Question about John Deere Garden
Why does my john deer 345 keep blowing fuses
libaredneck
  • 119 Answers
SOURCE: my john deere 345 shuts down while running.
check the tank for debris blocking fuel outlet. also change fuel cap as it could be pulling a vacuum on the tank.
Posted on May 05, 2009
  • 9 Answers
SOURCE: john deere mod 345 no spark
first find the wire that is grounded to mower to ignition
and check that it is isolated if mounted on some plastic and disconnect it
if it runs to start switch check wire for cuts also
most common problem is the coil located under the top plate held on by 4 /5 screws on sides.
remove top and follow plug wire back to coil
you can clean the curved edges of coil that are against motor {magneto} with sand paper and clean mag
remove plug and lay threads securely agains frame and check for spark {hold by wedging not by hand as you can get a jolt!}
Posted on Aug 20, 2009
nova2nv
  • 197 Answers
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Posted on Nov 14, 2009
  • 394 Answers
SOURCE: Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
Posted on Mar 13, 2010
SOURCE: how to replace drive belt on john deere model 345
- remove deck
- remove seat and rear fenders
- pry off deck adjusting knob
- remove F/R pedals
- remove floor plate
- use jackstands to prop up entire right side of tractor
- remove (2) screws holding fuel lines on side of frame
- lift out gas tank, set alongside left side of tractor
- remove plastic fan from hydrostat
- disconnect the electrical connector for the electric clutch
- from the top-side - use a 3/8" drive rachet - stick it into the tensioner slot next to the idler, rotate it to take tension off the belt, and remove belt off hydrostat pulley
- from underside - remove front idler (next to electric clutch)
- from underside - remove the "right-most" idler off the spring tensioner
- from underside - remove the "left-most" idler off the spring tensioner
- now the tensioner can rotate fully to take almost all the tension off the extension spring
- pop the spring off the tensioner arm
- the belt should now be able to be removed from the machine
- reinstall in the opposite fashion
- note: to reattach the spring, connect a nylon cord to the spring, and pull it rearward and guide it onto the tensioner arm - you need to stretch it about 1"
- for reattaching the two idler pulleys to the tensioner, get someone to hold the ratchet so the tensioner is positioned for the belt being in it's most-loose position. You may need to wrap the new belt around the hydrostat pulley first, and assemble the last idler pulley and belt at the same time to complete the procedure.
Posted on Jul 29, 2010
Why would a mdl 1035 john deere tractor keep blowing the starter fuse
There is a distinct possibility that this tractor was originally equipped with a 6 volt system. If it has been upgraded to a 12 volt starter, the ignition will need to have a resistor installed to bring it back to 6 volts.
I could be all wrong on this but it's worth checking.
Mar 06, 2015 | John Deere Garden
Why does 345 john deere run hour then stop?
Mine doing the same. Must have something in the tank. Took gas line apart for it enter filter and blew in to it. Works fine now.
Sep 04, 2014 | John Deere Tractor Starter 285 345 2243...
Moo345Bo72674
Follow the link to John Deere manuals
http://manuals.deere.com/
Aug 23, 2014 | John Deere Garden
John Deere 345 won't shut off
I would start with either replacing the key switch, or tracing the wires to make sure they are not touching together somewhere, completing the ignition circuit.
Apr 14, 2013 | Garden
Mar 13, 2010 | John Deere A,b,g Tractor Carburetor Float...
My John Deere 345 dies for no apparent reason
You have dirt in the fuel tank and it sucks the dirt up on the filter that is attached to the pump. After the machine stalls, the dirt falls off and it will restart and run for a few min.
Oct 02, 2009 | Garden
Garden Logo
32 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
