Question about Metropolitan Vacuum Metro Air Force Master Blaster 4.0 Peak HP
Metro air force blaster has burning smell but works
Replaced rotor on my 115 ready heater now it puts out way to many fumes,it burns my eys.any suggestions
The fuel/air mixture is not right.
  • Start by setting the pump pressure to factory specs.
  • Stop all air/vacuum leaks between the air pump & nozzle
  • If the problem persists, replace the nozzle. Desa recommended annual replacement. Simply stated- the nozzle wears out to a point that the fuel is a spray rather than a fog and the fuel can't burn completely.
  • You don't state the type being burned. Diesel smells more than kerosene.
Feb 05, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
I have a rlp100 heater that works well but now has an annoying smell. It also burns your eyes some. It is 3 years old and hasn,t been used much. What can I do to get rid of the smell?
The smell is unburned propane and the burning of the eyes is caused by carbon monoxide. My heater (RLP100) does the same and I was able to measure the carbon monoxide at 95 ppm (deadly). I have yet to figure out what exactly is happening. Tried a new regulator/hose from a new unit - no help. Also pulled apart the burner nozzle and cleaned the holes - helped a bit. Next step is the valve.
Dec 18, 2010 | Reddy Heater RLP100 Portable Forced Air...
I turned on the air conditioner and the car lost power and made a really bad noise and smelled like a rubber tire was burning. It has 168 000 miles.
air conditioner compressor is locked up. If noise stops with ac off, it's ok to drive. If it noise stays, DO NOT RUN VECHILE. You'll break your belt, ruin your compressor, and be a pain in the a$$ to clean everything out so the new belt fits and works properly.
Aug 19, 2010 | 2003 GMC Yukon Denali
I noticed a smell coming from the mastercool and now the low speed and low cool does not work.
is it a burning rubber smell or a burning eletric smell. burning rubber smell will be a slipping belt. replace the belt and pullys. tighten belt. electic smell will be a bad thing. have tested by technition
Aug 12, 2010 | Mastercool 67680 Evaporative Cooler Air...
Terrible smell and burns my eyes from 5gallon tank. First 5gallon tank was find as is small Coleman bottle . Can propane be bad from Supplier. It gives off sour smell and irritates eyes when burning?
I would not use it any further, I cant say if anything is in the gas, I doubt it, However the propane at too low a pressure etc, can cause this, dont use it with eyes butrning ever!
May 28, 2010 | All-Pro Propane Garage Shop Heaters - All...
I have a central heating and air unit. The unit
sunds like the fan bearings have seized up or u have a bad fan capacitor take a screwdriver and spin ith blade to where the air would be coming out the top and if it startswhen u spin it u need a fan capacitor
Feb 23, 2010 | Coleman Propane Forced Air Heater...
I changed filters,but still get eye burning smell,I do use Kerosene
In my experience, eye burning is a by product of burning even the best kero. And at 115,000, you are burning a lot.
Jan 03, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
I have a 1990 Geo Metro with 3cyl and auto trans. The problem i am having wit it is I have no forward or reverse gears? I know the pump is working as i checked fluid level with engine off and on. when on...
When was the last transmission fluid ATF and transmission filter change?
The recommended interval is 2 years or 24,000 miles.
Is the ATF color a lite pink color or it's DARK RED?
Any burn smell?
Do the old fashion drop the trans pan and filter change.
DO NOT GO TO shop that use a machine to flush your automatic transmission.
Most Metro automatic can go up to 140,000 miles before needing a rebuilt.
If the ATF is in lite pink and it's not burn then the most likely cause are
1)lock up torque converter is not functioning
2)transmission filter is clogged
Please rate my answer if it's useful to you.
Thanks
MUSTGO
Dec 11, 2009 | 1990 Geo Metro
Coleman forced air furnace
im assuming you are running a/c and not heat...Was the filter burning??  if not and there are no other obvious burnt wires then id say you need a new motor. The filter, if it was'nt binding the blower wheel or wrapped arround the motor shaft would not have caused the prob.
Oct 16, 2007 | Heating & Cooling
Heater smells like it got too hot!
check for dust in the air path through the heater. the fan forces air through the element.  if you have an air blower - blow air in a reverse direction through it.
Oct 15, 2007 | Del-Rain 1500-V 1500 Watt Ceramic Heater
Metropolitan Vacuum Metro Air Force Master Blaster 4.0 Peak HP Logo
21 people viewed this question
Top Metropolitan Vacuum Dryers Experts
Are you a Metropolitan Vacuum Dryer Expert? Answer questions, earn points and help others
