Question about Samsung SCX 4521F All-In-One Laser Printer
Paper jam copy the one page then its show the massage paper jam 2 check inside
    Problem Solver:
  • 5 Answers
Lkfsdl
fsdfsd
sdfsdf
sdfsdaf
safsdf
Posted on Jul 10, 2013
geemarie
  • 876 Answers
SOURCE: paper jam
turn off the printer
Unplug it
open the paper jam door and gently push the paper roller forward until it clicks.
close the door
wait a few minutes
plug the printer back in
turn it on and see what happens.
I hope this helps.
Posted on Aug 18, 2008
SOURCE: Paper Jam Error 2
Don't try a dozen things suggested by people online who's credentials are unknown. Go straight to the source.
I had the same issue and just went to www.samsung.com - looked up my model #, downloaded the PDF manual 86 pages and did a search for that error. It had step by step picture diagram of how to clear out the jam.
I just saved the company a few hundred on a service call to our printer sales/service vender.
Posted on Mar 18, 2009
SOURCE: Paper Jam 0
I have this problem too but mine is intermittent. I believe it's a physical failure of the (likely) plastic gears of the feeding system (from when I "had" to pull a dozen pages out of the jammed feeder!)
Any physical 'trauma' like that it may have experienced? You might be like me - in the market for a new printer.
Posted on Nov 24, 2009
SOURCE: Display reads paper jam 2 check inside
Open the Top Half of the Copier. The Scanner Section pops open by pushing up.
Underneath the Scanner Section is the Fuser Unit. Check in the Fuser Section, you will find paper Jam in the Fuser Section.
Posted on Aug 27, 2011
rakesh_budha
SOURCE: paper jam-2
samsung scx-4521f paperjam2 check inside
Posted on Dec 27, 2011
Canon IR 2016j, paper jams on every copy.How do i fix it?
Dear Abdullah
pl. check the machine base where it stay, it should be plain and firm.
Next check the left side door(test it by pushing inside while making copy). check the fixing assembly and paper path, may be toner clogged on its surface.
If your machine covered more than 200000 A4 copies, check the paper path (guide) at registration sensor and delivery guide at fixing unit.
If the paper jam at paper pickup tray, replace the pickup roller set (2nos.)
Since you have not mentioned the page counter and where paper jam occurs, its difficult to assume more.
thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
After restarting the machine shows the ready to copy massage it later bring a red indicator without any massage on the screen but the lower massages remain such as copy ratio, density among others what...
did you check jam indicator that glows red left from LCD panel?
Try to reopen the paper drawer and put it back strongly.
If you have dadf it can show jam if its lift up all the way.
On leftsideway, beneath the left door is paper pick up door reopen them and close more strongly.Also check the sensor flapper in the middle, wich is seen when paper pass door are opened.
For service manual you can contact me on emma.servis@gmail.com
Hope that helps!
Sep 04, 2010 | Canon iR 2016i Black and White Copier
Won't let me fax, copy or print. it tells me paper jam 2 look in
paper jam 2 generally denotes the fuser unit. thats at the back, the bit that heats up, theres a flip up/down cover that once opened should show you if theres any paper in there, also check the sensor, little black arm, move freely and be sprung, if the sensor is missaligned it will denote a paper jam even when there is none be careful to let the fuser cool down, printer unplugged for 10 minutes or so, 180 degrees will hurt.
Sep 24, 2009 | Samsung CLX-3160 All-In-One Laser Printer
After printing a page, 2 red light signals show and doesn't print anymore until after certainparts of the copier were opened and then closed. When the swiych in turned on again, it copies only 1 and then...
1)check properly if there is no paper jam, make sure all jams have been removed
it this doesn't work
2) Remove the paper in the paper tray and replace with papers tha do not have folded edges
Make sure you are not using a paper that cannot run smoothly through the photocopier (too light or too hard)
3) Also check if some papers are stucked under the paper tray.
Apr 08, 2009 | Sharp AR-5316 Advanced Digital Imager...
Paper jam-2
Mar 22, 2009 | Samsung SCX 4521F All-In-One Laser Printer
False paper jam massage on the HP photosmart printer D5063
Your paper loading and moving mechanism in the printer seems to have some jamming problem in movement or the sensors inside the left part of the machine may have dust or inturruption somewhere.
Service your printer your own if you can, or get it service from an expert....
Feb 13, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Canon 6050 copier
yes it indicates same message
Apr 14, 2008 | Canon NP 6050 Copier
Samsung SCX 4521F All-In-One Laser Printer Logo
42 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
