Question about LG Televison & Video
Can my tv explode
Why am hereing a frying sound low or high
    Top Expert:
  • LG Master
  • 75,581 Answers
Hi, It won't explode at all. Do not afraid of it. Contact any service technician to track out the present problem to your TV.
Posted on Jul 10, 2013
Heater/air conditioner motor
It's probably the fan resistor for low speeds that fried.
Here's a video on how to replace it on a Volvo V70.
Jul 31, 2016 | 2000 Volvo V70
Where do I put the freon into
You didn't say what year but here is what you are looking for.
The Low Pressure Service Port has a Larger diameter than the High Pressure port. The High Pressure port will cause the freon can to explode if you connect to it.
Nov 14, 2014 | Geo Tracker Cars & Trucks
50 " DLP makes a high pitch squilling sound and shuts off several times
Check and replace its color wheel. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 10, 2014 | Samsung DLP HL-P5663W 56" TV
My sony rear projection tv's red light started blinking 8 times, so I removed the high vltage splitter, so I needed to test the block. And you guys are sugesting for me to turn on the tv, now do I
Turn on very briefly and make sure the large red wire that entered the block is well away from any metal---if hear a frying sound and blink sequence is gone the block is bad( I used to put the wire into a old soda bottle as it has over 20 thousand volts coming out of it, much like the spark plug wires in a car---high voltage with low current.
Nov 01, 2012 | Televison & Video
TV turned on, heard loud pop. Now screen is very dark.
It sounds like the actual tube / lamp inside the unit has exploded. You will need to either get it repaired at a local TV repair shop or replace the TV. Unfortunately with that unit it is probably cheaper to just replace it.
Jul 27, 2010 | Akai PDP4225M 42 in. Plasma Television
Kenmore spacemaster will turn on, display appears to work, but food will not cook. Unit makes low whirring noise dissimilar to the standard noise. John
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
Here are some links you or someone you know can use (in order given) for high voltage section test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
You can find handy exploded views at the Sears Parts Site.
BUT once you have the part number from the Sears site, you can often get the parts cheaper
here.
Jan 09, 2010 | Kenmore Microwave Ovens
Samsung hc-p4752w
look for trouble in the low voltage and or high voltage power supply circuits. the popping sound could be an exploded safety capacitor in the horizontal output to the flyback transformer. the horizontal output transistor maybe damaged. chances are the low voltage regulator is also damaged.
Aug 11, 2009 | Samsung HC-P4752W 47" Rear Projection...
On/off sound
hi
What sounds like? Like a frying pan? a high voltage sparking? or what?
Thanks!
Dec 27, 2008 | Curtis CM32020S 32" TV
When turn on no picture and there is a high pitch buzz or frying. Then after a minute or two it will shut off by itself. Before thid happened the picture would come on slowly with a frying sound and then...
my first instinct in this is flyback transformer. or if it is three tube projector could be a high voltage splitter lines in picture sound like what is called retrace lines ... this is another indication of a possible bad flyback. high pitch sound is another sypmpton of a high voltage flyback transformer problem. WARNING televisions generate potental lethal charge. the device called flyback is used to generate several THOSAND volts. so be carefull if you take the back of any television. along with the flyback the horizontal output transistor possible could have failed. What type of tv is it? model
Oct 01, 2008 | Televison & Video
Tv will not turn on but makes a beeping sound
better take skilled tech person  help as it is high voltage problem.
Oct 14, 2007 | RCA F36668 36" TV
Televison & Video Logo
21 people viewed this question
