Question about Hardware & Accessories
AHC 20 amp 12 volt timer wiring diagram - Hardware & Accessories
5 Suggested Answers
  • 52 Answers
SOURCE: wiring diagram for paragon defost timer 8145-20
go to uniline.com
Posted on Feb 02, 2010
SOURCE: T104 intermatic timer being used
T104 is 208-277Volt timer.
Wiring is correct if timer worked fine before.
Quick troubleshooting:
Click manual override and see if lights turn on-off.
If manual override clicks clean and crisp, and lights turn on-off, then timer mechanism is working.
If manual override is sluggish and hard to push, and timer mechanism is rusty or dirty, then timer needs to be replaced.
Buy another T-104, swap out insides without changing box. Put wires back as before.
If the dial stops moving, then replace clock motor.
T104 uses the t-100 series 208-277 clock motor that Grainger sells for around $20
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
If the dial operates fine, the trippers may be worn out.
Grainger also sells T104 tripper
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
Posted on Nov 13, 2010
SOURCE: I have a paragon 8145-20 defrost timer. do you
Link below has wiring diagrams and wiring manuals for 240V 8145-20
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
I am not expert installing defrost timers.
According to information from Paragon, 8145 is for hot gas defrosting. 8140 series are time initiated, and pressure-or-temperature terminated.
Wiring diagram does not show compressor wired to timer.
The cycle works like this:
Timer is running but defrost is not switched ON.
Fan is ON.
Timer switches ON and activates defrost cycle.
Fan turns OFF. Hot gas valve turns ON for defrosting.
Cycle limit switch is temperature or pressure sensitive.
Cycle limit switch reaches trip point, timer switches OFF.
Hot gas valve turns OFF. Fan turns ON.
So fan is off during defrost cycle.
Hot gas valve turns ON when timer switches ON.
Timer is switched OFF by pressure-or-temperature limit switch.
Posted on Jan 20, 2011
Testimonial: "good info very helpful thank you"
ftw1952
  • 10319 Answers
SOURCE: How to wire a 12 volt DC1EJE8 Dayton Delay Timer
here is the basic hook up at the link below
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Posted on Mar 26, 2011
Where can I get a wiring diagram for a Porter Cable20volt battery
images for Porter Cable20volt battery wiring
Power Tools - Porter-Cable
www.portercable.com/20Volt
Get Linked with the Power and Performance of the 20V MAX* system of tools. Powered by a lithium ion battery platform which delivers the performance and ease ...
Shop PORTER-CABLE 20-Volt Max Lithium Ion Battery, 2 ...
www.lowes.com/pd_472386-79992-PCC680LP_0__?productId...
Lowe'sPORTER-CABLE 20-Volt Max 1.5-Amp Hours Power... ... PORTER-CABLE 20-VoltMax 4.0-Amp Hours... ... PORTER-CABLE 2-Pack 20-Volt Max 4-Amp Hours...Missing: diagram
Jan 20, 2016 | Porter Drills
How do you wire an air compressor from the wall to compressor?
Is it 120 volt only or you have a choice ?
You wire it for 240, if you have a choice
The wiring diagram is on the outside of the motor
or inside on the small cover, where the wires go to
You buy some 12/2 rubber cord & wire to the motor &
put a 240-20 amp plug on the other end
On the wall you mount a 1900 box & a cover with the
240-20 amp duplex
Aug 09, 2014 | Air Lift Air Tools & Compressors
How many 100 watt light bulbs can I hook to a 20 amp breaker (120 volts)
A 20 Amp breaker will support 2400 Watts with a 120 Volt line.
120 Volts times 20 Amps (Amperes) = 2400 Watts.
Answer? 24 100Watt light bulbs.
HOWEVER, you should always allow 1 cushion of 100 Watts.
That would be 23 100Watt light bulbs.
(Wait until you add electric motors to the equation. Things start getting a little more complicated)
(I always use 20 amp breakers for lighting. 15 amp breakers for lighting is phased out.
Secondly a 20 amp breaker requires using 12-2 or 12-3 wiring. (12/2, 12/3)
SO does the receptacles.
Therefore 12 gauge wiring is used throughout the house, until you come to the heavier loads )
[ 12/2 = 2 insulated conductors, and one bare copper ground wire.
