Question about KitchenAid KHWS01PMT Front Load Washer
Replacing the Faulty Door Latch
I have a KitchenAid Front loader washer. My question is hooking it back up. I failed to pay attention to the wiring connectors. Two of the three are white connectors that are identical -but one is with blue wires and the other is with black wires. can you tell me which connector applies to the top position? is it the blue or black wire connector? Door latch PartNo. is 8182634 for Model:KWHS01PWH0 thanks in advance. LD
    Top Expert:
  • KitchenAid Master
  • 12,223 Answers
See the video and proceed according. God bless you
Posted on Jul 10, 2013
2 Suggested Answers
SOURCE: KITCHENAID TOPLOAD MOD KAWE777BWH1-NO
PUBLIC LIBRARY--WIRING DIAGRAM RECONNECTED ALL OK
Posted on Nov 24, 2009
My front loader LG won't spin or wash, what can I do?
(1) If the washer won't spin or agitate the door latch should be checked. The door latch can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design, if faulty replace.
(2) If the washer won't spin or agitate the rotor assembly at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects.
Feb 11, 2015 | LG Washing Machines
Tip
Replacing a Door Latch
This advice is for replacing the door latch on the Kenmore Elite, Whirlpool Duet and Maytag epic FRONT LOADER washing machines.
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate.
NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Good luck and I hope this information is helpful.
on Dec 04, 2009 | Washing Machines
Connect door latch
see the diagram attached.God bless you61423b34-70cd-4b9c-a28a-da99461204e3.gif
Jul 09, 2013 | KitchenAid Washing Machines
My front loader washer is having the error code od and will not start. What does this mean and how can I fix this?
OD: Opened Door not sensed by machine control board. in this case the lid switch needs attention. or washer door. hope this helps ! 1.Make sure door is closed. Check for loose wire connections at switch and/ or machine control board. .Check for failed door monitor switch. good-day !
Nov 14, 2011 | Maytag Neptune MAH5500B Front Load Washer
How can I get my front load washer to open if the electronic mechanism has failed? Is there a mechanical way to get the latch to pop? I can't replace the failed part unless I can get it open because...
1. Unplug washer.
The necessary actions are to replace the entire door locking assembly: Duet Job Aid (pdf)
Hope helps.
May 28, 2011 | Bosch Washing Machines
I have a Frigidaire front load washer (3.5 cu.ft.). It is not digital. All the cycles run fine. It fills, agitates, and drains the water...but, it will not spin. We checked the trap and it was dirty. We...
It's probably your door switch, as they fail often on this unit. If defective, the door switch will not allow your machine to go into spin. Replacing the switch is easy, but it's a $90 part, which is the pain. The door switch is located behind where the latch catches the door and locks the door closed, when working properly. Remove the top lid (two screws in the back) and the two screws holding the door switch, then reach down and pull it up. Pay close attention on how the wires hook up and hook up the new unit. Reassemble and watch your machine spin!
Apr 16, 2010 | Frigidaire FTF2140E King-Size ENERGY STAR
Broken door latch whirlpool ghw9100lw1
The following link explains how to replace the door latch on a Whirlpool front loader:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
This is a very simple repair. I'm surprised at the cost of the labor you were quoted. An experienced technician can replace one of these latches in 30 minutes or less.
An alternate method of the replacing the latch is the remove the top panel of the washer and work down through the top. Due to variations in design features between models, this isn't always possible. If you want to remove the top panel, just locate and remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off. If you have access the latch assembly from the top, you can attempt the repair using this method.
If you have any questions, please let me know. I hope this helps you.
Sep 02, 2009 | Whirlpool GHW9100L Front Load Washer
Kenmore HE2T front loading automatic washer...model 110.4756,4757..displaying F22 error message? What does that mean and how do I fix it?
"F22" is a door latch error. It can mean any of the following:
1. The door latch mechanism is broken. Inspect the door latch to ensure it is intact and not broken. Verify the electrical connections are making good contact.
2. The door latch hook (located on the door) is broken or worn. If the latch hook is damaged, it may not allow the door latch to engage and lock properly.
3. The interconnecting wiring between the Central Control Unit (CCU) and the door latch are loose, broken, or not making good contact. The CCU is the main computer for the washer. You will need to remove the top panel of the washer in order to access. Simply remove the retaining screws located in the back of the washer and the panel will slide back, then lift off.
4. Defective CCU. The CCU controls nearly all the functions of the washer, including the door latch. If the CCU fails, the proper lock/unlock signals do not get sent to the latch mechanism.
Determing how to troubleshoot the CCU and Door Latch is in the technical data sheet included with your washer. The tech sheet is located behind the lower toe panel directly below the door. If the tech sheet isn't behind the toe panel, it will be affixed to one of the interior cabinet walls. I do not have the procedure memorized, but there are some tests you can try to determine if the problem is the CCU or latch.
If you determine the latch needs replaced, the following link may assist you:
The procedures I provided are for Kenmore Elite series front loaders, which are the larger cousing to the HE2. The steps are nearly the same except for how to remove the door gasket from the front facing of the washer. The HE2 models are glued on instead of using a wire hoop (unless yours is a later model and has been modified). You can use a metal putty knife to carefully peel the gasket loose and reseal it when completed. A good appliance gasket cement (found at any appliance parts retailer) will work. You can also use a plumber's sealant. Just make sure you use a pliable rubber cement. Do not use super glue.
Some prefer to try to work through the top of the washer and avoid removing the gasket. This may be possible with the larger top loaders, but the smaller models are usually a bit more difficult to access.
Replacement parts can be purchased on line at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
If you have any questions, please let me know. I hope you find this information helpful.
Aug 31, 2009 | Kenmore HE2 Plus Front Load Washer
Door will not lock
its either the door assembly frame problem or the door latch problem.
This advice is for replacing the door latch on the Kenmore Elite or Whirlpool Duet FRONT LOADER washing machines.
1. Unplug washer.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
May 03, 2009 | Washing Machines
Resetting washer after the problem is fixed
Did you unplug the washer at any point while you were repairing it? Normally, to reset some minor glitches with the washer all that is required is to unplug the washer for at least 30 minutes. This will reset the CCU. If you had the power secured, the problem SHOULD have gone away with the installation of the new door latch. Unless...you purchased a defective door latch, or have a faulty wiring harness. What was the error code you originally experienced? The reason I ask, is because if this is a Kenmore Elite Front Loader as the one pictured above, there is no "lf" error code. "Fdl" and "Fdu" error codes are usually the indication of a defective door latch. Could you please post back and clarify this information for me?
Sep 28, 2008 | Kenmore Elite 45986 Front Load Washer
KitchenAid KHWS01PMT Front Load Washer Logo
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
