Question about Car Audio & Video
I can't hear sound/music from my IPod. I've tried plugging it in the iPod cable an USB cable. The screen shows that it's playing but I can't hear anything
Make sure your volume is turned up on your ipod and in the car make sure nothing else is playing. Also check your instruction book and if all fails take your car back to where you bought it from and explain what has happened also make sure it's properly pluged in!
Posted on Jul 26, 2013
imseth85
  • 30 Answers
SOURCE: Jensen VM 9311 iPod Classic
The new ipod will not work with anything other than 2008 alpine products. Apple embedded a chip in the actual cable that tells the ipod that it's ok to pay. What you need is an authentic apple video cable that can only be purchased at the apple store...then hook the inputs up to the video input on the radio.
Posted on Mar 31, 2008
  • 146 Answers
SOURCE: jensen vm9412 and ipod classic
The newer generation iPods don't always work with the iPod connection kits in a lot of the car stereos. Some of the problem is due to the fact that the new generation iPods have been changed and the stereos were manufactured before the players were released so they are not compatible.
I bought my girlfriend a Pioneer car stereo with an iPod control cable, and it works fine with her Nano (not the new generation Nano) and it works with my iPod Photo 60 GB but it does not work with my iPhone 2G and I read that it is not compatible with the new Nanos or the Classics. Check with Jensen to see if the model you have is compatible with the Classic and see if there is a solution to the issue. It may not be compatible with the new video portion of the Classic firmware.
Cheers
Posted on Dec 29, 2008
SOURCE: Pioneer AVH-P4100 Ipod Video not playing
You have to set up the AUX output.
1. Touch the source icon and then touch "OFF" to turn the unit off.
(The unit will be in demo mode)
2. Touch the screen to display the touch panel keys.
3. Touch AV Menu you should see "Inital Menu" and touch it.
4. Touch AUX 1 on the inital menu to select desired setting.
5. Touch it until Ipod is selected (make sure you have the CD-IU200V connected.
6. Touch ESC. Ipod video should work now.
7. See Page 50 in Operation Manual for more information.
Posted on May 22, 2009
SOURCE: Can't play iPod movies on my JVC KW-NX7000
You will nee a KS-U20 Lead from JVC to make videos work.
Then use the AV to view them.
Posted on Jul 22, 2009
Testimonial: "Thanks much."
  • 69 Answers
SOURCE: Pioneer x910bt. no sound with iphone/ipod
if you are using the av ipod cable that plugs into the usb and the red,white,yellow rcas, you will have change a setting in the audio section for the audio to work, if you go into the AV settings, the first option with say AV1 input, press it until it changes to IPOD. you should then have audio, if that doesn't work, the the rcas are improperly connected to the radio. hope this helps
Posted on Jan 02, 2010
My ipod wont show up on the bar when i plug it in the itunes
Sometimes your iPod fails to display in iTunes, which will keep you from being able to transfer songs from your computer to your iPod. If this happens, there are a number of steps you can take to resolve the issue.
Is it the iPod? Your iPod could fail to show in iTunes for a variety of reasons and this issue can be resolved by something as simple as rebooting your iPod. To reboot your iPod, first lay it on a flat surface. Using your thumb and index finger, press the play and menu button at the same time. If done correctly, your iPod screen will go blank and then you'll see the Apple logo. Is it the USB cable? Your iPod could fail to show in iTunes if you are using a defective USB cable. Try connecting your iPod to another computer that has iTunes installed using the same USB cable. If iPod again fails to show in iTunes, replace the USB cable. Is it my computer? One of the most common reasons your iPod doesn't show in iTunes is because your computer doesn't recognize your iPod is connected. Troubleshooting your computer/iPod connection Disconnect your iPod from the computer and reconnect. If your iPod still doesn't appear in iTunes, disconnect your iPod and reboot your machine. Once your computer has restarted, reconnect the iPod. Is it iTunes? Your iPod could be fail to display in iTunes if there is a issue with your iTunes program. If there is a problem with iTunes you can try updating the software to the most recent version. If that doesn't resolve your problem, re-install iTunes. b> http://www.itunes.com/ b> http://www.apple.com/support b> iPod Won't Connect to iTunes b> Apple's iTunes software contains mechanisms specially designed to sync with your iPod, allowing you to transfer music, videos and other media from your computer. If you find that iTunes does not recognize or allow you to access your iPod, then you cannot perform some of the device's most fundamental functions. Fortunately you can often resolve this problem without expensive maintenance, simply by doing a bit of troubleshooting and determining the cause of your connectivity problem.