12/3 = 3 insulated conductors, and one bare copper ground wire.
Remember, with 12/2 the Black wire is ALWAYS the Hot wire. White is Common (Neutral). Bare copper is Ground wire.
12/3 has 3 conducting wires.
One Black, one Red, and one White for the Common. (Neutral) Bare copper is Ground.
Used for 3-way switches ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 30, 2011 | Hammering
Need radio cd wiring diagram for 2005 jeep grand chrokee
120706502.jpg FUNCTION PIN WIRE COLOR Accessory 12 Volt SEE NOTE ¹ Constant 12 Volt 1,12 RD/OG (2X) Chassis Ground 11,22 BK (2X) Power Antenna Remote Illumination Dimmer FUSE VALUE FUSE LABEL FUSEBOX LOCATION 20 AMP #28 DRIVER'S SIDE UNDER HOOD ¹ The receiver does not have an Accessory 12 Volt lead, it is triggered by the data lines in pins #5 and #6. When installing an aftermarket stereo, an Accessory 12 Volt lead must be run to the fusebox to a switched power lead.
² If equipped with "Hands-Free" cellular phone system.
The dash speakers are wired in parallel with the front door speakers.
Left Front Spkr + 10 D.GN Left Front Spkr - 9 D.GN/BN Right Front Spkr + 7 GY Right Front Spkr - 8 GY/BN Left Rear Spkr + 18 D.GN/D.BU Left Rear Spkr - 19 D.GN/VT Right Rear Spkr + 21 GY/D.BU Right Rear Spkr - 20 GY/TN Hands-Free Audio ² 4
16
17 D.GN/OG
D.GN/YW
D.GN Data Lines 5
6 WT/OG ¹
WT ¹ DO NOT USE THESE WIRES!
Sep 25, 2011 | Car Audio & Video
A diagram of how to wire a 220 volt outlet from two 110 volt outlets.
You can't really do that. The two 110 outlets probably come for the same 'leg' of the 240. If you check them with a meter, there will be '0' volts between the two hot wires. So, they have the same 'potential'. You need a regular 240 volt circuit from a double pole breaker that is rated for the wire size that it's feeding. 20 amp-#12 ; 30 amp- #10 etc.
Sep 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Malibu Light Transformer ML121RT troubleshooting
1) Disconnect the plug.
2) Remove the 3 hex screws holding the cover.
3) Make a note of all connections (taking a picture is even better).
4) Connect the black power wire to the red transformer wire.
5) Connect the white power wire to the white transformer wire.
6) Set your voltmeter to 20 or 50 volts AC (not DC and not less than 15 volts).
7) Plug the transformer in the wall.
8) Test the voltage coming from the A & B connectors at the back (polarity is irrelevant).
If you see 12 volts or thereabout, the problem is with the little switch (the one with the black and red wires that is activated by the trippers on the clock dial). I have the exact same problem but I have been unable to locate the part so I am going to try to clean the contact points and see if that works.
Jun 22, 2009 | Malibu Intermatic Inc. ML121RT Low...
Intermatic T103 timer wired for 240V
yes u will, but u will have to make sure one of the motor wires are hooked up that way also, in case it has been moved, here is a link with the diagram u need
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t103%20-%20english.ashx
May 12, 2009 | Intermatic T103 Indoor 120-Volt 40-amp...
Clock doesn't work
The wiring diagram for that timer is somewhat misleading. The 120 volt clock timer motor is connected internally to the "A" (neutral) terminal and the #3 terminal. The "A" (neutral) terminal is to the immediate left of the #1 terminal.
Here's how to do the wiring for your use, (assuming a 120 volt supply circuit and a 120 volt lighting or other load):
Connect the incoming power (line) black wire to terminal # 3. Connect the incoming (neutral) white wire to terminal "A".
Connect the outgoing (load) black wire to terminal # 4.
Connect the outgoing (neutral) white wire to terminal "A".
Mar 08, 2009 | Intermatic T103 Indoor 120-Volt 40-amp...
Low voltage only or can timer be used for 110 v
1 hp= 750 watts
125 vac = 125 volts alternating current, wall outlets
5 amp= 5amps
125vac x 5amps= 625 watts
a timer is a switch with a clock on it. just like a switch in a lamp cord.
Dec 12, 2008 | Hardware & Accessories
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
