Question about AMERICAN Comfort ACW500CH Portable Air Conditioner
I have the america comfort acw500CH unit and it was on hight speed and all of a sudden it shut itself off..it kept opening and closing the top vent by itself..turned it off waited 1 hour and turns on and no motor..
Comfort star
Make sure the indoor filters are clean. The outside unit will continue to run until the indoor reaches the temperature you have selected. Dirty filters can throw the temperature out. Its common for outdoor units to freeze up when on heating mode if the ambient air temperature is below 5 degrees Celcius.. The machine should however, defrost itself. There could be a problem with one of the pipe or air sensors on the outdoor unit.
Feb 23, 2014 | ComfortStar CHH012CD-13B Wall Mounted Mini...
Laptop freezes beeps
Is it up on a table on in your lap?
There are vents on the sides and bottom that need to be kept clear so the unit can cool itself, you can visually inspect those to make sure no dust/dirt are clogging them up and use compressed air to clean.
If you are snuggling in bed with it or have papers close to side of vents, or using in lap covering those holes, you should feel the heat, heat destroys laptops and if you continue to use it in that manner, if that is the issue, you will have a failed unit shortly.
It is most likely beeping and shutting down from excessive heat.
Oct 29, 2013 | Toshiba Computers & Internet
American comfort portable heating & a/c unit. compressor will not stay on.
Three things come to mind. First, if its on an extension cord make sure it is rated for appliance use. Undersized cords will cause the compressor to trip off. Secondly, I know it sounds stupid, is the thermostat set below room temperature?, And third, is it possible that the cool air, that it is initally blowing out, short circuiting and being pulled right back into the filter section. Like if a curtain is hanging over it or its behind a door? Good luck
Aug 16, 2013 | AMERICAN Comfort ACW500CH Portable Air...
Cuts out after 30 minutes of play , sometimes less and gets really hot
Your PS3 is overheating and the system is shutting itself down to save itself from serious damage.
If your PS3 is in a closed, confined space, get it out in the open. Make sure that none of the vents are being blocked. If there is alot of dust around the vents of the PS3, clean it out with compressed air.
If this does not alleviate the problem, there might be an internal issue such as dried out thermal paste or a broken fan. If you are comfortable in doing so, you can take apart the PS3 to fix these issues (many free tutorials are available online on how to take it apart, and spare parts are abundant on ebay). However, if your PS3 is still under warranty, it would be best to get them to fix it for free.
Jan 25, 2011 | Sony Playstation 3 (PS3) Console
Washing Machine shuts off by itself during cycle
Not sure what you are saying.. if washer is off balance, it will shut off, check legs are secure to floor and unit is leveled. If washer lid isnt sealed or lid switch is bad it can shut off at spin or start cycle. Depends on unit model. The smell can be a burning belt from a heavy wet comforter or you have mildew from water not properly drained from unit.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Possible Contactor Issue
Sounds like a bad fan switch in your unit. That unit has a fan board in it that is time delay on and off. Turn the fan to the on position and let it run all the time. If it keeps temp and does not shut off it is the fan realy board. The board also controls the compressor. Check that first and then the tsat. Russ
Jul 24, 2009 | Carrier 38CKC042 Air Conditioner
Saeco Magic Comfort Plus still producing steam in "off" position.
This may be something you can fix. It depends on your comfort level with mechanical repairs. You probably need to replace some o-rings in the steam valve. Don't keep trying to brew or steam because leaking water or steam inside may cause an electrical short. Decide if you want to delve into the repair, or locate a repair center near you. I could put you in touch with some.
Mar 18, 2009 | Saeco Magic Comfort Plus Espresso Machine
Electric dryer keeps shutting off...
Be sure that there is a LOT of air coming out outdoors first. If there is, the hi limit thermostat is now defective from the abuse of your fire hazard, I mean clogged vent. (same thing) If not, the vent is still not clean enough. If it's flexible duct, replace it with solid duct. You could also have a clogged up lint screen, (fabric softeners commonly clog the screen) or the fan in the dryer may also be clogged up.
Jul 02, 2017 | Kenmore 64852 Electric Dryer
Kenmore - over under
Adjust the feet to raise the front of the frige, which should be higher than the back. Therefore the weight of the door will keep it shut or at least cause it to shut itself if it pops open.
Jul 08, 2008 | Kenmore 62832 / 62834 / 62839 Bottom...
Buttons
F1 - F3 are the fan speeds when the air conditioner is in fan only mode.
The vent can be opened or closed based on your preference. When the air conditioner is in a/c or dehumidifier mode having the vent closed will cause the a/c unit to recirculate the room air and cool / dehumidify quicker. When you open the vent the a/c unit takes air from outside and cools / dehumidifies it. It is obviously not as efficient this way but it does bring in fresh air.
Jun 10, 2008 | Goldstar M1003R Air Conditioner
AMERICAN Comfort ACW500CH Portable Air Conditioner Logo
29 people viewed this question
Top AMERICAN Heating & Cooling Experts
Lawrence Oravetz
MightyMikeJr
Are you an AMERICAN Heating and Cooling Expert? Answer questions, earn points and help others
