Vbsr2080woww Washer fills and drains but does not agitate or spin. belt is present
    Top Expert:
  • Washing Mach... Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
First you will need to identify if you have a direct drive type or a belt drive. The later is obvious if you have belts under your machine it is a belt drive, if not it is a direct drive. Also there are 2 basic agitator types with some variances among them. The 2 piece and the single.
Agitator Dogs
The agitator dogs are in the 2 piece type of agitator. These wear out over time. They also break and can cause noise. To inspect and replace the agitator dogs follow video.
Agitator Coupling / Spline
The other type depending on age of your machine use a spline. Newer GE types have a coupling that gets stripped out and the older GE type has a spline directly on the agitater that gets stripped out. You will need to remove the agitator. The dispenser usually pulls right out. This will give you access to the bolt that holds the agitater down. Remove the bolt, then place your fingers under the agitator and pull up. This can take some force. A belt slid under the agitater can also work. Once off you will see if it is stripped or not.
Belt
If your washer is a belt drive type make sure the belt is tight. Check for black soot from belt wear. Replace if it has excessive wear or broke.
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacemente of motor coupler
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor and then turn tub inside. If it spins freely with no noise the problem is elsewhere. If it is noisy it needs replacing this is expensive and depending on the age of your machine you may not want to replace it. On a belt drive remove the belts and spin tub.
Posted on Jul 10, 2013
fixinit4me
  • 10 Answers
SOURCE: Washer won't spin or drain.
This site may help:
http://www.repairclinic.com/0088_11_1.asp
Posted on Oct 28, 2007
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it.  Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
Posted on Jun 02, 2008
localwonder
  • 6784 Answers
SOURCE: FILLS WTANK WITH WATER AND DRAINS BUT DOES NOT AGITATE NOR SPINS
Hi. your timer assembly is faulty. it is not initiating the spin and proper wash cycle due to this malfunction. the timer is responsible for the actions and commands. if its defective, it will not carry out the initiations correctly.
CLICK HERE TO BE DIRECTED TO THE PURCHASE PAGE FOR YOU REPLACEMENT TIMER.
Posted on May 23, 2009
mgprice
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
e-Guru
  • 3917 Answers
SOURCE: my ge wsm2700dawww stack washer will not agitate or spin
Hi
Please find the links bellow to diagnose your problem…since your problem to the washing machine can be caused due to various reasons.Please go through the article to have an in-depth knowledge to your query…
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntspin
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntagitate
http://www.geappliances.com/search/fast/infobase/10002166.htm
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 06, 2010
My washer will not spin or agitate, but will fill & drain
with it empty need to look at the bottom of the unit and see if the pulley and belt setup is bad.. my sisters un it broke the pulley and hers is newer..seems they dont make them to last anymore..
Feb 08, 2014 | Washing Machines
Replaced the belt and still not agitating, switch seems good
If the machine fills, won't agitate, wont drain or spin, then you need to replace the lid switch.
if machines fills, wont agitate, will drain but not spin, then you need to replace the motor coupling
Feb 08, 2011 | Frigidaire FWS1339A Top Load Washer
I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
Washer will fill and drain but not agitate
Check the lid switch if it is a top loader.
Nov 04, 2009 | GE Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Does not agitate or spin
Let me make sure I hear your symtoms right..
The washer fills...sound like the motor is running but it doesn't agitate or spin.. then when it tries to drain it bascially gravity feeds out until there is no longer enough water to force it out?
Sounds like the belt is off, or broken.. I am not all that familiar with your model, but I think most GE's are belt drive.
If it were the agitator coupler, the washer would probably still drain..
Pull the front cover off of the washer, you will see the belt and pulleys, make sure it is A: still on the pulleys, and B: tight.
If not, loosen the four bolts on the moter, put the belt on and then slide the motor towards the rear to tighten it.. then tighten the four bolts. They may simply have not tightened the bolts on the motor from factory and the motor slid back loosening the drive belt.
GOOD LUCK!!!
Jun 20, 2009 | GE Washing Machines
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
No agitate/no spin/yes spin in rinse
this is a drive shaft issue. this shaft is connected to the gear case and the gears may be stripped or the clutch may be damaged. there are many plastic parts here in this area that can break due to heavy load or just old age. replacing the internal parts and clutch will fix these issue you are having.
Mar 13, 2009 | Hotpoint VBSR3100D Top Load Washer
Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Mar 13, 2008 | Splendide 2000S Vented Washer/Dryer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
