Question about Garden
Preasure screw for gilmore greenlawn sprayer model 010pexg
If my sprayer is plugged lint? cat hair?then how do I unplug it? I still haven't figured out how the squeeze trigger works. Can't see how it can contact the sprayer.
There is a clear cover over the suction head that is held on with 2 screws. Remove the screws with a philips screw driver and the cover will remove providing access for cleaning. Refer to your owners manual which provides this info with a photo I think. Reinstall in the reverse manner. Be careful not to over tighten the screws as you could strip the threads. So to reassemble do not use an electric screw driver or drill type screw drive.
Jun 10, 2016 | Bissell ProHeat Turbo Deep Cleaner Upright...
Why won't the bottle screw into my sprayer?
Its like putting a cap on a bottle.. If it doesn't go on its eigther a) cross threaded or b) the wrong cap or c) user error
Jun 05, 2014 | Scotts Miracle Gro Liquafeed Sprayer 6...
It will not spray
Your pump cam follower may be broken, such that the pump is just not working. Good news, you don't need to buy any new parts. If you open it up and find that the cam follower plastic tabs are broken, Gilmour provides a second set of 2 cam followers on the other side of the cam follower assembly. Just remove some screws, reverse the assembly, and you are back in business. Since the higher the wheel speed the more stress there is on these tabs, I would not recommend moving the wheels any faster than what occurs with a slow walk.
See photos at:
http://s911.photobucket.com/albums/ac317/vonoretn/Gilmore%20Wheelpump%20sprayer/
Jun 04, 2011 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
My gilmour wheelpump sprayer just quit spraying. It appears to not be building up pressure. I have cleaned out the valve and screen on the bottom, removed and rinsed out the hollow oval 'ball'...
Your pump cam follower may be broken, such that the pump is just not working. It happened on mine. You don't need to buy any parts. If you open it up and find that the cam follower plastic tabs are broken, Gilmore provides a second set of 2 cam followers on the other side of the cam follower assembly. Just remove some screws, reverse the assembly, and you are back in business.
See photos at:
May 11, 2011 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
My 5 litre sprayer was taken from out the front & we found it two streets away with the screw on cap missing; can it be replaced?
If you can come up with a model number I may be able to find your cap. No promises but I will certainly give it my best. I realize this is only a 5 liter sprayer and most likely powered by a hand pump for an air supply. The hardware may or may not have spare parts for your sprayer. However there is a good chance we can locate a cap for you on line.
Kelly
Mar 23, 2011 | Aqua Garden
I f u can give us service center her in manila thank you
ASUS Philippine Call Hotline:1800-1441-0573 (10:00-21:00 Mon. ~ Fri.)
Please call:+63-(2)-636-8504 if you use mobile phone.
Asusworld Megamall
+63-(2)-6382955 (10:00-22:00 Mon. ~ Sun.)
SM Megamall 4th Floor Cyberzone Bldg. B Mandaluyong City
Tekzone Makati
+63-(2)-8128976 (08:00-18:00 Mon. ~ Fri. / 09:00-12:00 Sat.)
7185 Export Ave. corner Chino Roces Makati City
Tekzone Cebu
+63-(032)-4227510 (08:30-18:00 Mon. ~ Fri. / 09:00-12:00 Sat.)
E-14 J Kings Warehouse Complex Hernan Cortes Mandaue City
Servimax Technologies Inc.,
Unit G, Gilmore Commercial Plaza
#10 Gilmore Avenue, New Manila Quezon City
Phone: (+632) 721-9102 and 722-2992
Fax: (+632) 721-6819
Schedule 10:00 - 19:00 Monday to Saturday
ASUSWorld Virra Mall
4th Level VMALL Plaza Greenhills, San Juan, MM
Phone:+632 584-2612
Schedule 10:00AM - 20:00PM Monday-Sunday
AW Gilmore Zone
3/F Gilmore IT Center Bldg., #8 Gilmore Ave., cor. 1st Street, New Manila, Quezon City
Phone:+632 994-3696
Schedule 10:00AM - 19:00PM Monday-Sunday
SUWERTE,
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 24, 2010 | ASUS Computers & Internet
My new sprayer will not pick up the solution.
Terry - I did the same thing and am frustrated. Anxious to see the answer. I have tried "backflushing" per instructions, and running yardtrimmer line up the nozzle to check for debris.
Siphon just does not work. Even with clear water.
May 26, 2010 | Garden
Weee killer leaks from my Gilmour sprayer finger
Im pretty sure that is all it is. The pressure is by how many times you pump it up. Its just on or off. Sounds like It needs to be cleaned real good, and put soap in it befor you put it bak together. Also there is a screen if you hold the handle and turn the trigger part and unscrew it.
May 10, 2010 | Gilmour 1 Gallon Lawn & Garden Spray Tank...
Driver side windshield sprayer weak. Passenger side s ok.
Use a straight pin to clear the sprayer hole. There is possibly a piece of trash or rock that has settled there but not causing enought back preasure to push itself out.
Apr 29, 2009 | 1999 GMC Suburban
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
