Question about GE Profile Harmony DPGT750EC Electric Dryer
Dryer light bulb burned out
I got a question first off my dryer don't close shut and the light bulb burned out is it ok to leave the plug on or take the plug off? Can I change the light bulb but Will it stay shut if i change the light bulb
    Top Expert:
  • GE Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
Light Socket
The light socket can get corroded or a wire connection can come loose. You will need to remove the front panel to access the housing on most dryers.
Door Switch
If your dryer has an interior light, it probably uses a standard 40-watt appliance bulb, but check your owner's manual to be sure. If the bulb is good but the light won't come on, check the door switch, which serves two functions: When the door is closed, it turns off the light and allows the dryer to start. When the door is open, it turns on the light and prevents the dryer from starting. To check the door switch check for continuity. You should have some when the door is closed and none when the door is opened.If not replace the door switch by removing the front panel.
It blows fuses or trips the circuit breaker
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. Loose connections on the power cord cause failures and or fires. This can be checked with the dryer unplugged and removing the service cover and visually check for burning and mechanically check for tightness.
If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Posted on Jul 10, 2013
  • 54 Answers
SOURCE: No power to dryer
If you go to lowes you can purchase a pen type voltage tester cheap. Insert the tip into the 2 long prongs they are the hot wires. The L shaped one is the netural. You might unplug the dryer and remove the cover where the cord goes in the dryer. Check and make sure the wires are tight where they attach to the terminal block as alot of times the installer does not tighten them.
Posted on Jul 04, 2008
  • 1122 Answers
SOURCE: Where buy light bulb (120V,
go to sears .com click on parts, put your model number in and all the parts for your dryer will come up,let me know how you do-mike
Posted on Oct 01, 2008
  • 3 Answers
SOURCE: DBXR463ED1WW GE Dryer Runs for Hours
on which setting are you running it. If you are running this on the timed setting then its obviously a faulty timer. Sounds to me though that you are running it on its automatic cycle. If this is the case it could be a couple of things. Somewhere on ur beast there is a moisture sensor, this is what advances the timer and tells it to stop. This may be faulty or it could be that ur vents are indeed clogged which would trap the moisture in and result in the long dry times. The simplest way to go about this one would be to clear the air flow and see if the problem persists.( this means pulling out the dryer clearing all the vents, if using the flexible ones make sure they are not binding up while setting dyer in place. Also if there is a vent that runs through the wall as well you can clear this by removing exterior vent). good luck
Posted on Feb 20, 2009
  • 10865 Answers
SOURCE: My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Posted on Nov 09, 2009
michiganfan9
  • 179 Answers
SOURCE: my dryer door won't stay
your latch is probably bad. the part number is WE1M536 it will cost about $5 you can get it at searspartdirect.com
Posted on Jul 15, 2011
Gas smell from vent
Something that runs on gas in your house is leaking that out, not necessarily the dryer. Check all your pilot lights to make sure they're either burning or that device's gas is shut off by valve. You don't share buildings with another family, do you? (like a duplex or quad housing)
Oct 19, 2012 | LG DLG3788W Gas Dryer
I have a maytag gas dryer mgdx500xw, with door open and light on, circuit breaker blows, with door closed it does not, if I remove the bulb, it won't blow either way. Weird?
the return neutral wire from the bulb has to have a bare spot on it touching the metallic case somewhere in the dryer,when you remove the bulb you just isolate the bare spot on the neutral wire from the hot wire
Sep 07, 2012 | Maytag Dryers
Stackable Kenmore model 110.98752. Dryer drum turns but no heat. Vent does not appear plugged since air does flow through to outlet.
With your volt ohm meter (VOM) check for 220 volts at the terminal block the cord attaches to.
If 220 is present, unplug the dryer and remove the rear panel.
With meter set to continuity check the thermostats and fuses on the heater as well as the heater coil. Remember to unplug the wires to each component to check them correctly.
You should read 120 volts from black to white and red to white for a complete circuit.
