Question about RCA Cc275 Vhs Handheld Digital 12-72mm Video Camcorder Solid State Image Sensor
How much is my used rca solid state vhs camcorder model number cc275 worth now
Trying to find the value of my camcorder and how much I can get for it if I pawn it
5 Suggested Answers
SOURCE: RCA CC617
Had the same problem took mine apart and found the ribbon cable going to the viewer was cracked and broken probably because of the flexing of the cable during adjustments. Not fixed yet.
Posted on Oct 17, 2008
  • 4234 Answers
SOURCE: RCA VHS CAMCORDER
Let us attack this from a different perspective. What is the problem with the camcorder? Typical labor rates will be in the $150 range, so you are looking at that much for the repair without parts. Please update this with a problem description and I'll try to provide you with what needs to be done to fix it.
Thanks,
Dan
Posted on Dec 08, 2008
techman007
  • 1112 Answers
SOURCE: camcorder won't record
Check the tape and make sure the record tab is still on the tape and has not been removed. If the record tab has been removed then use a new tape for recording as the unit will not record. This tap is usually on the lower left end of the back of the tape. When the tap is present it closes a record mode switch letting the system know the tape is able to bv recorded on..
Posted on Dec 27, 2009
  • 44 Answers
SOURCE: Need Manual for RCA VHS Camcorder Model No. CC 285
TRY THIS .GOOGLE Manual for RCA VHS Camcorder Model No. CC 285
MAY NEED A BIT OF SEARHING
IF YOU FIND A PDF VERSION,DOWNLOAD IT,AND BURN TO DISC
KEEP IT SAFE RUN IT ON COMPUTER OR PRINT IT OFF
Posted on Feb 15, 2010
My cc275 vhs rca comcoder on camera will not focus are stay on rec for 2 second
I understand you have a problem. What is not clear from your description, however, is the actual nature of the problem. Please can you state it more clearly. Thank you.
Jun 15, 2017 | RCA Video Cameras
Progressive Scan
Try these steps:
Locate the output jacks DVD player. Sometimes they are standard female RCA A/V jacks, like those found on the front of many VCRs. Others are more tricky, having a small jack that looks like a stereo headphones plug. These camcorders require a special cord that converts a 1/8" stereo signal into RCA A/V male plugs.
  1. Using the proper cord, connect your PLAYER to the VCR's RCA A/V input jacks, usually found on the front or back of your VCR.
  2. Turn on your VCR and TV, so you can see the input from the camcorder. You might have to select "Input 1/2", "Line 1/2", or "VIDEO" depending on your VCR model. You should now see whatever is on your camcorder displayed on your television.
  3. Press "Record" on your VCR, then press "Play" on your camcorder. That's it!
Sep 07, 2008 | Samsung DVD-VR357
What kind of charger do I need for RCA autoshot 72x camcorder
suggest you contact the manufacturer thru their website customer support
Apr 10, 2015 | RCA Video Cameras
How do I connect my panasonic vhs 188 camcorder to a dvd recorder?
On these old models of VHS camcorder, I recall they have either RCA outputs, or BNC connectors which will require a BNC adaptor (to convert to RCA).
Using a 3RCA lead, connect the camcorder to the video (and audio) inputs of your DVD recorder.
Sep 19, 2011 | Panasonic AG-188 Camcorder
Feb 15, 2010 | RCA Video Cameras
RCA VHS CAMCORDER
Thanks,
Dan
Dec 08, 2008 | RCA Video Cameras
I have a RCA Solid State VHS Camcorder that was made about 1988, I think, with a model number of 934.53742850. Whenever I put a tape in, it has trouble winding the tape around the head so it can record or...
The takeup spool is not working properly and when this happens the machine will do exactly as you described and shut down. The belt that powers it may be slipping. Usually clutch driven.
Sep 21, 2017 | Video Cameras
Need the battery
Have you tried Batteries Plus near you or go online to www.batteriesplus.com
they list both the batteries and the chargers for this model of camcorder
Nov 18, 2008 | RCA CC6254 VHS-C Analog Camcorder
RCA CC617
probably the lcd screen is broken (the one that you can see through the veiw finder) if this is the case it is not reasonably fixable. Otherwise it may be a connection that is broken and it is not getting any feed. If you give it a little tap and it comes to life breifly, this is probably the case. You can take it to a small electronics repair shop and they will let you know if its worth fixing or just using as is.
Jul 08, 2007 | RCA CC617 VHS-C Analog Camcorder
RCA Cc275 Vhs Handheld Digital 12-72mm Video Camcorder Solid State Image Sensor Logo
109 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