Try resetting your iPod. Apple recommends this as a first step in troubleshooting an iPod not appearing in iTunes, since a quick reset will often restore functionality. If you use a click wheel iPod, hold down the "Menu" and center buttons until the Apple logo appears on your screen. For the iPod Touch, hold your "Home" button and "Sleep" button simultaneously until the Apple logo appears. Charge your iPod battery. If your battery has absolutely no power left, your iPod will often remain unresponsive even when plugged into iTunes. Try charging for three to four hours and then try connecting again. Plug your iPod into your computer using a different USB port. Sometimes a failed connection can mean you have a faulty USB port, so try plugging your USB cable into a different port and see if the iPod appears in iTunes. Verify that you have the latest version of iTunes. Visit the iTunes page Apple.com and check to see the latest version available. If you do not know which version currently runs on your computer, click "About iTunes." For Mac users, this option will appear under 'iTunes" on your menu bar. For Windows users, the option will appear under "Help" on your menu bar. Download the latest version of iTunes if necessary. Reconfigure your iPod service. If running iTunes on a Windows computer, click "Start > My Computer > Manage," and select "Services and Applications." Under "Services," select "iPod Service" and click "Stop." Leave the window open and connect your iPod to your computer. When your iPod shows up on your computer, click "Start." Reinstall iTunes. If simply updating iTunes does not work, you may have defective software. Try removing the program from your computer and completely and reinstalling it.
Jan 29, 2013 | Apple iPod touch
I have a new ipod classic 160GB which I am trying to connect to a 2010 Ford Focus via the USB connection. When I connect using the same USB lead that I attach to my laptop the radio screen shows track...
Hi Ben3230, I have the same problem with my ipod nanno (2nd gen). If I connect the nanno up to the usb socket in the centre console of my 2010 Ford Focus, the tacks display on the screen but no sound. I purchased a 3.5mm jack and connected that from the ipod to the 3.5mm jack in the centre console (as well as the usb lead) and suddenly music. Hope that solves your problem.
Jan 12, 2011 | Apple iPod nano
How to get videos on ipod to play on screen.
well, why not try Daniusoft iTransfer. it alway works well for me. many of my friends are using this product. i think it meets your needs.
it has the following features:
1. Transfer videos and music to iPod/iPhone directly .
2. Transfer video/audio files from iPod/iPhone to PC. (then you can play videos on the player screen)
3. Transfer iPod/iPhone videos and music to iTunes.
Hope this may help you. have a good day.
Apr 22, 2010 | Phase Linear UDV9010 Car DVD Player
When I plug my iPhone into the USB it doesn't
ANSWER: The headphone jack will not charge your iPod. Only the USB will charge your iPod. However, the headphone jack will play music, but the USB will not play music from your iPod.
REASON: The headphone jack does not provide any power to charge your iPod. It isnly has enough power to recieve a music signal.
REASON WHY YOU CANNOT PLAY IPOD THROUGH THE USB: The USB is only intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files. The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
TO PLAY MUSIC FROM USB (NOT IPOD): You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
SOLUTION: To charge your iPod, you need to plug it into USB. However, to play music, you need to plug your iPod into the headphone jack.
Good Luck! - Chris Proia
p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
Aug 13, 2009 | Dual Electronics XDM6350 Car CD/ MP3...
I own an Apple Ipod video which I bought in 2006. It worked just fine for about 9 months at which point I could not get any sound(music) from the headphones or when plugged in via the usb dock to my car...
If all your music is in iTunes, format and restore the iPod to a Mac formatted iPod in iTunes. There are some firmware updates as well, which restoring will give you, and these should help. After doing so, iTunes will copy all your music back to the ipod.
Dec 11, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod nano screen and music keep locking up
Please dont take your ipod along with you. May be it doesnt like to cme out for running
Jul 14, 2008 | Apple iPod nano
Ipod wont play music / No sound
The clicker noise you hear is separate from the audio output functionality of the iPod. It sounds like an issue with the headphone jack possibly. Try a soft reset by pressing the menu and center buttons at the same time for 5-7 seconds.
If that does not work, then please consider the FREE Diagnostic Testing that we offer through our website. It will cost you virtually nothing to have us diagnose your issue. Our company is staffed with formed Apple Techs and we are an Accredited Business with the Southern Colorado Better Business Bureau (BBB).
Regards,
Rick
EverGreen Electronics
'Eco-Friendly iPod Service, Sales & Recycling'
E-Mail: sales@evergreenelectronics.com
Website: http://www.EverGreenElectronics.com
FREE Apple iPod Technical Support - http://www.iRepairGuide.com
Jun 09, 2008 | Apple iPod nano 3rd Generation
Car Audio & Video Logo
172 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
