Question about Garden
Bad boy mower
I have an 08 zt bad boy mower with a vanguard Briggs and Stratton motor and I'm haveing problems keeping it running First I was cutting and it started spitting a sputtering then it died ....so I called bad boy and they said replace fuel filter so I did and mowed once Then I go to crank it and it runs for about a minute and dies I called bad boy and they say drain fuel and start fresh so I do and I ad fresh gas and crank it and now it runs at idle and will not idle up.......please help my grass is getting tall fast
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
Sounds like dirty carb get a rekit clean and boil the carb what i mean by boil go to auto store buy strong carb cleaner put the strip carb in it for two days take it out using compressed air we use 300 lbs blow every hole out in that carb if yu see tiny holes take a wire and poke the blow them out again put back to gether with other parts you boiled like the jet and down spout turn adjust ment screw out 4 turns that should get it started the run and adjust from there should run fine main thing dirty carb problem
Posted on Jun 07, 2014
Benimur
  • 6966 Answers
SOURCE: hard starting and poor running
Try running the engine without the filter and check if the idle would smoothen, maybe a little high. If problem persist, then it would be fuel delivery problem. If the idle is constant (but high), then some sort of blockage on the air filter or a vacuum leak.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 10, 2008
  • 84 Answers
SOURCE: have a craftsman model :917.273621,
try the coil. the coil will produce the spark for the spark plug seeing as there is no battery, try replacing it with another of the same power.
Posted on Jun 24, 2009
  • 41 Answers
SOURCE: Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Posted on Aug 04, 2009
bbreton
  • 437 Answers
SOURCE: Gas Push Mower - Briggs & Stratton, will start but run for
The jet in the bottom of the carburetor is clogged up. The engine will prime but after that fuel is burned off, the engine stops. The jet is not allowing fuel to be sucked into the engine.
Posted on Sep 30, 2009
  • 7 Answers
SOURCE: Engine starts and runs fine, then dies.
My 5hp B-S is doing the same thing and found a post that seems to be the best answer. Replace the float. It runs out of gas if the float is not working properly.
Another cause may be the diaphram, maybe.
Mine is 12 yrs old so I plan on getting the whole carb rebuild kit
while I have it apart
Good Luck
Posted on May 19, 2010
Where is oil filter on 13.5 briggs
Briggs & Stratton Riding Lawn Mower Engine Oil Filter #696854 ...
? 2:05
https://www.youtube.com/watch?v=QjYmbfGU0qg
Aug 22, 2014 - Uploaded by RepairClinic.com
This video provides step-by-step repair instructions for replacing the oil filter on a Briggs and Stratton small ...
Oil Change- Briggs & Stratton 12.5hp Mower - YouTube
? 5:05
https://www.youtube.com/watch?v=udjoD-mW5ig Aug 15, 2012 - Uploaded by Alex's Bikes and Motors
Oil Change- Briggs & Stratton 12.5hp Mower. Alex's Bikes and ... This is going to sound weird, but I can't ...
Oil Filter 492932S - Briggs & Stratton Parts
https://shop.briggsandstratton.com/us/en/parts-and.../oil-and-oil.../oil-filter-492932s Briggs & Stratton oil filters are engineered to keep your Intek, Vanguard OHV and twin cylinder engine running smooth. Save on costly repairs -- order genuine parts today!
oil filter on 13 5 briggs Google Search
Mar 12, 2018 | Briggs Garden
Crankshaft pulley bolt keeps dropping out no matter how hard I reinstall it. Any idea? Countax A20-50 and its a Vanguard 20hp twin. Thanks!
Does that motor vibrate badly? The crankshaft may have gotten bent. If it vibrates VERY badly, it may be nearly impossible to keep that bolt tightened. Your best bet may be to try some (REMOVABLE) Loctite (like Loctite Blue 242) on the bolt threads. It's expensive, but it's well suited for situations just like this.
Aug 03, 2014 | Briggs & Stratton Garden
16hp horz vanguard, only starts with pull start,when running the lights won't work......
have a load test done on the battery as it appears to fail when the current draw is high as in starting taking the current needed to run the ignition syatem
Mar 16, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton Modle# 100000 will not stay started.
your engine is only running on the fuel you are pumping in, the carb. is not lifting the fuel on its own, maybe because of water in the bowl or dirty jets. You must take the bowl of and clean it out and depending on the type of carb. it might need a new diaphragm. Stephen.
Apr 25, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Engine smokes and looses power
Check the air filter, replace.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 26, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Oil in air breather
sounds like you have too much oil in the engine (should normally be around 500-600ml when there is too much oil, it gets past the piston rings and pushes it through to the head.
May 20, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
520 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
