Question about Pool & Spa
Hurlcon ctx 2hp pump troubleshoot
Controller shows no flow & cuts out after 10 mins running, basket only 1/2 fills,filter guage goes to 12o'clock,converter almost fills, water pressure strong at pool hose end & looks strong filling basket before motor, motor has been checked & OK, this has been occurring on & off all year,had pool guy come 3 times, can't find problem, filter cartridge slightly worn, band broken in 1 place,but all else ok,water level & chemical balance ok.This is driving me crazy, can you help?
    Top Expert:
  • Pool & Spa Master
  • 8,673 Answers
Motor overheating replace pump
Posted on Sep 13, 2017
  • 61 Answers
SOURCE: Pool pump will not fill back up
It sounds like you are sucking air into the pump. Make sure strainer baskets and pump baskets are clear, and the valves are in the right position. Also check the water level in the pool, and make sure that the pump is not sucking the skimmer dry. Next try lubricating the gasket on the pump lid, or if it is in bad shape (flattened/cracking) replace it. If this does not solve the problem put silicone around the inlet to the pump (silicone is a temporary fix that could last days or months--for best results replumb with teflon tape and sealant). If all that fails you could have debris stuck in the impeller.
Posted on Apr 05, 2009
  • 366 Answers
SOURCE: 1/2hp Hayward Pump for existing inground pool
you will be fine with the 1/2hp. The Hayward will move quite a bit of water as well. It may not move as much water as the 3/4hp but it's very close and the 1/2hp will cost a little less to operate so if anything, you may just have to run it for one additional hour per day to compensate. You will be surprised how much water a 1/2hp will move. The only issue with smaller pumps is if you have pop-up cleaner heads or a suction driven automatic cleaner such as a kreepy krauly, however, if a 3/4hp will run it, a 1/2hp will run it as well. You can install a larger motor on the super pump but it will not move more water unless you upgrade the impeller as well. Just make sure you don't use a bigger impeller than what the motor is rated for because it will strain the motor and cause it to overheat. Hope this helps.
Posted on Feb 22, 2010
Testimonial: "Great. Thanks for the quick feedback. I look forward to saving a few $'s this year operating my pool. Cheers!"
jharwell668
  • 640 Answers
SOURCE: How to open pool, fill sand filter with water?
I happen to have a copy of the users manual for this pool filter. These are the instructions for operating your filter.
1. Be sure correct amount of filter sand media is in tank and
that all connections have been made and are secure.
2. Depress Vari-Flo control valve handle and rotate to
BACKWASH* position. (To prevent damage to control valve
seal, always depress handle before turning.)
3. Prime and start pump according to pump instructions (be
sure all suction and return lines are open), allowing the filter
tank to fill with water.
WARNING: ALL SUCTION AND
DISCHARGE VALVES MUST BE OPEN WHEN
STARTING THE SYSTEM. FAILURE TO DO
SO COULD CAUSE SEVERE PERSONAL
INJURY.
Once water flow is steady out the waste line, run the pump for
at least 2 minutes. The initial back-washing of the filter is
recommended to remove any impurities or fine sand particles
in the sand media.
4. Turn pump off and set valve to RINSE position. Start pump
and operate until water in sight glass is clear—about 1/2 to 1
minute. Turn pump off, set valve to FILTER position and
restart pump. Your filter is now operating in the normal filter
mode, filtering particles from the pool water.
5. Adjust pool suction and return valves to achieve desired
flow. Check system and filter for water leaks and tighten
connections, bolts, nuts, as required.
6. Note the initial pressure gauge reading when the filter is
clean. (It will vary from pool to pool depending upon the
pump and general piping system). As the filter removes dirt
and impurities from the pool water, the accumulation in the
filter will cause the pressure to rise and flow to diminish.
When the pressure gauge reading is 8-10 PSI (0.55-0.69
BAR) higher than the initial "clean" pressure you noted, it is
time to backwash (clean) the filter (see BACKWASH under
Filter Control Valve Functions.)
