fouund under the shingles lots of round dics about 1 1/2 inch in diameter,with cotton like texture contained brown eggs an insect had laid.
It sounds that most likely it's a type of insect that makes and any insect that makes it cool cocoon will fly perhaps it is termite with wings
Mar 13, 2018 | Cars & Trucks
What insect is eating My Hibiscus Leaves
They can be 1. Japanese Beetles 2. Mealybugs 3. Saw flies 4. Thrips 5. Aphids 6. White flies 7. Spider mites
Jul 14, 2017 | Garden
How do I get rid of clusters of transparent wing insects that gather in Summer on the growing tips of the figs , as well as the passion fruit at Tamborine mountain?
Cover your tree in a fine net when the figs start to form after blooming. I know wasps like to lay their eggs in them, and those fruit usually fall off. Probably the same with the passion fruit.
Dec 01, 2014 | Ortho Home Defense Max Insect Killer 133...
Ir helicopter only upper wing spinning
Have a SATURN-X 2CH IR and the tail and the tail rotor will not spin? What can I do?
Dec 30, 2012 | Worldtech Devices World Tech 85618 2CH...
My 9053 lifts off fine goes left right and reverse. but it goes reverse also when i want to go forward . Tail rotor turns at what appears proper rpm. and it changes direction when i push stick from reverse...
I own this heli also. The problem is that the tail rotor does not apply enough push to tilt the heli forward. It is this forward pitch that moves the heli forward. Aside form buying a stronger tail motor, upgrading your battery etc, the only thing you can do id this:
Get a credit card, a pair of scissors and some tape. Cut a couple of strips from the credit card about 2 1/2 - 3 times wider thhan the tail rotor blades and the same length. Now tape the strips to the top of the tail rotor blades. Make sure you don't increase the length.
This will help a little by providing more air push when the tail rotor in engaged. Without some serious modding, this heli will never be great.
I have more fun flying my micro size syma helicopter in the garage then I have flying my volitation. If there is even the slightest breeze, the volitation will float in the direction of the breeze and will not fly against it.
Apr 03, 2011 | xheli 9053 Outdoor Volitation Metal...
Have hobbyzone firebird commander 2, new to flying. Could not get it off the ground, kept veering to right - and my friend's new, same plane, also did the same, yet veered to the left. Help
Some RTF aircraft are not quite RTF as they sometimes need trim adjustments. Also, a wing could be heavier on one side than the other as RTF models are mass produced with cheap and cheaply assembled components.
For a quick balance check, remove the prop and obtain an electrical terminal block (aka Chocolate block). You will need just the brass terminal insert with both screws.
Remove the prop and put the terminal onto the prop spindle. On the other open end of this, you need to insert a small curtain hook (ones that are used to hold up net curtain wires). Insert this into the other end. To the hook, tie a short length of nylon or cotton. Suspend the cotton from a platform such as a shelf. You need to be able to hang the aircraft without it touching the wall but it needs to be close to the wall. Once done, obtain a tape rule and measure the leading edge END of the wing. Move the tape to the other wing and make sure that the same position aligns with the same mark on the rule. If it doesn't, you need to add a minute amount of weight. About a gram, to the higher wing.
If it is fine, then remove the cotton and then tie a loop into it. Make another cotton string loop identical and hang it one plane length away. Using a small piece of sticky tape, tape the cotton to the tape and then to the extreme top of the tail fin. Loop the other cotton loop over the prop spindle, making in effect a cradle system. Again, use a tape rule to ensure that the both wings sit at exactly the same height. Add a piece of tape to the lighter wing to level it. A better way is to use nail varnish as it levels itself and prevents wing surface issues.
If both wings are okay, then it may be the tail fin rudder. It could be stuck on the right side rather than in the middle. This makes the aircraft fly to the right the faster the speed is, even taking off. Try trimming the rudder with the trim control on the transmitter or servo link.
If all else fails....buy a model boat as it could be the operator....
Feb 13, 2011 | Hobby Zone Firebird Commander 2 RTF...
Open Questions:
Televison & Video Logo
361 people viewed this question
Top Televison & Video Experts
