Question about Fisher and Paykel DGGX2 Dryer
Control panel plug
It came undone and I can't find where it plugs from back of dryer to the back of controls
    Top Expert:
  • Fisher and P... Master
  • 12,223 Answers
See the diagram and proceed according. God bless you
Posted on Jul 10, 2013
Control panel does not respond on Crosley Dryer Model CDE4205AYJ
Don't you just love electronic controls. On the inside of the dryer is like it always was back in the day with mechanical timers. The same old problem the old ones had is the blower wheel slips and causes overheating or a ball of lint at the base of the filter chute. This eventually blows the FUSE. Their is 2 of them fuses so look close one is usually behind a shield out of sight and may have been overlooked. DIAGRAM
Apr 29, 2013 | Crosley Dryers
"LOC". As I turn the dial to the requested setting, all the times (15min. 55 min., etc.) are displayed, but as I go to push the 'start' button, the screen says, "LOC",...
Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
Regards,
Richard Roth
http://appliancecafe.com
Nov 07, 2012 | Frigidaire Electric Dryer
Dryer is not turning on But washer is working fine
see this causes and fix it. God bless you
Power From The House
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Main Control
The main control board may have failed. To check this check the two main feed leads entering the control refer to the tech sheet located on your dryer. The two leads are usually a separate plug of heavy wire. Check to see if power is entering you should have 120 volts. If not the problem is not the control. If you have power coming in and nothing is illuminated the main control will need to be replaced or the Timer will need replacing.
Sep 28, 2012 | Washing Machines
Dryer wont come on
Door Switch
Wiring
Main Control
Sep 28, 2012 | Amana Dryers
How to remove the front panel of my lg dryer
  • Hey Nicholas Coccovizzo
    Unplug the dryer's 3-prong electrical cord from the power outlet.
  • Pull the dryer away from the wall and turn to one side to access the back of the appliance.
  • Remove the screws at the top of the dryer on the back panel.
  • Push the cover of the dryer from the front toward the back to disengage it from the cabinet, then lift the front of the cover up a few inches and toward the back at an angle.
  • Remove the two screws inside the front corners that attach the cover to the control panel. this will disconnect the cover from the front control panel.
  • Unplug the control panel from the wire plugs connected to the knobs and buttons. Set aside the control panel
  • Remove the two screws that were hidden underneath the control panel. These screws hold the top of the front cabinet in place.
  • Open the dryer door in the front of the appliance and remove the screws just below the slot for the lint screen, keeping one hand braced against the front of the cabinet to prevent it from falling forward. Removing these screws will detach the front cabinet from the sides, exposing the motor, dryer drum, belts and the blower for circulating hot air
    Good Luck!
  • Jul 29, 2012 | LG Dryers
    I am trying to hook up my stackable washer and dryer. I havee a 220 plug 30a what do I need to do so I don't have to go back to home depot and get whole new plug in and plug?
    If the unit has a 30 amp/220volt plug, then you will need a dedicated 30 amp outlet from a 220 volt line from the panel. You can not switch the plug to work with a regular (15-20 amp) outlet. Have an electrician install a 10 gauge 220 line from the panel to the unit. good luck!
    Aug 30, 2011 | Whirlpool LTE6234D Top Load Stacked...
    Have a DLEX5101V dryer... It won't stop spinning after the timer ends - as long as the door closed it keeps spinning.
    if you can get access to your main control board be hind panel. unplug dryer then tap the control board a few times. you could have a stuck relay. plug back in and try it. may fix you problem short term.
    Aug 17, 2011 | LG DLEX5101V Electric Dryer
    I have a duet electric dryer GEW9250 about 5 years old. It stopped working last week. The light inside works but nothing else (no control panel buttons or lights or the digital display). A repairman...
    Hello there and thank you for choosing fixya
    To tell you the truth i dont think the contrlole panel was the problem the control panel rarly goes out here is a list of the most common things that go out and are a lot more cheep to replace
    Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
    If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
    Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
    Aug 05, 2011 | Whirlpool GEW9250 Electric Dryer
    DLE5977S
    Not too bad. Unplug. Remove three screws along back, at top edge. Stand in front of dryer and, using the palms of your hands, push back sharply on the top (L & R sides) to slide it back about 2 inches, then lift top off. Remove 2 phillips head screws at 5 and 7 O'clock position behind door. Remove screws holding top control from top corners. Pull top of control panel loose from retaining clips along top. (watch for sharp edges) Set control panel on top of dryer. Remove 4 screws now accessable at top of front panel. Un-plug light, door switch, lift front panel off, and unplug sensor at bottom. Set front panel aside. Remove 4 screws at front of side panel holding front bulkhead (with drum rollers attached), lift up bulkhead and remove. Reach under drum to unhook belt. Remove drum. The hardest part is pobably hooking the belt back on with the tension pulley while reassembling. On a scale of 1 - 10, it rates about a 5.5. First one might take an hour and a half. If you've done a few, you can knock 'em out in about 20 minutes.
    Oct 29, 2009 | LG DLE5977 Electric Dryer
    Control panel dead
    1. Unplug dryer.
    2. Remove 2 screws from rear top of dryer.
    3. Lift panel assembly up, taking care to not pull wires.
    4. Check plugs on circuit board for panel display. Press each one firmly, but carefully.
    5. Put back together, plug in, turn on.
    Jun 14, 2009 | GE Profile Harmony DPGT750EC Electric...
    Fisher and Paykel DGGX2 Dryer Logo
    46 people viewed this question
    Top Fisher and Paykel Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Bill Eager
    Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