Posted on May 24, 2010
  • 760 Answers
SOURCE: Dial a flow question
Ok the first on the PSV valve. the 1/2 position should really be 1+2. You have two linlets to your pump. One from the skimmer and one from the main drain in the floor of the pool. When you select port 1 it will be one or the other perhaps 1 would be skimmer and 2 would main drain. You can select one and see if the flow stops in the skimmer. That will tell you which is which, depends on how it was plumbed. Position 1+2 combines the two flows. I normally select both, If my pool gets a lot of grass and leaves, I select skimmer only or when I vacuum. I select main drain only when there is more debris at the bottom. OK recirc is only recirculating within the piping system bypassing the filter. You can dowload a complete manual of your filter and components from www.haywardnet.com. Green water: Ok your chemicals are right? Free Chlorine, total chlorine? hardness, calcium, pH, alkalinity? Well most pool companies want you to buy some algaecide and that can't hurt, but I'd shock your pool if it's dark green I'd put it 4-6 gallons of liquid chlorine, if its light green 2-4 gallons. This is when I'd use recirculate. Allow this to mix without filtering for a couple of hours. Turn the pump off and allow to set overnight. In the morning you should have much clearer water, with green slime sitting on the bottom. Vacuum this to waste very gently so as not to remix algee.IF this doesn't work you'll need som floculant and repeat the opeation folling the directions on the floculant Restart filter, keep chlorine level high above 5-10ppm for a day or two and keep filtering. If it is still cloudy now,add some filter aid. In hot weather, don't let that free level go below 4ppm. Don't allow anyone to swim while chlorene level is high. Be sure to us test strips that indicate free and total chlorine.
Posted on Jul 21, 2010
MOTORWIZJ
  • 1383 Answers
SOURCE: Hello , I have a 5yr old pool complete with
ALWAYS FREE.. SO IT SEEMS THAT YOUR NOT GETTING AIR, THESE BLOWERS HAVE FOAM IN THEM AND CAN ,AFTER A FEW YEARS GET CRISPY AND BREAK UP AND PLUG THE AIR PUMPS SUCTION PORT. THE FOAM IS USED AS A AIR FILTER AND A NOISE REDUCER , WHEN THESE BLOWERS GO BAD 90% OF THEM CAN'T BE REPAIRED ! = JUNK.. TO SEE IF YOU HAVE A RESTRICTION IN YOUR LINE OR LINES ,USE A SHOP VAC TO **** AND BLOW THE LINES IN AND OUT.. THESE BLOWERS ARE HELD IN USUALLY WITH ONE SCREW AND ARE EASY TO REPLACE ONE MORE CHECK 4 YA IS, THERE MIGHT BE A CHECK VALVE INLINE ON THE BLOWER , IT MAY BE BAD . BEST WAY TO CHECK IS TURN THE BLOWER ON FIRST , THEN TURN THE WATER PUMP ON.. HEY IF'N I WAS OF HELP GIVE ME A REVIEW OR A THUMB.. JAY YOUR LOCAL POOL PUMP WHISPERER IN FLORIDA
Posted on Nov 16, 2010
Testimonial: "Thank you -- the 2hp motor provides air induction and bubbles. There is no foam to break off. I did blow system out , still the same. Will keep lookin"
Lose press on retrn to pool using Hayward S166t with brand new veri flow pump attached. I back wash and pressure restored is excellent but within 15 or twenty min drops off again.
what is the water like?
Dirty? Green? Murky? Cloudy?
Something is clogging the filter!
Let me ask this, you said: "Pressure drops Off" ???
Do you have a pressure guage on the filter?
Does the pressure increase? Or does it Decrease?
This will be an important piece of information!!!!
  • If pressure increases on the pressure gauge...
    • then filter is working and filtering out dirt and filter is clogging up.
  • If pressure decreases on the filters pressure gauge,
    • then the basket, or literally anything that is decreasing or stopping the water from getting to the pump, or more precisely to the internal impeller of the pump!
Most commonly - plugged impeller, baskets need to be checked, enough water in pool? etc.
