Question about Linear Garage Door Opener Safety Beam Set
My Lenear garage door opener Model #LDO5O does not work
Lenear garage door opener does not work . what would i look for if it is the receiver/logic board in the opener?
What is the different between 41AB150-2 and 41AC150-2?
This receiver logic board (part number 41AB150-2) is for garage door openers, including Craftsman garage door opener model 13953904D.
This receiver logic board (part number 41AC150-2) is for garage door openers, including Craftsman garage door opener model 13953901DM.
315MHz Security Radio Controls Purple Learn Button Replacement Garage door opener receiver logic board 41AB150 2 for... 25313039-z4aba1t3xnu0kgnrds04j5va-2-0.jpg
Dec 08, 2014 | Cars & Trucks
The remotes for my craftsman garage door opener will not reprogram. the light on the rear of the unit does not blink when I try and reset / reprogram the remotes.
Anytime you cannot program more than one remote it is the receiver that has quit working. The receiver is part of the logic board.
Oct 27, 2011 | Sears Craftsman LiftMaster Chamberlain...
How can I test the Receiver Logic Board for Craftsman 1/2 HP Garage Door Opener Mod.139.53962SRT1
The only way a homeowner can test a logic board is with a good remote that is programmed to that logic board.
Jun 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Model 139.53684 Keyless entry doesn't work
The remotes and keypad use the receiver which is part of the logic board.'t The button on the wall is hardwired and doesn't use the receiver. You might pull the logic board and check for bad connections on the printed circuit.
Nov 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener Intermittent
Yes your receiver is bad and it is part of the logic board.
Jul 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener remote won't work
meerkat1 your receiver has quit working which is part of the logic board. The logic board runs around $80.00 for the part alone. Might be time to get a new opener.
Apr 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Linear Garage Door Opener Safety Beam Set Logo
Top Linear Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Linear Building Material Expert? Answer questions, earn points and help others
