Question about Dryers
Ge dpgt750 Why the light went out
    Top Expert:
  • 12,223 Answers
Test the main control board. God bless you
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Posted on Jul 10, 2013
My GE dpgt750 dryer will not power up sometimes, but if I unplug the unit for a period of time it will come back on.
I replaced my thermistor heat sensor in the back and it began to work immediately, then after 4 or 5 loads it repeated the same problem. The next time I got it to run I made sure to run it only at 3/4 temperature or lower and was able to keep running all day. Is there something I am missing with this fix? David
Nov 21, 2011 | GE Profile Harmony DPGT750EC Electric...
I have a GE profile dryer dpgt750 and it will not get hot only stay wsrm
you need to access the cycling switch and the sensors in the dryer heater/blower housing and possibly replace the drying sensor bars by the door on the unit
Oct 03, 2010 | GE Profile Harmony DPGT750EC Electric...
I have a GE DPGT750 Gas Dryer. The dryer will not heat up. Air is blowing out of the exhaust outside. However, the air is cold.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 28, 2010 | GE DPGT750GC Gas Dryer
I have a GE Profile Harmony Dryer DPGT750. The machine makes a loud, almost grinding noise when the dryer is operating. It also sounds almost as though the drum is out of balance. It is more noticeable...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 26, 2010 | GE Profile Harmony DPGT750EC Electric...
I have a G.E profile dryer dpgt750 cant seem to figure out how to take off the back panel, the dryer is making a loud noise sounds like possible belt problem. any ideals? THANKS MARTY
Marty, you need to remove the front cover on these and most dryers by removing lower front kick panel screws, then remove the front cover and then you access the top cover screws to remove top cover then you can access th drum belt
Nov 17, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
GE DPGT750 Gas Dryer runs but no heat
if your blower motor isn't getting up to speed it won't heat.check troubleshoot mode by holding my cycles and help at the same time for three seconds.may need a new blower motor
Mar 09, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
GE DPGT750 not heating
check your email this manual will take you step by step thru the repair
Jul 02, 2008 | GE Profile Harmony DPGT750EC Electric...
Need Help
Have you tried unplugging it for 3 min? That will reset the computer. If that don't work you might need a new touch screen \ computer
Jun 29, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
51 people viewed this question
Top Dryers Experts
