Question about Zanussi Washing Machines
Zanussi zwg7120k Washing machine wont drain. Cannot locate filter.
SOURCE: zanussi washing machine filter
Open the panel at the bottom right of the front of the washer. Then pull out the drain hose and pull the plug from its end - this will drain most of the water. Then the filter turns anti-clockwise - if it is too stiff to turn by hand I use an open set of pliers or strong scissors to give more grip (It may be an idea to put a cloth between the pliers/scissors and the filter to offer some protection.
Posted on Jun 21, 2009
  • 10 Answers
SOURCE: my zanussi washing machine will not drain
you must first remove as much water from the rum as you can.unscrew the filter at the bottom right of the machine (BE AWARE WHAT EVER WATER IS STILL IN MACHINE IS GOING TO COME OUT ) if this is blocked it is likeley to be the cause if not get down and look in the whole where the filter fits, at the back of that chamber is the pump impellor make sure nothing is stuck in it .If all that fails you have an electrical problem with the pump or electronic control best to call an engineer for those problems.
Posted on Jul 23, 2009
bozcro
  • 867 Answers
SOURCE: Zanussi ZWD1470W fabric conditioner compartment won't drain
fabric conditioner is dispensed during rinse cycle, if it does not work then either, try pouring hot water into dispenser, as conditioner tends to get goopie when dry, thus may have clogged up
Posted on Dec 11, 2009
dancandoit
  • 436 Answers
SOURCE: WMA46 washing machine not draining, filter blocked
the filter is underneath on the pipe going to the pump, you wiull need to remove a hose clip.
Posted on Jan 04, 2010
barkencoa
  • 3463 Answers
SOURCE: my zanussi timeline 1600 washing machine has
I suggest that you check and clean the filter.
This should be located at the bottom front right of washer behind drop down cover or flap. Unscrew anti-clockwise to remove and clean
Please rate my solution.
Thankyou.
Posted on Jan 16, 2010
Zanussi z918 washing machine wont empty or spin although the pump seems to work
if the pump seems to work, check outlet hose for blockage/check pump filter as well
Dec 09, 2011 | Zanussi Washing Machines
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
My hec washing machine wont drain help
If you have not already done so, then remove and clean filter located at bottom front right of washer behind flap.
Unscrew anti-clockwise to remove and clean.
Feb 06, 2010 | Zanussi WJS1265W Front Load Washer/Dryer
My zanussi timeline 1600 washing machine has problems draining. Is there a way to fix this easily?
Thankyou.
Jan 16, 2010 | Zanussi ZWF1650W Front Load Washer
Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
The machine wont let the water drain
Remove and clean filter located at bottom front right of washer behind small panel.
Thanks.
Oct 29, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi washing machine filter
Jun 15, 2009 | Zanussi F1245W Front Load Washer
Wont drain, wont empty, wont go onto rinse, drain or spin during
The filter on this machine is behind the flat at bottom right of machine. Tilt machine back before unscrewing to avoid spillage. If filter is clear get back to me and will explore other possibilities.
Nov 16, 2008 | Washing Machines
Filter can be clogged, pump can be dead or water outlet clogged.
Apr 11, 2008 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
562 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
