Question about Vehicle Parts & Accessories
I have a 2005 Cadillac STS...... The trunk release use to work....... When I try to open the trunk release on the outside, it doesn't work.... But it work if I unlock from the inside or with my fob...
    New Friend:
  • 53 Answers
It sounds like a bad lock cylinder or a broken cable going from the lock cylinder to the latching mechanism.
Posted on Jul 10, 2013
Trunk fuse 2006 sts
The fuse is located under the rear seat in the fuse box.Trunk/valet fuse.
Feb 04, 2015 | 2006 Cadillac STS
My Cadillac sts 2005 4.6 cruise control doesn't
Cadillac has a cruise control system that becomes disabled when there is a fault in either the suspension, abs, traction control, or engine management system. The car needs to be scanned to find the cause
Apr 21, 2013 | Cars & Trucks
The video explains it self can't open the trunk to my 1999 Cadillac sts with key or real ease button the safety button in the glove box is turned off pls help
TRUNK WILL NOT OPEN
It can be trunk cable issue or the latch issue which gets open/close. It has to be inspected. =========
There are few relatively helps links with solutions to troubleshoot these problems. ---------
I suggest you to go through the links and confirm the issue: ------
Click the link below: ----
Trunk release Problem on Toyota Camry?
http://schematicsdiagram.blogspot.in/2012/02/trunk-release-problem-on-toyota-camry.html
Trunk button Not Working on Buick car?
http://schematicsdiagram.blogspot.com/2011/12/trunk-button-not-working-on-buick-car.html
How to remove Trunk/Hatch Lock on Acura?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-trunkhatch-lock-on-acura.html
How to Remove Trunk Lid on Acura Integra?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-trunk-lid-on-acura.html
2005 Lexus SC430: Retractable hard top will not come down and Trunk will not open?
http://howtobyme.blogspot.in/2012/05/2005-lexus-sc430-retractable-hard-top.html
2000 Toyota Camry: Trunk will not Open?
http://technoanswers.blogspot.in/2012/04/2000-toyota-camry-trunk-will-not-open.html
These will help.
Thanks.
Nov 26, 2012 | Cars & Trucks
I can't get my trunk to open2005 cadillac sts
There is obviously a problem with the trunk release solenoid in the trunk. You will have to do it the "old school" way and use the KEY to get the trunk open. Once you get it open, inspect the wiring conduit that runs between the body and the trunk lid. You will most likely find the problem there where the conduit bends back and forth each time the trunk is opened and closed.
Apr 30, 2012 | Cadillac STS Cars & Trucks
My battery is dead and I have keyless entry and I need to open my car or trunck so i can get a jump... I have a regular key but have no clue to where it goes being that they have no key entry on the...
Hello: On the rear bumper, driver side lower portion you will see a square which you can flip open with the key you have. Once open you will see a lock cylinder, insert the key and turn. That will open the trunk. Inside the trunk you will see a handle, pull it and it will open the drivers door. That should do it.
Nov 01, 2010 | 2005 Cadillac STS
My husband and I have a 1994 Cadillac Seville STS with a trunk release malfunction. We have tried to open the trunk by inserting the key in the lock, but the key will not turn. Until today, we were...
Does the key you have open the driver door? Do you have a keyless entry key fob, does it work? you also might try removing the glove box and disconnecting the wires from the trunk button and touching them together with a paper clip or other small wire but before you do that look in your owners manual a determine which fuse is for the trunk release and check the fuse then the last would be to have GM dealer check to see if the key you have is the proper key fror your car and if it may be worn out
Aug 29, 2010 | 1994 Cadillac Seville
2005 Cadillac STS door problem... Front driver door wont open from outside, seems as if the electronic system isnt responding to release latch when handle is pulled? Anyone have similar problem? All other...
There is NOT a mechanical connection to the outside door handles on the front doors. There is an electronic "door popping solenoid" This is a electronic problem. I think there was a recall on this.
Apr 05, 2009 | 2005 Cadillac STS
Trunk door wont open
somewhere in the truck is a trunk release button on the drivers door , in the center console or in glovebox
Dec 10, 2008 | 2005 Cadillac Escalade
Vehicle Parts & Accessories Logo
111 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
