Question about Radio Communications
Search Fixya...craig cbh506 headset - Radio Communications
Am looking for a used gear box 250 v max
post a want ad in your local newspaper or on Craigs list we do not search for used transmissions here on fixya
Jan 14, 2017 | Motorcycles
What is the pin no for cbh 506 ?
Jack, Check the attached links,instruction and guides, you wil find Craigs support page 3rd link. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Pair Cell Phone to Bluetooth Headset
How to Solve Bluetooth Pairing Problems
https://craigelectronics.net/support
Aug 03, 2016 | Radio Communications
I need drivers for cmp616f mp3 player
craig cmp616f driver Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on craig cmp616f driver related ... why isnt my craig mp3 player model number cmp616f turning on? because you need ... ...craig mp3 player cmp616f. how do i turn down volume ? press the volume ...
CRAIG CMP616F USER MANUAL Pdf Download.
www.manualslib.com > Brands > Craig Manuals > MP3 Player > CMP616F
View and Download Craig CMP616F user manual online. Craig MP3 Player User Manual. CMP616F MP3 Player pdf manual download.
Craig 4GB MP3 Player, CMP616 - Walmart.com
www.walmart.com/ip/Craig...MP3-Player-CMP616/33846067
Walmart
Rating: 2.5 - ‎8 votes
Buy Craig 4GB MP3 Player, CMP616 at Walmart.com. ... It looks like you are not signed in. To proceed you will need to either sign in or create a new account.
How to use a Craig MP3/MP4 Player - YouTube
Jan 24, 2016 | Craig Audio Players & Recorders
Set up voice command and it calls the wrong person.
According to the user guide you tap the headset for voice recognition selection. However sometimes it may be the error of the phone not recognizing the name you want to call. Sometimes the names are similar in speech (Craig, Greg, Tim, Kim) you may want to change to last names or a combo of a name (Billybob). Check your phone recognition without the headset to see if it is the headset not making the name right. If the headset is still under warranty I would get a replacement.
Good luck from Headsets Direct!
Mar 27, 2011 | Plantronics M100 Bluetooth Headset
Need passkey for my H680 motorola head set . ???
Hi, you can follow this step as a guide.
Step 1: Set the headset to be discoverable
1. Turn off the headset.
2. Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
1. On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
2. On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000.
See the instructions that came with your other Bluetooth-enabled device for more information about pairing it with Bluetooth devices.
Hope it helps.
Thanks for using fixya.......
Jan 09, 2011 | Motorola Mobility H680 - Headset -...
I need a security passkey for a plantronics 6400 bluetooth headset
Remember all blue tooth use the same codes.
hope that helps...
thanks for using fixya........
Jan 07, 2011 | Plantronics Explorer 320 Headset
I have a PS3 and I want to put BB 655+ headset but it is from my mom and I dont know the password.
Hi, All headset devices use a default code which 4 zeros,'0000'.
I guess that will do..
You can pass your comment..
Use this as a guide
Thanks for using fixya............
Jan 07, 2011 | RIM BlackBerry 8100 HS-655 Bluetooth...
Hello- I just dropped my H710 Motorola headset. When I turn it on I hear the 4 tone chime, but now I also hear a ping after the chime. The headset will not connect to my Palm Centro and I'm unable to pair...
Try to pair again. Make sure you erase the profile from your phone. Then pair again. If you keep hearing pink. there is damage to the speaker on your headset.
Jan 15, 2010 | Motorola Mobility H710 Bluetooth Headset
Radio Communications Logo
236 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
