Question about Garden
My detergent tank was cracked and when I took it off, it broke into several pieces
  • 109 Answers
So get a new one or make something work
Posted on Jul 10, 2013
How do you replace a 2005 pontiac vibe charcoal canister
Can't tell you where yours is exactly. But two spots that is most likely at. Under the car on the driver side, right behind the front tire mounted to the frame. Or on top of the fuel tank, You can see it, but have to drop the tank to get it out. I have never replaced one though. Fix them always. If the box is crack, I get a piece of plastic and silicone it on, over the crack. If the nipple broke off, I use a piece of copper tube, just a bigger than the hole. Heat it up, hot. Use pliers. Then insert it to the box and push the nipple on it at the same time. Do this quickly. Then smear silicone around the crack. keep the silicone close or you won't be able to get the hose connected back on.
Jul 27, 2015 | 2005 Pontiac Vibe
How do you remove the lower handle?
Check the clean water holding tank. I had this problem and found that was a crack near the outlet on the bottom of the tank. I replaced the tank and resolved the problem. I have taken this machine apart several times, if the tank is not the problem with yours, check the water tube.
Apr 26, 2015 | Hoover F7425-900 SteamVac V2 Widepath...
My detergent tank is cracked and when it took if off it broke into pieces
Look in the manual for the part number of the tank. Then order a replacement.
Jul 10, 2013 | Garden
Can you fix the top rim of a 72 g bow front if the middle piece is broken?
if its only the top black plastic piece sure you can , id use superglue and let dry (hours not minutes) and wash it several times with water to clean residue off , (NO fish in tank or water ) if crack is to the top of actual tank < its possible with aquarium silicone but I wouldn't chance it id replace it
Mar 20, 2013 | Aqueon All Glass Aquarium Co. 72 Gallon...
Coolant Resevoir Tank Leak
A repair might buy a little time but you should replace.Either the junk yard or dealer will have this part.it is a coolant resevoir.
Aug 28, 2012 | 2002 Chrysler Sebring
My Hoover steam vac dual v clean water and detergent tank leaks water before attached to the vac and during cleaning
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
May 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
The smart soap dispenser on my GE profile dishwasher is not dispensing soap. I filled the smart dispenser several months ago and it does not appear that any of the soap was dispensed. how do i resolve?...
We mistakenly switched liquid detergents and mixed enzyme based and bleach based. They gelled in the dispenser. I took the outer door cover off and could not figure out how to take the white plastic despenser off of the main door without breaking it. I disconected the electrical harness and took the main door off the hinges so I could take it outside, turn it upside down and use the garden hose pressure nozzle to blast the gellout of the white plastic dispenser. I use a piece of plastic coat hanger to poke around inside to break up the gell several times. It all came out in marble size pieces.
Aug 17, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Crack and hole in the screen...
There are several parts distributors in the US that supply parts for Hitachi TV's You can try Herman Electronics, Tritronics and PAC parts, all have websites. Be prepared for the cost: a new screen will be in the $300-$400 range. It's not just a piece of ordinary plastic; it's actually two pieces of specially designed plastic designed to disperse the light evenly, called a lenticular and a fresnel.
Oct 31, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Can I get a new clean water tank for my Hoover? After filling tank, as soon as I lock it in water poors out even before I can start cleaning carpet.
Take the clean water tank off, and look at the underside very carefully. This tank is made of a very thin plastic, and chances are, your tank is cracked or broken. Sometimes the valves fail as well.
There is a new tank available, a single-piece tank instead of separate water and detergent reservoirs. The part number you want to look for is 42272104. The new tank does NOT come with a handle, so save your handle and use it on the new one.
Search for this new part number online and find the best price. I have seen them for around $40.
May 17, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
