Question about Yamaha Clavinova Clavisoft 35 Diskette and Book Combo Christmas Melodies
Manual for a Yamaha Clavinova CVP-107
My church has the Yamaha cvp-107 that uses a floppy disc. You play your music and record it on the floppy disc. We do not have anyone to play so is there any pre recorded church music that we can purchase. And a manual
2 Suggested Answers
  • 10865 Answers
SOURCE: Yamaha Clavinova CVP 55 -
Hello. Most likely you will need to either clean the drive or replace it.
Posted on Sep 21, 2010
Clavinova CVP-85A. Where can I get a service manual or schematic diagram?
David
What is the problem you are having?
I have some info on CVP85/87 which shares the same service manual.
Let me know and I may be able to pass on some info.
Jan 18, 2016 | Yamaha Music
Wiring diagram yamaha cvp 303 clavinova
i have a broken cvp-85a but the pedals are ok so?
Jan 14, 2013 | Music
Need manual for CVP-700 english version
how opening yamaha cvp-700
Jun 30, 2012 | Music
The disk drive on my Yamaha Clavinova CVP-105 acts like it has a disk in it when it doesn't and won't always play pre-formated disks like it used to. Is the drive dieing? Where can I go to get it fixed? ...
Often these drives are continuosly selected by the controller and rotate even without a disk.
These USUALLY use the old 720K disks which are almost impossible to find. The common 3.5 1.44Mb floppies often will not work in these units.
You can SOMETIMES use the 1.44Mb disks by covering the second corner hole AND degaussing the disk with a tape eraser and then reformating the disk in the Clavinova.
The pre-formatted 1.44Mb disks without degaussing SOMETIMES leaves artifacts between the tracks used by the 720K disks that causes problems.
Nov 27, 2010 | Yamaha Music
Cannot use the floppy disk of my CVP 65 as it appears the memory is full. It plays new discs, but won't record.
This sounds like it MIGHT be a floppy drive problem rather than a full memory... REMEMBER to ONLY try recording a file no bigger than what the floppy will hold which is 720Kb.
NOTE: The disks used in this are not the COMMON 3.5 inch floppies, but the older 2DD 720K floppies. They have only one hole on corners where the new 1.44 Mb ones have two holes.
To USE the 1.44 Mb flopies do this: Use an opaque tape to cover the hole that does NOT have the write protect slider. THEN most omportantly DEGAUSS the disk with a degausser. THEN Reformat the disk in the CVP 65.
The pre-formatted 1.44 disk when formated at the 720Kb used by the CVP 65 will have ARTIFACTS between tracks since the higher density also have half the track spacing and the formatting doesn't always clean enough width leaving artifacts between the tracks when formatted as 720Kb These ARTIFACTS can cause trouble.
The 720Kb disks are ESSENTIALLY unavailable anymore.
Jan 15, 2010 | Music
Yamaha clavinova cvp-83s
Hi, did you manage to sort your problem as the same thing has happened to my clavinova (same model). Thanks.
Oct 05, 2009 | Yamaha Full-Size Keyboard
I have a clavinova CVP 409. If I try to record using an external memory device (external Hard drive or memory stick, a message appears; DISC ERROR. Can you please help me solve the problem or direct me...
I SUSPECT that the CVP 409 will ONLY talk to the Yamaha USB floppy drive, not a hard drive or memory stick.
The internal drivers for these musical instruments do not have the "smarts" to talk to the wide variety of peripherals that PC's are able to.
Sep 10, 2009 | Yamaha Full-Size Keyboard
Can I replace the pedal unit to the Yamaha Clavinova CVP-75?
I can't solve the problem, but just wanted to sympathize because I have the same problem. My pedal is broken on my Yamaha Clavinova cvp85a. It worked wonderfully for years but finally it broke.
I'd be in the market for buying a new pedal or fixing the old one. But I've not found any suggestions in any of these forums for either solution.
Jul 21, 2009 | Yamaha Music
Yamaha Clavinova CVP-83S NO SOUND OUTPUT
clavinova 83s...comes on but goes off within 20 sec.,sometimes comes on display lights up but no sound or functions?
Apr 01, 2009 | Yamaha Full-Size Keyboard
Keys stick on Clavinova CLP 360
A contact rubber for CVP-35, part number VS549800 will work, that's how I fixed my sensor problems on my CLP-360.
Jan 19, 2009 | Yamaha Full-Size Keyboard
Yamaha Clavinova Clavisoft 35 Diskette and Book Combo Christmas Melodies Logo
60 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
