Question about Frigidaire Compact Air Conditioner
Keeps beeping keeps changing from cool to energysaver to fan only constantly
2001 Honda Foreman 450es is it normal for the oil cooling fan to come on and off when trail riding thanks
Seems normal to me. An oil cooler fan works to keep the oil cool just like a radiator fan works to keep the coolant cool. It doesnt necessarily run constantly but it kicks on as needed.
Nov 07, 2016 | Honda Motorcycles
The cooling fan comes on five minutes after starting
Unless you have the A/C on, that may be normal. The cooling fans only run once the coolant temperature exceeds about 215 degrees. It runs until the temp is down to about 200 degrees. The fans will cycle on and off as necessary to keep the coolant within that range. When the car is in motion, the airflow thru the radiator is normally sufficient to keep the coolant stable and the fans do not run. Only if you turn on the A/C will the fans runs constantly, since the A/C system needs constant airflow thru the evaporator.
Nov 03, 2016 | Cars & Trucks
Why are my cooling fans for radiator running constantly?
The cooling fans are supposed to run any time the a/c is on in order to keep air flowing across the condenser. Your a/c will not work properly at idle if they quit.
Jul 27, 2015 | 2010 Ford Escape
Question about a fujitsu lifebook P5010. when i power up i have a blank/black screen although i can hear the fan running constantly. the little lcd display area next to the power button works. there are...
Hi insurancedud...
Try blowing the dust out of the laptop by using compressed air in a can or an air compressor, the compressor is the pefered choice (max air pressure 90 psi).
Blow the air into the fan discharge of the laptop, (be sure not to overspeed your fan) then blow the air into the intake of the fan.
Do this a few times until you have no more dust in your laptop.
Then see if that cooled it down, if not maybe your fan is faulty and not cooling properly.
You can also put a cooling pad with fans under the laptop to help cool , they have the laptop coolers with usb power.
Please take time to rate me thumbs up
Sep 11, 2011 | Fujitsu Computers & Internet
I have a '96 mitsubishi 3000GT and it keeps over heating. I've had the thermostat replaced twice and am constantly changing the oil. what could be wrong?
I would make sure that when it gets warmed up that the cooling fan is kicking on.If not I would try changing the coolant temp. sensor on the engine for the cooling fan or test the fan to make sure the fan is still good.The fan should be mounted to the radiator.
Feb 16, 2010 | 1996 Mitsubishi 3000GT
Beeping sound coming from control panel model#10656562400
Hi!
Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause which can't be lubricated or repair instead required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 01, 2009 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Wont change mode
changing mode all the time, beeping all the time, sounds like my wife - slap it!!
Jul 10, 2008 | Maytag Chassis Built-In Air Conditioner...
Fan in cooling compartment
The fan inside the unit should run all the time, this insures a more constant temp throughout the compartment by keeping the air moving.
May 28, 2008 | Carrier Beverage-Air UR30GEFD Beverage...
Asrock P4i45gv motherboard problem
it sounds as though your cmos chip is damaged; if you are unable to get as far as the bios when pressing F2 or Del on boot up, then you may need to replace the motherboard. Also reseat your memory as that is another cause and check the Cr2032 cmos disc shaped battery as this may be flat and the original cause of constant reboot cycle. Lastly this also happens if you have changed any hardwre in your pc as windows will not boot if there have been major changes to hardware and windows will have to be repaired using your XPcdrom.
Aug 22, 2007 | Asrock P4I45GV R5 Motherboard
Frigidaire Compact Air Conditioner Logo
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
