How to repair a ruud uakb-030jaz air conditioner
Unit stopped working today. Checked breaker, roof fuse, and inside fuse. Inside fan does not come on while thermo on fan "on". No cooling. Slight humming sound coming from unit in hallway ceiling. Water pan clear. Unit got dusty during construction remodeling job. Thermo lights up fine and can be adjusted, but no cool or heat. Any ideas? Where can I get troubleshooting manual. I have tools and a multi-meter.
Therinnaiguy
  • 1420 Answers
SOURCE: no cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Posted on Sep 04, 2007
  • 1073 Answers
SOURCE: fan in my Central Cooling Conditioner Unit are not running
NEVER POKE AT ANY PRODUCT on a heating and cooling system it need to be serviced by a trained tech that knows what is going on in the unit, poking around can cause death and at the least a large sum of money if you poke the wrong place
Posted on May 20, 2008
  • 59 Answers
SOURCE: Outside Unit Air Conditioner fan not running
probably a bad fan motor. could be a capacitor
Posted on Apr 25, 2009
jumptrout51
  • 3361 Answers
SOURCE: central air conditioner doesn't cool
The capacitor is located inside the control panel on the outside unit. It is round or oval and silver in color.It runs the outdoor fan and the compressor both.
The terminals are marked= C, /F or fan/, H or herm. C-F-H.
The microfarad rating is printed on the capacitor. Make a color code wire diagram before removeing wires.
Disconnect power to the unit. Use a insulated screwdriver to short out the terminals on the capacitor before removing it.
Posted on Apr 27, 2009
  • 116 Answers
SOURCE: The outside unit on our Ruud heat pump won't turn
first look for red button neer the copper line set if has one push it second inspect thermostat wires for weed eater damage check disconnect for fuses check breaker at main panel pull disconect and remove cover check stat wire connections look at the capacitor if swelled up on top bad if all look ok put disconect in using insulated object manually push in contactor if unit comes on check for 24 volt ac on yellow stat wire to common if none stat wire could be loose at indoor unit or stat bad hope this helps you
Posted on Jun 06, 2009
NEED TO KNOW THE TONNAGE ON THIS UNIT
2 1/2 ton. home is about 1200-1400 square feet ?
Apr 18, 2016 | Ruud Matching Split Air Conditioner
Ruud UAKA-030JAZ fan spins, not blowing cold air
there are 3 things to be considered,first,if the compressor motor `s connectors are having loose,it gives a hi ampere to your RELAY that can cause to its contacts being fried,second,the compressor motor itself is gaining a hi ampere already i.e. having unusual sound that can cause heavy friction inside the turning mechanism and third the last but not the least,maybe this time,the tubes or the compressor itself having very small holes that causes to the refrigerant to escape and it doesn`t gives off cold air.
Apr 17, 2014 | Ruud Heating & Cooling
My 4 year old Ruud home a/c compressor stopped working. inside fan blows but compressor won't turn on...what can I do prior to calling the gas company who installed the unit...
Ruud parts warranty from factory is 5 years, the capacitor has possible gone out, it will be in the contol compartment on the out side unit and is a dual run capacitor that controls the compressor and fan motor. Recommend if capacitor is bad to replace entire capacitor. As Stated above the parts are under warranty if under five years old. To verify age the date code is in the serial number after the "F" **** week/year of manufacture. Also outside unit has independent power supply so check fuses if any and circuit breaker.
Aug 21, 2011 | Ruud UBHC Air Conditioner
WHAT SIZE UNIT IS A model # UAKB-042JAZ SERIAL # 6953F300414316..HOW MANY TONS IS IT...
They are: Height:19in X Length: 40-1/2in X Width: 27-5/8in
You can also check the manual here:
http://www.adamsheatingandcooling.com/ruud/ruud-ac/uakb/UAKB-specs.pdf
It is located on page 6.
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Ruud UAKB048 Air Conditioner
The air conditioner was working today i have a RUUD UAKA018JAZ, the fan is running however it is not blowing cold air out the vents
Hi, your problem is in the unit outside. Check to see if the fan is on, make sure the compressor is running also. If nothing is on, check the breaker to see if it tripped. Also, the box at the unit has 2- fuses inside behind the plastic cover you can't see unless you remove it. If the unit is off and the breaker was ok, remove the cover and replace BOTH fuses. Do all of this and let me know. If the breaker keeps tripping or blowing fuses if the unit was off, you have a componant shorted. It may be off or on and not cooling well due to a loss of freon. If it is on, hold your hand above the fan to feel the air. It should be nice and warm almost hot if its hot outside. Let me know what you find please. We can find the problem.
Sincerely,
Shastalaker7
Jun 12, 2010 | Ruud UAKA018 Air Conditioner
The outside unit on our Ruud heat pump won't turn on. The inside fan blows but the unit outside sits idle - no fan turning, nothing. It was cooling earlier today, but when I came home from shopping, the...
Jun 05, 2009 | Ruud UPMC036 Air Conditioner
When my unit is on the outside is not working the inside is blowing little hot air. What do I need to check? Its a Ruud Achievers Series
Set the thermostat four degrees lower then house temperature and fan to on. Go outside and see if fan is running. If not check circuit breaker.
Apr 26, 2009 | Ruud UBHC Air Conditioner
Air conditioner fuses
If the unit is located on the roof then they would be in the disconnect box up there. If it is on the ground then the same. If no disconnect box if found then check you breaker box for a tripped breaker.
Feb 14, 2009 | Ruud UAKA042 Air Conditioner
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
