Question about Garden
Lawn mower recoil spring
The pull cord broke when trying to start and then made a loud metal clinking noise. It looks as if the spring came uncoiled and is loose in the recoil. I can not get the recoil starter off of the engine top because something is jammed and holding it on. What should i do?
    Master:
  • 969 Answers
Remove mounting nuts, pry recoil off fly wheel. Purchase new recoil assembly at mower repair store.
Posted on May 28, 2014
SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Posted on Mar 21, 2009
SOURCE: Starter cord loose on Bolens 4.5 HP lawn mower
Need to remove the pull cord assembly. Something is amiss in there. If you don't want to attempt it, I'd take it to a shop.
Posted on May 13, 2009
panilling9
  • 284 Answers
SOURCE: Starting issues. Can't pull cord.
Make sure your flywheel brake is not engaged or the cover is hindering the mechanism somehow after it is installed
Posted on May 25, 2009
  • 4 Answers
SOURCE: I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Posted on Jun 07, 2009
rburroak
  • 14 Answers
SOURCE: lawn mower needs new cord to crank the engine. how do i replace the cord
Remove the 3 bolts located on the flywheel housing.(should be 7/16") one in front and two on side.
Posted on Jun 19, 2009
Broken spring in recoil starter on lawn mower
While I have not done this on newer model lawn mowers, I have replaced recoil springs in the past. Here's what I did: First you need to pull the spark plug wire off so the engine will not start. Then block the flywheel with a piece of wood to keep it from turning. Then, using another piece of wood such as a short (6-8 inch) hardwood dowel placed against the ears of the recoil drive, and drive it in a reverse direction (clockwise) with a hammer to knock it loose. It may take several sharp blows to break it loose. The recoil drive is reverse threaded to keep it from coming loose when the engine is running. Once the drive is loose, remove it to get access to the recoil spring which must be replaced if it is broken. With a new spring in place, rethread the recoil drive counter clockwise until it is finger tight. Then, tighten it down with one sharp blow against the wooden dowel.
Jul 10, 2013 | Garden
Pull cord on briggs & strtton wont retract back
If you don't know how you will need a manual, it is kind of tricky.
Remove the rope. Feed the spring from the outside of the housing and connect to the recoil housing. Turn the wheel using a 3/4 " rachet extension and the spring will feed ito the housing until the end of the spring connects to the ouside of the housing. Keep turning until the spring is tight, back off about 1/2 turn and feed the rope from the outside, be carful here, if the extecsion comes out the spring will uncoil and you get to start off all over again.
Apr 16, 2013 | Briggs & Stratton Garden
Need toknow how to rethread pull cord for briggs & stratton 300 mower
You need to remove the Recoil
Remove the Old line
Insert the new line
Wind the spring tight
Ensure you have 6 feet outside
SO YOU UNDERSTAND. THE SPRING IS COMPLETELY WOUND (Then backed off ONE ROTATION). and then allow the spring to RECOIL to PULL the line in and then the Pull Length. it will become quite clear as you are doing it
Apr 13, 2013 | Garden
Pull start cord will not recoil
sounds like the recoil spring broke and needs to be replaced
Dec 29, 2012 | Garden
My Craftsman lawn mower starter cord doesn't retract after mower starts.
I have had this situation before on a lawnmower. I didn't have a craftsman, but is probably the same issue. Basically, the spring that recoils the cord back in either broke or came unwound. When the mower is not running, the cogs on the pull chord keeps the cord from coming out. When the mower is running, the spring is not wound enough to hold the chord in and thus releases or doesn't hold it in.
Try pulling the pull chord assembly off and rewind the spring.
May 05, 2011 | Craftsman Garden
How do you change pull cord on mower
  1. Undo and remove screws holding the starter cowling onto the engine. Remove cowling carefully
  2. Use a screwdriver to prise up the clips that hold the pulley unit inside the cowling
  3. On the side of the pulley there is a slot which the end of the recoil spring hooks into - unhook the spring
  4. Allow the spring to uncoil from the pulley and unhook the other end of it from the centre of the pulley boss.
  5. Pull out remains of old cord and thread new one it. Tie a stopper knot in the end but do not wrap it around the pulley yet.
  6. refit the spring and fir the pulley back into the retaining clips on the cowling.
  7. Turn the pulley 13 and 1/4 turns anti-clockwise to wind the spring up again.
  8. Whilst holding the pulley push the un-knotted end of the cord through the cowling and refit the handle
Feb 22, 2011 | Briggs & Stratton Briggs Stratton...
The pull cord will not recoil back into the mower and won't start it how can i fix that so my mower will work again
You probably have spring problem. You will have to pull the starter shroud off. Eigther the spring is broke or there is debris or rust binding things, if your lucky its the latter, clean and lubricate.
Sep 28, 2010 | Garden
Jun 07, 2009 | Garden
Pull cord on weedeater wont recoil
sounds like the spring is broken itself.there should be a hook at one end and a loop at the other end.the hook usualy breaks off but the spring looks good.replace the spring with part number..4140 190 0600 ....that is the stihl part number.let me know if this helped you...if not give me a quick mail and i'll try to help some more......
Mar 12, 2009 | Garden
Garden Logo
149 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
