Question about Refrigerators
Can I run a 110v compact fridge on 12v with a power inverter
  • dave Jul 10, 2013
    Yes I do. So basically my question is : with the correct inverter, would it be a practical application for use in a camper rather than spending upwards of $600 for an actual camper unit?"
  • dave Jul 10, 2013
    I answered in the wrong area (testimonial) So I'm still wishing to hear your input
  • Refrigerators Master
  • 15,950 Answers
Yes! Do you know the wattage
Posted on Jul 10, 2013
Testimonial: "Yes I do. So basically my question is : with the correct inverter, would it be a practical application for use in a camper rather than spending upwards of $600 for an actual camper unit?"
I shut down the fridge. Not getting any power to it now. I have checked breakers and fuses. There is power to 110 outlet where it plugs in. No power to gas valve. What do you think the problem is?
Your Norcold refrigerator is powered by 12V DC, not 110V AC. You need to check input power at the power board. If the fuses are good and you have good 12V to the refrigerator, check to see if you are getting 12V past the 5amp fuse on the board. If not, you may have a bad board. Norcold Power Circuit Boards for Sale The Norcold Guy
Jul 12, 2015 | Norcold Inc Norcold 1210IM Refrigerator
Greenlight but no ac out
voltage regulator is bad. Most likey bad caps.
May 16, 2013 | PowerBright Power Bright 2300 Watt Power...
I bought a LG Plasma TV RZ 42 PY 10X in in Italy where it is 220V 50Hz and now live in Mexico where it is 110V 60Hz. Although the TV Data states it's working range is 100 to 240V and 50 to 60Hz after a...
You need a power supply adapter. Might I suggest a 12v dc converter/inverter? The upside is that, for the money, you also get backup power to run your tv! Bonus!
You will need a good sized 12volt battery that will charge off of 110v house current and then the inverter will cover the rest. If the power there is bad or drops cycles you have everything covered because your inverter/tranformer does it all. Nice!
Here is the link to a website that sells these kinds of power supplies.
http://www.110220volts.com/Sub3/220inverters.html
Oct 11, 2010 | LG 42LC2D 42 in. LCD HDTV
How to convert electricity from 110 to 220 volts for my SHARPE Microwave oven
Ah, the problem of the ages. There are 2 solutions. One is a transformer of the proper size, and the second is to purchase a heavy duty battery charger (that runs on 220 volts). Connect the red and black (+ and -) wires to a 12v to 110v voltage inverter, similar to what you would plug into a 12v auto 'cigarette lighter' socket to produce 110v current from a car battery. The charger turns the 220 vac to 12 vdc, and the inverter turns the 12 vdc into 110 vac. This works, as it is what I did when I moved from the US to England.
Feb 04, 2010 | Sharp R-230 Microwave Oven
Reddy Heater 70 (Kerosene) won't start
In the same temperature range that is giving you trouble, run an ext cord (110v) from a known good household circuit and plug the heater into the cord. If the heater runs OK, then the inverter is your problem.
Jan 05, 2009 | Reddy Heater-30-55,000 BTU Variable
Conecting to 120 volts AC
If you want to get more precise, figure out everything in terms of power (watts).
Basic electrical rule 1, 2 and 3:
voltage x current = power
or re-arranged:
current = power divided by voltage
or re-arranged:
voltage = power divided by current
For example, 12V X 2 amps = 24 watts.
or another example, 400 watts divided by 120 Volts = 3.33 amps
A 55W headlight that uses 12V would draw 55 /12 = 4.6 amps @ 12V
A 55 watt light bulb in a lamp at home would draw 55 / 120 = 0.46 amps @ 120V
As the previous post mentioned, inverters are not perfect when convertering 12V into 120V. If the converter consumes 1000W from the 12V battery, then a 90% effecient converter would generate 900W of 120V AC power best case. The other 100W is lost primarily as heat.
The other thing that gets tricky is that these ratings and the formula above are used for resistive loads, like light bulbs or hair dryers. Anything with a motor or transformer is considered an inductive load and can get much more tricky to calculate.
Consequently you need to give your self a safety margin when figuring out how big an inverter you need.
How does work in a practical sense?
Lets say you want an inverter for TV, DVD and Sat. Receiver. Look at the back of TV or in the manual. It should say how many watts it consumes. Lets say it is 400W. The DVD might be 100W and the Sat. receiver 50W - just as an example.
400 + 100 + 50 = 550 Watts. (just as an example)
You might think, well no problem, I'll use a 600 Watt inverter and have 50 watts left over. Depending on your inverter, that 600W might really be 600 x 90% effecient = 540 Watts of AC, less a 20% margin of error for the inductive transformers in the electronic of the TV, DVD and Sat. receiver 540 - 20% = 432 Watts.
Now you can see your 600 Watt inverter isn't big enough to do the job.
If we really need 550 watts of AC, add 10% to make up the effiency loss, then add a safety margin for inductive loads.
550 + 10% = 605 + 20% = 726 Watts.
Sounds more like an 800W inverter fits the job.
What does that mean in terms of wiring the 12V batteries to the inverter?
from the formula above:
In our example, we have an 800W inverter that runs on 12V
The current would thererfore be:
current = 800 watts divided by 12V
current = 66 amps.
That is important info because you can not use light gauge wire to carry 66 amps worth of 12V to the inverter nor could you use a 20A fuse to protect your inverter.
Now that's a lot of science for a guy who just wants to run a toaster on an inverter right?
800W / 120V = 6.66 amps
Using garryp's ratio 11:1, 6.66 x 11 = 73 amps.
That is a good ratio with a good safety margin.
This is all just MHO and should not taken as solid technical advise. In other words, don't blame me if you blow yourself up.
Nov 26, 2008 | Coleman 5640B807 Compact Refrigerator
Can i use a dc adapter in my van for my compaq notebook
Yes, there is a way to do this. It's called an "inverter" and what it does is convert 12v/24v to 110v/220v - you can get them from most electrical retailers and increasingly from car parts retailers as well.
The little inverter box will provide you with one or two standard sockets, into which you can plug your notebook power supply normally.
BE CAREFUL about how long you use one without the engine running, though, as changing the voltage that far draws heavily on the vehicles battery.
May 26, 2008 | Compaq Computers & Internet
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