May 17, 2015 | Hayward Pool & Spa
maqke sure the intake union is tight also check to see if seal slipped use filter lube
Jul 02, 2014 | Pool & Spa
Error after short prime cycle
AIR LEAK IN SUCTION LINE. PUT A GARDEN HOSE WITH A RAG AROUND IT TO BACKFEED FROM INTAKE IN POOL. WITH PUMP "OFF" TO LOCATE BREECH IN LINE.
Apr 21, 2014 | Pentair IntelliFlo VF High Performance 3HP...
It sounds like you have a suction leak. What's odd it that it works for 2 hours then loses prime. I don't think it would be related to the air temperature. Check out the pump basket lid o-ring to make sure it is in good condition and properly lubed (this is a very common cause of suction problems).
Also check your water level to make sure it's high enough. Any valves on the suction side of the pump may also be suspect. Good luck with it.
Jan 05, 2014 | Pool & Spa
My jacuzzi Century Flex-48 pool pump is surgeing after running for 10 min.
possible motor overheating then overheating seals, then they wont pump water they expand and water goes by them
Oct 09, 2017 | Pool & Spa
Pump will not stay running. motor gets warm. motor shuts down after running for about 10 to 20 seconds.
Check the voltage at the pump while its running. If the electric feed line is too long for the guage wire,
voltage drop will cause the motor to overheat and switch off.
Oct 07, 2010 | Flotec Corrosion Resistant Shallow Well...
Help low pressure in pool pump and filter
I can relate so well to your problem. My pool is surrounded by pines and deodora trees... all the needles seem to find their way through the baskets, strainers and into the inlet of the pump. It became a daily routine of having to reach into the inlet and clean the debris if I wanted a filtered pool.
Here' s a solution that will work!
Purchase an extra debris scoop ...the kind you put on the pole and scoop debris from the bottom of the pool.
Cut the net out of the frame and wrap the netting around the skimmer's debris basket and secure it with an oversized rubber band or zip ties, then replace the basket back in the skimmer.
Your skimmer will keep the debris out of the pump!
This will make a world of difference in your pump's pressure!
Give it a try and see if you're not working better!
Jun 03, 2010 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
Feb 20, 2010 | Hayward SAND FILTER, PRO SERIES
I have 1 and 1/2 horsepower sprinkler pump that wont prime. As soon as the end piece fills, it will empty if I open the end to the sprinkler.
I don't know what is your system set up. However, the system set up should be the following;
1. Your 1-1/2HP sprinkler pump must be installed at
a fix location nearest the water source. (Complete
with power and plumbing lines.)
2. At the end of the suction line is a vertical check
valve with strainer.
3. The suction pipeline must be connected to the
suction port of the pump.
4. At the discharge port, a flow control valve tee must
be installed. The flow control valve tee top is
covered with a plug, which serves as the priming
port when opened.
5. After the flow control valve, connect a short nipple
so that you can put a gate valve to stop the water
flow or allow the water to flow. You may connect
a pressure tank at this point or you may connect
the pressure hose going to the sprinkler.
6. To prime the pump, open the plug at the flow
control top. Fill it full with water, replace the
priming port plug.
7. Turn the flow control valve to full closed position.
8. From full close position, switch the power on.
9. The pump now run on and off due the pressure
switch setting. Slowly open the flow control valve
such that the water pressure remains steady.
10. Take note of the pressure.
11. Shut the power off, and connect the sprinkler
pump hose.
12. Put the power back on, and allow the pump to
run with the sprinkler.
Under this set up, you can run the sprinklers when your pump is running. Hope this will solve problem.
Dec 08, 2009 | Plumbing
Lost my prime in my pump, i have tried numerouse time fill the basket area with water turn on pool pump nothing, any more suggestions. I lost my prime to my pump a few weeks ago . I had a pool company...
please check your impellar it sounds like it is broken this is the part that really moves the water if motor is ok then it would most likely be this .
Thanks for useing fixya
Rate me
Apr 27, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Pool & Spa Logo
56 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
