Question about Maytag Neptune MAH5500B Front Load Washer
Neptune Washer Problem
When i have the water turned on going to the washer i have water dripping into the inside of the washer where you put the clothes. Also, how do you raise the lid on the washer.
  • 240 Answers
To remove the lid on the Neptune, you first remove the door, taking the screws out of the hinges, then lift them out. This might take a little work. The front cover should unclip at the corners up top. Two screws out, then lift the top. The water leakage could be caused by one of the fill hoses and supply hoses (which are all over the top of unit) could have sprung a leak and has become loose somewhere. Let me know how it turns out. Good Luck!!!! Jim
Posted on Sep 09, 2007
Ive got a maytag neptune model# MAH8700AWW front load washer that water keeps dripping into the soap dispenser and filling up the tub over night about 1 to 2 gal of water and ive been looking for a repair...
Would be the Inlet solenoid (this is effectively the valve that allows water to come in - that the inlet hose screws on to, and has a couple of wires going to it on the inside).
Replace carefully, with the power shut off, or simply turn the tap off when not in use :-)
Oct 01, 2017 | Maytag MAH8700A Front Load Washer
When washing machine not being used the water drips into the washer tub, it is top loader about 12 yrs old
if the washer is filling up on it's own the water valve is bad,sediment gets inside it doesn't close all the way allowing water to leak through. they show two different valves,when you talk to your parts guy bive him the full model number off of the washer and they are asking for a series number either 83 or 87 so you get the correct valve
Mar 08, 2011 | Maytag Neptune MAH5500B Front Load Washer
Our washing machine sat outside during a hard freeze (4 days without ever getting above 27). We had the water lines disconnected/dripping to avoid busted pipes, but we didn't realize there was a spot for...
your water valves, you have 2. may have a crack due to the freezing. they retain water inside. you have to take appart or lift the top of the washer to inspect the water valves. the main valve is the one you connect the fill hoses. the other is the one on the dispenser.
Feb 08, 2011 | Maytag Neptune MAH5500B Front Load Washer
Neptune MAH 4000AWW works good but some whater is left
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
Apr 11, 2010 | Maytag MAH6700AWW Neptune Front-Load...
When the washer finishes the spin cycle and I open it up to remove the cloths, the water continues to drip into the drum. What do I need to do to repair this problem.
It sound's like the water inlet valve is stuck open, it's located at the back of the washer, the cold and hot water hose's connect to it, you may need to replace it with a new one to fix the drip.
Apr 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
"nF" error code at end of cycle, and water leak
nf means u have a bad water valve u may also have a bad hose underneath the lid as well if u have water in your control
Mar 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Leaking Washer Machine
this is joyce
This sounds like a center seal kit, they run around $80.00 they are complecated to install so I would suggest getting someone to install for you.
thanks,
joyce
Feb 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water left pooled inside maytag neptune front loading washer
Possible explanation: Some water is left in the hose going up to the drainpipe b/c the pump can only pump water with water, not air... so when the last bit of water is sucked up, it 'stays' just the other side of the pump exit nozzle and keeps the drain tubefilled. This water gradually leaks thru the drain exit valve and back into the machine, sometimes siphoning standing water in the drain trap with it.
The valve is either electric solenoid or plastic/rubber clapper in a cylinder. Your call whether to fix or not depending on ease and cost. Probably a $20.00 part.
Cheers!
Jan 27, 2009 | Neptune MLE2000A Front Load Stacked Washer...
Neptune washer
If the water is draining out o.k. then either there is no signal from the water level pressure switch, no signal from the control board or a problem with the Spin windings.
Mar 11, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
78 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
