Question about KitchenAid Washing Machines
Connect door latch
I have a KitchenAid Front loader washer. the door latch produced FdU error code to the point that the typical fixes stopped working. so I removed it and ordered a replacement. My question is hooking it back up. I failed to pay attention to the wiring connectors. Two of the three are white connectors that are identical -but one is with blue wires and the other is with black wires. can you tell me which connector applies to the top position? is it the blue or black wire connector? PartNo. is 8182634 for Model:KWHS01PWH0 thanks in advance. LD
    Top Expert:
  • KitchenAid Master
  • 12,223 Answers
See the diagram attached.God bless youconnect door latch - 61423b34-70cd-4b9c-a28a-da99461204e3.gif
Posted on Jul 10, 2013
SOURCE: Hotpoint WM83 control module plug connections
Fixed it - by a process of elimination and logic :) What was worrying me initially was the fact that it is possible to fit the connectors in either position (Hotpoint!).
Posted on Jul 04, 2008
  • 958 Answers
SOURCE: WD62 programmer wiring
hi robbie,
you can slowly try each plug to every slot in the board. they are not interchangeable. they have keys that would not fit to other slots.
i hope i was able to solve your problem..please rate me...tnx
drcool299
Posted on Jul 11, 2008
  • 135 Answers
SOURCE: Front panel connections for Hotpoint WMA 46 washer
red/red = x2 black/blue = x11 black/black = x9, hope this fixes for you
Posted on Nov 17, 2008
SOURCE: KITCHENAID TOPLOAD MOD KAWE777BWH1-NO
PUBLIC LIBRARY--WIRING DIAGRAM RECONNECTED ALL OK
Posted on Nov 24, 2009
blueextc3221
  • 15935 Answers
SOURCE: Maytag front load washer GHW9200LW Fdu error
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
I have a front loader and the door wont unlock
The latch may be broken.
Here are the instructions to manually unlock...
(tip courtesy JSRock)
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Mar 29, 2010 | Kenmore HE2 Plus Front Load Washer
Whirlpool front load door handle jammd can't open door.
The door latch assembly must be replaced if an error code appears on the display prior to the jamming of the door. The code is either "Fdl" or "Fdu". Please let me know if that is the case.
There is a pull tab located at the bottom of the door latch assembly purposely for manually releasing the door by pulling it down. Here's how to access it:
  1. Lean the washer on its back against the wall.
  2. Remove the three screws under the bottom edge on the front of the washer to remove the lower panel under the door.
  3. Reach the tab with your hand up inside the washer behind the front casing on the right side and pull it down.
  4. Pull the door to open it.
  5. Inspect and clean the door latch for any material or dirt that causes the glitch.
Jan 07, 2010 | Kenmore 44932 Front Load Washer
Will not lock, seems to be in the locked position. DS pushed "something" in that should be out.
You'll need to manually unlock it.
May 26, 2009 | Kenmore Washing Machines
Lcd showing dle error..machine stops
Door Lock Error.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" "DLE" error codes, these are usually indications of a failed door latch assembly and will require replacement.
May 07, 2009 | Washing Machines
My front loader washer whirlpool codes fdu and the door won't unlock.
F/dU error means --------- Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error. -------- to resolve the error --------- Door Lock Mechanism broken. globul1a.gif Check Door Lock/Switch Assembly for foreign objects globul1a.gif Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) globul1a.gif Door Lock/Switch Assembly Failure
Apr 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Simpson front loader model 45S651D i can't open the door. its having trouble finishing cycle now it has i cant open it!
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Jan 28, 2009 | Washing Machines
After a cycle my door does not open on my LG front loader
Jan 26, 2009 | Washing Machines
Kenmore 45986 door lock
Jan 25, 2009 | Kenmore 43142 Front Load Washer
Resetting washer after the problem is fixed
Did you unplug the washer at any point while you were repairing it? Normally, to reset some minor glitches with the washer all that is required is to unplug the washer for at least 30 minutes. This will reset the CCU. If you had the power secured, the problem SHOULD have gone away with the installation of the new door latch. Unless...you purchased a defective door latch, or have a faulty wiring harness. What was the error code you originally experienced? The reason I ask, is because if this is a Kenmore Elite Front Loader as the one pictured above, there is no "lf" error code. "Fdl" and "Fdu" error codes are usually the indication of a defective door latch. Could you please post back and clarify this information for me?
Sep 28, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
