Question about Garden
My detergent tank is cracked and when it took if off it broke into pieces
  • 53 Answers
Look in the manual for the part number of the tank. Then order a replacement.
Posted on Jul 10, 2013
2 Suggested Answers
  • 109 Answers
SOURCE: My detergent tank was cracked and when I took it off, it broke into several pieces
So get a new one or make something work
How do you replace a 2005 pontiac vibe charcoal canister
Can't tell you where yours is exactly. But two spots that is most likely at. Under the car on the driver side, right behind the front tire mounted to the frame. Or on top of the fuel tank, You can see it, but have to drop the tank to get it out. I have never replaced one though. Fix them always. If the box is crack, I get a piece of plastic and silicone it on, over the crack. If the nipple broke off, I use a piece of copper tube, just a bigger than the hole. Heat it up, hot. Use pliers. Then insert it to the box and push the nipple on it at the same time. Do this quickly. Then smear silicone around the crack. keep the silicone close or you won't be able to get the hose connected back on.
Jul 27, 2015 | 2005 Pontiac Vibe
Coolant Resevoir Tank Leak
A repair might buy a little time but you should replace.Either the junk yard or dealer will have this part.it is a coolant resevoir.
Aug 28, 2012 | 2002 Chrysler Sebring
My Hoover steam vac dual v clean water and detergent tank leaks water before attached to the vac and during cleaning
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
May 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
The EGR vale is new, it it is rough idoling or driving..i drive about 104 miles a day..it use about 1/4 tank gas per trip. (new plugs) they are fowled out .. i pulled the wires one ata time no change in...
SCAN IT TO SEE IF YOU HAVE MAP SENSOR WORKING.ALSO CHECK VACUUM LINES GOING TO MAP SENSOR MAKE SURE ITS NOT. BROKE OR CRACK.CHECK COILS RESISTANCE.BAD COILS CAUSE ROUGH IDLING.SCAN MAKE SURE COOLANT SENSOR ISNT OPEN.REMOVE EGR VALVE. CLEAN OUT CARBON IN THE INTAKE PORT.USING A PIECE OF CLOTHES RACK.CLEAN UP DEBRIS.ALSO CHECK FUEL PRESSURE REGULATOR.CHECK VACUUM LINE TO FUEL PRESSURE MAKE SURE ITS NOT FULL OF GAS.AND DONT HAVE CRACKS IN IT OR BROKE.
Jun 06, 2009 | 1994 GMC Sierra
Can I get a new clean water tank for my Hoover? After filling tank, as soon as I lock it in water poors out even before I can start cleaning carpet.
Take the clean water tank off, and look at the underside very carefully. This tank is made of a very thin plastic, and chances are, your tank is cracked or broken. Sometimes the valves fail as well.
There is a new tank available, a single-piece tank instead of separate water and detergent reservoirs. The part number you want to look for is 42272104. The new tank does NOT come with a handle, so save your handle and use it on the new one.
Search for this new part number online and find the best price. I have seen them for around $40.
May 17, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
My affinity washer (front load ATF6000ES) is leaking detergent
are you using he detergent?. if what you see on floor is pure detergent then look at dispenser housing for cracks. remove drawer, open, depress lever in back and pull out, to see inside housing. If the screw or mounting for the loose paddle (baffle) broke and slammed housing in some way then you would also have a hole in the tub. You can easily remove top, 3 screws in back to check this. If tub is broke, buy new machine!
baffles are usually attached with screws from outside basket, requiring removal from tub
Mar 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
My steamvac f5870-900 trigger mechanism isn't working
Here is a picture, maybe that will help:
Dec 01, 2007 | Vacuums
Tank Dispensing
Is the detergent tank cracked at the bottom, under the black seal? If so the whole tank asm. needs to be replaced. But if this is new, then it has a one years warranty on it and you can take in for warranty repair.
Oct 13, 2007 | Hoover F7222-900 SteamVac Upright Vacuum
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
