Maytag performance top load washer
The washing machine first started making a noise when spinning. Sounded like a garbage disposal. I lifted the lid and started it again. The tub stopped spinning and I could spell a burning smell. Now it won't do anything. And there were fine white shavings all under the washer. Please help! Thanks!
    Top Expert:
  • Washing Mach... Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
  1. No power to the washerMake sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
  2. Lid switchThe washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defective.
Read more: http://www.appliancepartspros.com/repair-help/washer-repair-help.html#1#ixzz2YbiV2et5
Posted on Jul 10, 2013
catriver
  • 878 Answers
SOURCE: Drain/Spin won't work unless lid is lifted up
Curdy, it almost sounds like your lid switch is loose or fractured and the lid actuator is not making the switch. Check this out first and post back...Catriver.
Posted on Oct 20, 2006
  • 641 Answers
SOURCE: Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Posted on Jul 26, 2007
SOURCE: MAYTAG WASHING MACHINE
The rubber smell is the belt from the motor to the tub. The grinding sound is/was the tension pulley that keeps the belt tight. The bearing on the pulley probably went out and now the belt is burning because of the friction of sliding around the pulley. The belt and the pulley need to be replaced. If you have the room, turn off and disconnect the hoses. Unplug the electrical cord from the wall outlet. Remove the drain hose and any water in the tub. Carefully tip the washer over backwards, DO DROP IT!!! Now you should be able to see the motor, tub, tension pulley, and belt. With a basic 3/8' drive socket set, probably metric, and a couple of screw drivers you should be able to remove the belt and the pulley. Take the belt, pulley, and model numbers to an applicance parts store and buy replacements.
I only suggest this because I hate paying labor. If you are not machanically inclined then you are going to have to pay the labor.
Good Luck
Posted on Dec 19, 2007
onthejob5130
  • 640 Answers
SOURCE: maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Posted on Jan 03, 2009
  • 9 Answers
SOURCE: Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Posted on Jul 02, 2009
Amana NTW475OYQ1no lights or sounds. Verified power @circuit board. Someone closed lid on a shirt earlier that preventing lid to I open.verified switch waz working and the wife did a load of laundry.
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following ... Speed Queen, Amana Whirlpool ..... Lid lock lightflases; no spin cycle.
Amana Washing Machine NTW5400TQ1 Troubleshooting ...
www.repairclinic.com/.../Washing-Machine...-/Amana-Washing-Machin...
Amana Washing Machine NTW5400TQ1 Troubleshooting & Repair Help. Amana Washing Machine problems. Washer won't spin · Washer is making loud noise ...
Jan 16, 2016 | Amana Washing Machines
When my washer spins or if you lift the lid before it is finish it makes a very load banging noise. PLEASE HELP
That is the braking mechanism in the transmission. Not usually worth fixing but will probally last quite a while.
Jun 11, 2010 | Maytag Dependable Clean Top MAV5920EWW Top...
My maytag washer makes a clacking sound when it spins or aggitates
Use a wedge of wood or a non marring tool to lift the front of the top cover and tilt it back on the hinges. Be careful of the load lid when lifting it back so it will not fall freely back making a loud noise. On each edge of the washer there are support rods in rubber shock absorbers. My guess is the rubber is deteriorated and you need to order new ones.
Jan 21, 2010 | Maytag Washing Machines
Washer will spin but won't drain automatically
are you sure it spins? usually something is in the pump like a sock. You could remove the front and take the hose off the pump to see if its clear. It also sounds like it could be the lid switch. if you have to close it make sure you hear a clicking noise from the lid switch.
May 14, 2009 | Maytag Washing Machines
Top loading Maytag washer Model #A9700 washer fills with water then stops, no washing, no spinning
When the machine worked would the machine stop in the wash cycle when you lift the lid? If so you might check your lid switch.
Jul 16, 2008 | Maytag Washing Machines
Maytag Atlantis washer will not drain and spin unless you lift the lid
The cheaper thing to check first is is your lid bent? The lid switch is in the center of the lid. If it "droops" or has been bent, it shaft on the back of the lid cant hit the switch. Open the lid and apply pressure in the bottom, center of the lid. This usually corrects the problem without replacing the switch.
May 31, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Oct 19, 2006 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