Look closely at the wires at the terminal for a burned wire.
No burned wire, open the wall outlet and inspect the wires and the female connections.
Read voltage at the wall connection for 220 volts and 120 volts from hot to neutral on both legs.
With the power disconnected you should take at least one wire off each thermostat and limit just to be sure you don't somehow get a false read.
If it runs at all and the heating element is OK then you most likely need a limit kit.
You dryer has a series of safetys. If the control thermostat fails, the filter housing gets blocked with lint, or the vent gets stopped up the heat could cause a fire. The bottom cannister thermostat limit is the lowest temp one 250F, it should shut down first if it fails then the limit mounted at the top of the cannister is set to Blow at 300F When it blows that is an indication of an external vent blockage. If the problem is from within the dryer then the fuse mounted on the blower housing will blow an the dryer won't run. The fuse is rated at 350F and is tied into the door switch. That is why the wires are smaller. They don't carry the heat load. If the duct fuse blows it is the same as if you opened the door. The dryer simply quits running.
Jul 16, 2011 | Kenmore Dryers
I replace the light bulb but it does not work although the dryer works fine. Is there a special bulb?
with the power unplugged, check the tab inside the bulb socket to be sure its not burned or damaged, also,, at times a new bulb is no good, If you have a multimeter,, put the selector to continuity ,, and place the black lead to the bulb base, and the red lead to the center point at the bottom of the bulb, if you get no reading, the bulb is no good, ( if you don't have a meter, screw it into another lamp, as long as your sure the dryer light socket is a 120v not a 220 volt
Jul 12, 2011 | Whirlpool GEW9250 Electric Dryer
Two things. 1. the dryer does not shut off when the door is opened. 2. I changed the light bulb, still does not work, and now the door will not fullly close and latch.
your door switch is stuck in the closed position
replace that and you should be ok
as far as closing it may be the switch stopping the door too
Oct 05, 2009 | Kenmore 74872 Gas Dryer
Replaced burned out dryer bulb on Whirlpool GEW9250PW and now drum light won't shut off even with door closed. Dryer will not work but all panel lights function normally - UNTIL you press start. Dryer...
Hello jmylymok,
Welcome to Fizya,
You said, you replaced burned out dryer bulb on Whirlpool GEW9250PW and now drum light won't shut off even with door closed. Dryer will not work but all panel lights function normally - UNTIL you press start. Dryer just beeps and doesn't work. When I tried the troubleshooting solutions, the error 6E comes up. What does this mean?
This sounds like the reason your bulb went out was more than just a bulb normally dying!
There is a short, or in that socked or the switch or it affected the the control panel too!!
This sounds like a hands on diagnoses job!
Let me know how it goes.
Huuum
Oct 08, 2008 | Dryers
Won't start, just beeps - sounds like door switch problem others have had
The three short beeps could be part of the fault code. Check the owners manual and there are diagnostic sheets on the inside of the machine. I cannot find this fault code in my data base. What is the Model and Serial Number of your Dryer. Check the Power inside the machine at the power cord power connections. You should have 120V from both power terminals to the common terminal. There should be 240 Volts across the main power terminal. Another quest replaced the power cord. Hope to hear some good news soon.
InMrFixIt.
Aug 12, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer will not start after bulb burned out.
moch, the fact that the light is staying on when the door is closed leads me to believe that the door switch is the culprit. If that switch is not made you will not start. See if the pin is broken off. Start there and let me know. Catriver.
Aug 10, 2008 | Whirlpool GEW9200L Electric Dryer
Dyer has power but doesn't start
dryer inside is very hot, 6 years long time, i have the feeling that wire was damaged and connected to each other cause this kind problem.
Jul 06, 2008 | Kenmore Elite HE4 Electric Dryer
Three beeps
Replace the bulb and door switch.. (cheap)
last would be this 3-beep problem..
http://www.youtube.com/watch?v=tq3k22cqjR8
Mar 27, 2008 | Kenmore Elite HE4 Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
148 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
