Question about Dryers
Dryer shutd off.
Whirlpool dryer. Motor is making slight humming noise. Shuts off periodically.
    Top Expert:
  • 12,223 Answers
See the next steps and fix it. God bless you
Not all will apply to every dryer. Check our video page for more style dryers.
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. You will need to disassemble the dryer to check these. Some dryers use rollers in both the front and rear.
Belt
The Belt should be replaced if you hear any noise coming from it or if there is any cracking, glazing, or grooves worn out.replace the belt along with the idler pulley.
Idler pulley
Dryers have a tension or ideler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace the glides and bearing houses if necessary. Put hand inside drum near front and push up there should be no play.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace the rear bearing when they're worn. Put hand inside drum near rear and push up there should be no play.
Blower wheel
Your dryer's blower whells pulls air over the heat source, through the clothes drum, and past the thermosta ts, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace the blower whell Many times the blower wheel is making the noise and it is commonly mistaken for the motor.
Motor
The motor may be making noise. The easy way to check is to remove the belt and turn the dryer on if it is noisy replace the motor
Posted on Jul 09, 2013
Whirlpool gas dryer Model GGW9200LW0. tumbler will not start everything functions as usual but the motor makes a humming noise and the tumbler will not turn.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 13, 2011 | Whirlpool GGW9200L Gas Dryer
My Maytag dryer (model no. 3758AYW) makes a loud humming noise...otherwise it works. Vent was disconnected and it still hums continuously when turned on. This is supposedly a "Quiet Series 200".
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
This often indicates that the motor is going bad...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 17, 2010 | Whirlpool LER5636P Electric Dryer
Kenmore frt ld dryer, motor hums ,shuts off, does not trip brkr
see it all the time,the motor is getting to weak to start,that's why you get the hummming sound sometimes,you can check your locak used appliance store or maybe ebay has one,your model number is inside the dryer door,to sum it up it's the motor,let me know now you make out-mike
Apr 11, 2009 | Kenmore Dryers
Whirlpool Estate Dryer not working
Sounds like the motor has seized. Try manually turning the drum with your hands. Is it hard to turn? If it is then the motor has seized up. If not, the windings in the motor may have shorted. Hopefully this answers your questions
Apr 08, 2009 | Whirlpool Dryers
Humming noise, runs and stops thru out drying process.
You have a motor that has a thermal overload built into it. This is for the dryer's protection. My best guess is to replace the motor. But before you do all that, make sure the wiring is good from the receptacle to the controls in the back of the dryer. It could not have a good connection thus causing this noise.
Jan 29, 2009 | Whirlpool LER5636P Electric Dryer
90 series dryer wont start
first check and see did any clohes fall down in the blower wheel,,from fillter no...check the belt that its not jammed,,check your idler wheel ...always unp[lug unit first.....now we will check motor ,turn unit on if you get a humming for about 10 to 15 seconds than a click,,replace motor
Dec 25, 2008 | Kenmore 63942 Dryer
Gas dryer makes loud hum
Sounds like you may have a motor issue, they can get lint trapped inside, and it causes the motor to overheat, and eventually go out. You can remove the top, then the front, and see if thats the problem. Usually, once the motor starts making noise, its time to replace. Right now, the packings in the motor are cold, and once they heat up, they stop making noise, so it could last quite a while.
Nov 16, 2008 | KitchenAid KGYS850LT Gas Dryer
WHIRLPOOL GAS DRYER MODEL LGR7646E
sounds like your motor is bad or the start relay on motor.. dont think you can replace just the start relay on that motor
Nov 06, 2007 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
62 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
