The following links should help?
Manual
https://philips.encompass.com/shop/model_research_docs/?file=/SHA/sm/CVP09FX.pdf
Filter
Filter Part Number DFILMA001JBEA Sears PartsDirect
SOURCE: My Sharp CV-P09FL portable a/c
Check your filter to see if its clean, and also move your thermostat sensing bulb in front of the front cooling coil in front of your filter, this cold be a sign as weakening thermostat sensing bulb, if all else fail, replace it.Thank-you-very-much!
SOURCE: cleaning my Sharp CV-10NH
Here is the link to the manufacture site for your manual.
http://www.sharpusa.com/products/TypeManuals/0,1083,217,00.html
SOURCE: Sharp 10000 BTU 38db portable air conditioner
sounds like the unit has a low charge and is cutting out on a low press safety. This is more then likey not something you can fit yourself most of this units are not really serviceable with out cutting the lines open and adding a valve. If the unit is still somewhat new you can try for a warranty repair, if not you are better off to replace it.
SOURCE: I have a Sharp portable a/c model CV-10MH. I drain
not a expert just trying to help,, sounds like you have coils in the back of the unit cloged up with dust,, take outside and spray some water and clorox mixed on the coils and clead good then rinse of with water,, hope this help
